Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Have Sky+ HD connected to my Sony Bravia KDL40w3000, keep getting the unsupported signal error message ?
Sony local rate helpline.
Posted on Dec 16, 2009
I HAVE AN OLD THOMSON SKY BOX(NON HD) CONNECTED TO A SONY BRAVIA 32BX320. THERE IS A POOR RECEPTION ON SKY CHANNELS PARTICULARLY NOTICEABLE ON SKY SPORTS FOOTBALL WHERE IMAGES ARE "DRAGGING", "DELAYED
First step...clean out the "old" guy with clean, dry, compressed air to get dust off the capacitors and resistors. The frequencies that the "box" selects are regulated by those components. If this doesn't work you should realize that the electrical values of those components change as they age...and like grandma, can't do the tricks they used to.
Jan 12, 2013 | Televison & Video
I have a Sony Bravia KDL-40EX400. Every morning I have to reboot my cable box to get my cable signal. I get the "Unsupported Signal" message and no picture if I don't. I have seen other posts about this...
All symptoms show that cable box is cause of problem, not sure that its internale circuit problem (signal processing in cable box) or its getting distorted signal from cable company.
TV sounds good because it works fine with blu ray player that is HD signal as well.
Change cable box just to confirm it.
I hope this tv would be under warranty so ask nearest Sony service to update its firmware under warranty cover that might fix the issue.
Thanks.
Jul 05, 2010 | Televison & Video
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Pc setting for sony bravia
'Unsupported Signal' Error indicates that TV is accepting the signals for Video but not able to display because resolution doesn't matches. Else the message would be 'No Signal'.
Follow the steps-
NOTE- Make sure cable is 15 pin(at both ends) VGA cable, working fine between PC & Monitor.
1.The standard resolution of laptop(any) which would support is 1024*768.
2. Toggle the display output from Laptop Fn Keys depending on Laptop Brand.
3. Connect the cable after settings made.
Also PC Settings will not be highlighted until connection is made.
Jan 20, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
PC input to Sony Bravia - from Sony Vaio Laptop - unsupported sig
"Unsupported signal" suggests one of two things. Either the refresh rate on your computer is set too high (it MUST be at 60 Hz.) or you have the display resolution set too high
Nov 15, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony kdl40v200
I work for sky as an Engineer (not a subby)
HDCP is the encryption sent down when a program is transmitted. Over the years I have had several jobs where this is the case.
What you can do to fix the problem is Download update for your sony bravia telly this will fix the problem. There is another solution, if you get another engineer out ask him to put a different manufacturers box in..... Sky HD is made by Thomson, samsung, pace, Amstrad,
both solutions have worked for me when coming across theses faults whilest installing sky... The first one is going to be your best option... for example at the minute all I am getting when i go to pick my HD stock up is Amstrad. No other manufacturers so you may find it hard for the engineer to source you a different make.
If neither work. Force a download to your HD box (they have been updating the software recently so this may also work for you.)
Take the power out the back of the HD box. hold down the Standby button then reinsert the power. hold Standby button in until all light are lit on the front of the box... Then wait 10 minutes (better off making yourself a cuppa) give that one a try.
Hope ive been of some help to you
Little Dish Fitter
Sep 17, 2008 | Sony BRAVIA KDL-40V2000 40 in. LCD...
Sony Bravia
I have purchased KLV-40W400A Full HD but I am not satisfied with the picture quality. When the issue was raised sony is putting blame on Tata Sky and vise versa.
Kindly suggest.
Jun 19, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
413 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
