Question about Acer NSK8458AN Keyboard
Typing requires pressing & holding for about 2 sec
  • 2 more comments
  • john_benn615 Dec 10, 2009
    have gently vacuumed keyboard problem remains more advice please
    i cannot find the area in control p. for adjustment need more detail
    HELP THIS FORMAT IS VERY POOR IN ITS RESPONCE TO A slow type
    typing is the problem i need detailed instructions - control panel - keyboard changes - then press ?
    Brigadier General:
  • 3,917 Answers
Hi
As you have mentioned that your keyboard works but you have to keep the keys pressed for a longer period of time for the character to get printed it’s clear that there is a dust issue. If the keys do not strike correctly, make sure that the keyboard is free of dust, dirt, and foreign matter. Turn the keyboard upside down to allow for any foreign debris, such as hair, food particles, or dust, to fall out. We recommend that you periodically use compressed air to blow dust out of the hard-to-clean crevices in the keyboard. If you spill a drink or some other liquid on the keyboard, immediately turn the keyboard upside down to let the liquid drain out, and then mop up as much liquid as possible. Wait until the keyboard is completely dry before you use it again. Let us know if you need further clarification.
Thanks for contacting fixya.com
Posted on Dec 10, 2009
  • 855 Answers
What it sounds like your problem is, is that the key sensitivity and speed need to be adjusted. On your computer go to your control panel then to your keyboard, Under your keyboard you will see setting that you can change . At this point depending on how you type that will determine where to adjust settings. Not knowing how you type I'll give you the easiest way to set them. The easiest way would be decide which one or ones you want to change. Write down where the settings are now. Then make adjustments,you should be able to try them there, if not youcan make one or more changes at a time then try them out. Once you have them set to where you are comfortable with them you would be done, Take your time and adjust them making slow changes that way you won't overshoot the adjustment that you need. Good Luck and I hope this helps you.
  • Ronald Park
    Ronald Park Dec 10, 2009
    After you go to keyboard set your speed and repeat speed. Put your cursor over adjustment arrow and hold down the left mouse button and move. Then there should be a block where you can type to check speed and readjust as needed.
What are the 2 pins in the back for? master slave configurations? If so what jumper setting makes it a slave?
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
dont forget to vote
Feb 06, 2011 | Hitachi Deskstar 7K160 HDS721616PLA380 160...
When i installed hard drive and set the jumper on primary master it dint show up and in bios the txt is showing like that primary master drive 0 (not installed)
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test or replace all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard)) drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
Feb 06, 2011 | Seagate Barracuda 7200.7 40 GB Hard Drive
When i install some thing the bios not comes.tel me what is the booting key with step by step
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps
hope this helps
Dec 30, 2010 | Computers & Internet
How to master rester a compaq presario sr2150nx
hope this helps
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
??????????????????????????????????????????? hope this helps
Dec 29, 2010 | HP Compaq Presario SR2150NX PC Desktop
I can not log in my router home page
1. Connect only a comptuer to the router using a ethernet cable to any one of the gray port on the router.
2. In the computer connected to the router, Click on start - > Run / Start scarch -> [type] CMD & hit enter.
3. In the black screen [Command prompt] type Start http://192.168.2.1 & press enter.
4. If still does not work.
5. In the black screen [Command prompt] type ipconfig & check what it the IP address under ethernet adapter local area connection,
6. It should be 192.18.2.x where x is a value from 2 to 254 & the default gateway should be 192.168.2.1.
7. If you get 169.254.xx.xx or any other numbers then try unpluggin the power from the router & pluggin the power back in after 30 sec.
8. Still the same numbers try pushing on the reset button at the rear of the router using a paper clip or pin for 10sec & release it after 10 sec once again unplug the power from the router wait 30 sec & plug back after 30 sec.
9. Again try step 3.
Thanks
Dec 27, 2010 | Computers & Internet
I have a Zenith TV and need to reprogram my remote.. thank you for the rca ones,,
OK if you need remote code try this:
11423/10017/10463/11265/10145/10092/10030/11145/10016 .OK need how point your remote to your TV then press & hold on remote TV button at the same time remote power button until solid light come up then press & hold play button for 5 sec until TV sleep then press and hold reverse button for 2-3 sec until your TV light up if yes press stop button.
good luck.
Apr 28, 2010 | Universal Remote Control GE174Universal...
How do i shut off the energy saver compliant on xerox c20
For majority of the models Xerox entry in service mode holding [0], include the device.
Entry in service mode
Xerox 5845, 5855
Or include the device with simultaneously pressed button [Interruption] and [2], or on included device to press and hold these buttons more than 2 sec. If device faulty - an entry is realized button [Interruption] and [5], with restriction function (consecutively appearing reports on fault are thrown double keystroke [Foots]).
Hereinafter, the device calls четырQхзначный code of the access: this or 8765 (by default), or the last four numerals counter mines in inverse order (if counter mines shows 01234567 - a code of the input 7654).
Xerox N17, 24/32/40, 3225/4025
There is 3 diagnostic modes:
1 - are checked breakers, sensors and are removed parameters фьюзера, input: (2+6), after "IOT?" press "7" 2 - haves something published the test-sheet "net" in simplex or duplex, input: (2+6), after "IOT?" press "4" 3 - are changed parameters and adjusting the printer (NVRAM), input: (2+6), after "IOT?" press (4+7), "7" immediately release, "4" keep before appearance "3" on дисплее, then release.
XD102...155, XE60...84, XC800...1255
stop auto stop auto
sometimes write as C Density select C Density select (that same)
WC PE 16(e)
we type on keyboard [menu] - [#] - [1934] - [menu], after entering inscription "TECH" will appear in service menu
Oct 12, 2009 | Xerox CopyCentre C20 Black and White...
MY 6310 just stopped on me. I have to unplug and plug it back in but stops again. All lights are blinking and it said to RESET POWER.
HP 6310 Reset
There are 3 types of resets in the printer
1.Partial Reset
2.Semi full Reset
3.Full Reset
To do partial Reset.
1. Unplug the power cable and turn off the the unit.
2. Press and hold # & 3 at the same time with out connecting the power cable.
3. While holding the button, connect the power cable and do not the release button for 5 sec.
4.Then turn ON the unit
To do Semi full Reset.
2. Press and hold # & 6 at the same time with out connecting the power cable.
4.Then turn ON the unit.
To do full Reset.
2. Press and hold # & 9 at the same time with out connecting the power cable.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 29, 2009 | HP Officejet 6310 All-In-One InkJet...
Reset power
1.Unplug the power cable and turn off the the unit.
3.While holding the button,connect the power cable and do not the release button for 5 sec.
To do full Reset.
Thanks, Joe
May 30, 2009 | HP Officejet 6310 All-In-One InkJet...
HP iPAQ 2490B can not be hard reset
remember that you must hold down the two buttoms at the same time then push in the reset for 2 sec (holding it in). release the 2 buttoms then remove the stylus for the reset port. after about 4 sec press & release the reset buttom again, sytem will pwr up. If this doesn't resolve the issue then try the clean reset but bear in mind u will loss any thing u installed on the ipaq as system go to default setting and u will be required to align the screen. good luck
Mar 07, 2009 | HP iPAQ HX2490 Pocket PC
Acer NSK8458AN Keyboard Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
