Try resetting your PRAM to 'reset' your firewire-port:
- Turn off your iMac
- Press and hold command-option-P-R (command = applekey, option = alt)
- While holding this combination, turn on the iMac.
- Keep holding this combination until you have heard
the 'startup chime' 3 times.
- Allow your mac to boot up.
If this didn't work, try removing the power cord from your mac after turning it off, and leaving it unplugged for 15 minutes before turning it back on.
These steps usually work for me when I have a firewire-problem. I hope it helps for you.
Regards,
tS
Testimonial: "the firewire port is fine; recognizes two other drives connected via firewire, so resetting the PRAM won;t make a difference."
Hi there
It looks like a filesystem-related problem, but Firewire might still be the culprit (Sometimes it just 'banishes' certain devices). Check System Profiler > FireWire, and see if your hard drive shows up in there. If it doesn't, try the PRAM-reset, otherwise, try the following:
Open Disk Utility and check if your drive shows up in there. Select your drive and press Repair Disk. If your drive doesn't show up, or the repair process fails or hangs, try this:
- open Terminal
- type in "top" (no parentheses), this will run a system monitor program
- maximize the screen, and look for a process called fsck_msdos or fsck_hfs
- note down the Process ID (PID) of this process, it should be a four or five digit number
- press ctrl + C to close the system monitor
- type in sudo kill and then the process number you noted down
(for example sudo kill 1948)
- Terminal will ask for your password. Type in your password and press enter (note that no ***** will be shown while typing your password, so take care to type it correctly)
- your drive should show up now (with an error that it couldn't be repaired) in read-only mode
To restore full functionality, you'll have to reformat the drive. Back up your files to another drive, and then format the drive using Disk Utility:
- select the drive
- select the Erase tab
- choose Volume Format and Name to your liking (Mac OS Extended is only readable by Macs, or PC's with Macdrive installed, MS-DOS is readable by both but only allows files up to 4GB)
When formatting is complete, you can move your files back to the drive.
Hope this helped...
