Question about Acer X193W LCD Monitor
On boot and thru windows startup the top 1/3 of the screen is a lighter color, it stays that way...like the contrast is gone out of it...I switched to another monitor and no problem...Is there any way to adjust this problem out? ACER X193W...thanks in advance
Benimur
  • 6966 Answers
SOURCE: Windows XP Pro. driver for the acer LCD Monitor X193W
To my knowledge, it is compatible and certainly would work with XP. Since this monitor has both DVI and VGA inputs make is compatible for most video cards or even a built-in video of the PC. If for some reason the Acer X193W would not work with your Windows XP PC, possible reasons are:
  • Screen Resolution and/or Screen refresh Rate of the PC's Display Properties too high, try lowering them down;
  • hardware fault either on the monitor or video card;
  • incorrect/missing drivers of the video card;
  • it is being hooked as a secondary monitor and the dual/twin view is not activated.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 08, 2008
  • 408 Answers
SOURCE: How to adjust intensity of Acer X193W LCD monitor manually
if you go into the screens menu, there will be a button for contrast and brightness.  When you have the one you want selected, press munu again and that will bring up the dialog to change the percentages.
Posted on Mar 06, 2009
avcstereo1
  • 143 Answers
SOURCE: Acer x193w LCD Monitor repeatedly auto configures.
Here is a link to get the manual:
http://www.acerpanam.com/synapse/data/7117/documents/X193W%20(Qisda)%20user's%20manual.pdf
Starting on page 15 are the directions for the monitor controls. Page 17 indicates a "RESET" feture to Clear the Old-Statuses of "Auto-Configuration". There are quite a number of setting for this monitor.
Posted on Jun 11, 2009
FreeTech
  • 426 Answers
SOURCE: how do you change the contrasting on the acer
Check for hidden buttons around the ridge and on the back if none are found you will need the software from acer to manage the display settings
Posted on Jul 21, 2010
mcdevito75
  • 1970 Answers
SOURCE: how do I change the contrast on my monitor Acer
mcdevito75 here, Press the AUTO button on the monitor under to lower edge of monitor itself. This restores factory settings, if you still want to adjust, press MENU button then use left / right arrows to adjust picture quality.
Posted on Jul 27, 2010
After booting up all I get is a black screen
Try this:
If you're booting up the device and it goes thru the Post test and then goes to a black screen this usually means your OS has crashed.
You will need your Operating system or Recovery Disk.
I hope you've backed up your data and files.
Try this:
Windows 7
http://pcsupport.about.com/od/toolsofthetrade/ss/windows-7-startup-repair.htm
Vista:
http://pcsupport.about.com/od/toolsofthetrade/ss/windows-vista-startup-repair.htm
XP:
http://pcsupport.about.com/od/operatingsystems/ss/instxprepair1.htm
Good Luck!!
Aug 16, 2012 | Compaq Computers & Internet
Black screen on Acer aspire 1642
Try below steps.
1. Check computer in safe mode (Tap F8 while booting)
if works fine in safe mode , check startup programs and services.
2. Run antimalwarebyte in safe mode download from http://www.filehippo.com/download_malwarebytes_anti_malware/download/6a5b2c1adb0e88e84ab39920bab1ebbd/.
3. Try to repair using repair your computer option (windows 7,8)
Dec 02, 2011 | Acer Aspire 1642WLMi Notebook
I have a Satellite Pro A120. The screen has gone red at startup and colours are all wrong now.
Try booting to BIOS. If you have the same problem, LCD is already defective. If the color in BIOS is normal, it means you only need to reinstall Windows. To go to BIOS: Turn off computer. Press and hold F2 then press power button. When it starts, you should see the Advanced Setup screen. The screen is color blue with yellow or white texts.
Dec 08, 2009 | Toshiba Computers & Internet
Screen colors washed out
You can RESET the monitor setting externally by clicking adjustment menu button goto RESET press ok. If contrast and birghtness not set properly light will not be properly visible
Dec 10, 2007 | Samsung SyncMaster 940MW 19" LCD Monitor
Constant white screen
check the brightness and contrast from the menu on the monitor try increasing it ... the problem will get solved...
if same problem persists contact ur near by experrt technician he may tell that the tube is gone he must recharge it....
Sep 11, 2006 | Sony SDM-HS73P 17" LCD Monitor
Acer X193W LCD Monitor Logo
21 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
