Question about HP MP2210 XGA 1500 LUMENS Multimedia Projector
I have a HP mp2210 digital projector and I hooked it up to my Dell D610 laptop and the picture from the screen on my computer won't show up on the projector. Just a blue screen unless I push the buttons and it says "Set up" with a video camera in the top right corner showing. How can I get it to show my screen?
Yes, I solved it by unplugging everything and then re plugging it all in and it worked.
Thanks anyway!
Posted on Dec 11, 2009
How can i hook up dell latitude d610 to tv with s video cable
you need to right click on your laptop wallpaper and click personalize it may say display or you can go to the control panel and search change display once your there you should see to screens with the numbers 1,2 just drag the 2 into the 1 spot and that should take care of it you computer screen will just show wallpaper and the tv will have the icons when your done drag the 1 back into its spot.
Oct 23, 2012 | Dell Latitude D610 Laptop Computer -...
Replaced dell latitude d610 screen and now it lights but no picture
Did you remember to plug the video cable back into the motherboard? [round cable with plug on end]
Jul 03, 2012 | Dell Latitude D610 Laptop Computer -...
Projector is connected to an HP laptop. Once everything is plugged in and the projector is turned on, I turned on laptop as per the manual. The projector recognizes the device, shows the HP start up...
Press Fn + F4 keys, it will change output to external monitor.
Toggle keys to get needed combonation: projector only -> Projector+Laptop screen -> Laptop screen
Mar 09, 2011 | Dell 2300MP Multimedia Projector
My Latitude D610 Dell laptop is not connecting to the internet via my ZyXel broadcom router. In fact, the laptop doesn't even recognize the router or show the router as an option when I click on "Available...
1. Connect your router via LAN.
2. On your internet type in 192.168.1.1
3. Type 1234 on the password screen.
4. Go on the Wireless LAN tab
5. Un-check the option for Hide SSID
Dec 22, 2009 | Dell Latitude D610 Laptop Computer -...
Hook-up from d610 to tv
It is possible that your laptop drives EITHER its own display OR an extrnal monitor such as your TV. Look for a Screen Swap key on the laptop keyboard. It is usually a "Fn" key and requires you to hold down the "Fn" (Function) key whilst you tap the screen swap key. This key usually has a small picture of two screens seperated by a / . Hope this helps. Ian.
Sep 29, 2009 | Dell Latitude D610 Notebook
The display cuts off the bottom quarter of the image
you have a weird display resolution set somewhere on the laptop. The vplcs7 is relatively old. It only supports 800 x 600 (SVGA). If you are cloning your monitor, you need to set the output to the projector also to 800x600. Depending on how your laptop is configured you may need to set your laptop monitor to 800x600 while using the projector, then going back to the normal resolution when you are finished.
Feb 02, 2018 | Sony VPL-CS7 Multimedia Projector
Need to connect my dell laptop to a large screen projector using a computer video interface for vga and compatible computers I have a delllatitude d610 the interface is an inline2080
I assume you know how to connect the VGA cable and which function key is used to activate the second display. You will have problems if the laptop display size is not supported by the projector. Many older projectors will not work with wide screen laptops.
when you connect the projector, Just press the presentation mode on your keyboard, Fn + (Presentation Key), Sometimes F5 or F8!
Then you will see your desktop on the projector screen.hope this helps
Aug 13, 2009 | Dell Computers & Internet
Dell latitude d610 dark screen
there is a inverter in LCd that makes your lcd bright white shine. when it breaks down you see black screen. something happens on lcd you cant see clearly  you should go to service and need to be changed INVERTER.
pls rate
May 28, 2009 | Dell Latitude D610 Notebook
Hooking projector
You will probably need a standard VGA cable. The ends look like the connection for a monitor. Take a look if you don't know what I'm talking about: http://en.wikipedia.org/wiki/VGA_connector
There should be a port on your laptop and one on the projector. After it's hooked up you might have to toggle between the projection settings or select the correct source on the projector. Normally, there is a source or input button on the projector. If the picture isn't showing up on the projector but is on the laptop or vice versa, you'll need to toggle between settings. On my dell, it is fn (function) and the F8 key but sometimes it's the F7 key or some other F? key, just look for the LCD/CRT on the function button or the picture of a monitor looking thing. This is only if you don't see the image from the projector. Hope this helps you out!
Nov 09, 2007 | Compaq Presario 1200 Notebook
Dell 2200mp searching for signal
One problem may be that you must tell the PC to send the signal to the external monitor. Usually, if you hold down the function button and hit the F5 key you will see several options on the screen. (Other laptops use different function keys. Look for the one that shows two tv screens. You want the option which shows the laptop and the external monitor.) To advance between options, you hit the F5 button again and it moves over to the next option.
My computer needs me to lower the resolution on the laptop in order to send the signal to the projector. If you also need to do that, you can do it in Control Panel, Display, and Settings, and lower the resolution on screen number 1.
Doing both of these things should work.
Also, confirm that it is finding signals by hooking it to a DVD or video and see if it finds the signal through one of the other ports.
Sep 25, 2007 | Dell 2200MP Multimedia Projector
195 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
