Question about Samsung SyncMaster 245BW Monitor
My syncmaster 245 bw will only display a blank screen through the dvi port. Another crt monitor works fine through the vga port . I'm running a nVidia 7800 GS video card.
  • wardysbiz Dec 10, 2009
    This was somewhat helpful as it added to my knowledge but not helpful to the problem as the refresh rate was already set to 60 Hertz. The Samsung manual has a self test that unplugs the monitor from the computer. A test screen should display if the monitor is working. The screen is still blank. Will Samsung opt to replace or repair this problem, and how long will it take to resolve all of this? I'm still within the three year warranty period.
    Sergeant:
  • 208 Answers
You need to adjust the monitor refresh rate to 60 Hertz or 70 Hertz.
Use the CRT first to adjust it, then after adjust,plug in your Sync Master to see is it perfect or not,find the best frequency that work best.
To adjust it,right click on the screen,enter properties, then click setting tab.
Then in advanced tab, click it then you see the monitor tab, find the perfect screen refresh rate.
Posted on Dec 10, 2009
  • donny ardalando
    donny ardalando Dec 10, 2009
What connections are required
Make sure the monitor works on a friend's PC using the DVI... let's not go backward to VGA when DVI is available on both the PC and monitor. If the monitor works, install the driver and reboot. It should work for you too.
Jun 19, 2014 | Gateway HD1900 19" Monitor
Hi I BOUGHT NEW Samsung SyncMaster P2070 20" LCD Flat Screen Monitor , AND I HAVE HP COMPAQ AND THE MONITOR NOT COMMUNICATE WITH PC
http://support.dell.com/support/edocs/video/p56135/en/connect.htmhttp://support.dell.com/support/edocs/video/p56135/en/connect.htm
you Monitor uses the DVI-I Port this link will show you what it is. you will need a adapter that can connect to VGA port on your PC. unless your HP has a DVI port. You need a DVI-I to DVI-I connection to work if it has one
this link will explain the difference of the DVI ports...
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=51555&prodTypeId=329290&objectID=c01525281
the adapter you need is a DVI-I to vga ...
opensources_1.jpgcheck the pins on both the pc and the adapter and monitor
Sep 14, 2011 | Samsung SyncMaster P2070 20 inch LCD...
I have a syncmaster 400p i need a new graphic processor can u reccomend a compatible one
Good day,
If your screen has a VGA, DVI, or HDMI port, most of the new graphics cards will be compatible with your screen. Most graphics cards come standard with DVI ports and include a vga adapter for the screen cable. Some of the new graphics cards come with HDMI and DVI ports or a HDMI converter if you want to use HDMI.
I would recommend a Nvidia graphics card. Depending on what your primary use is going to be they have an extensive range to cater for your requirements and price range.
Hope this helps!
Regards
Nov 28, 2010 | Samsung SyncMaster 400 T 40 in. Flat Panel...
Samsung syncmaster 2033sw monitor, till now i was using a vga cable for the display, but recently i bought a dvi cable and connected it. but its not detecting the display of dvi cable. if i remove the vga...
LCD Monitors having multiple inputs have option and option to select and switch between the displays from analog (VGA) or Digital (DVI) inputs. Go to the LCD menu and select input source (DVI)
Hope this helps!
CreativeTECH
Nov 15, 2010 | Samsung Syncmaster 2033SW Monitor
I have this monitor hooked to my PC ATI 7500 graphics card with a DVI cable. When the PC initially boots up, the monitor display is blank - it does not display the boot-up messages until the MS Windows...
This is normal. Your monitor has a VGA hook in for regular definition. What it is doing, the monitor always by default looks for the VGA hook first. On my desktop it does the same thing until it finds a signal on the DVI.
Dec 29, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
Jul 21, 2009 | LG 22" FLATRON LCD Monitor
Switched from crt to lcd, no display!
You need to install the Display driver shipped or downloaded from net.
Mar 31, 2009 | Samsung SyncMaster 171 V 17" Flat Panel...
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Nvidia GeForce 7200 GS PCIE - Multi-Display does not work
This card does not allow you to Multi-Display with the VGA port and the S-video port. If you put a DVI to VGA port adaptor (not supplied) on the DVI port, you can Mulit-Display two VGA monitors and (presumably) a VGA (from the DVI port) and S-video monitor.
This is not explained anywhere and the card does not come with a DVI to VGA port adaptor, so I wa only able to work this out after I bought the DVI to VGA port adaptor.
May 21, 2008 | Nvidia GeForce 7200 Graphic Card
Samsung SyncMaster 245BW Monitor Logo
438 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
ismael castillo
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
