Question about Meade ETX-90EC (325 x 90mm) Telescope
I purchased a used etx90ec. Two of the battery terminals are moderately corroded. The lights on the control do not come on and it doesn't work.
  • 3,186 Answers
If you can clean up the battery terminals with sandpaper, then you will need to try an outside power source.
Buy either the 110 volt adapter or BETTER but a 12 volt power pack at Wal Mart (the kind you use to start a car) make sure it has a 12 volt cigarette lighter style plug.
You can buy either the 12 volt power cable or tthe 110 volt adapter from www.scopestuff.com. I never use the internal batteries, always a 12 volt power pack. The ETX likes steady 12 volt current.
If it does not work with the outside power source then something is burned out on the main board. You will need to return it to Meade for repairs. Here are several links you need.
http://www.meade.com/support/index.html
http://scopestuff.com/ss_cig1.htm the 12 volt cable
Posted on Dec 10, 2009
Battery light on 2006 focus comes on inter.
Fist thing to try for a quick fix would be to clean terminal posts. It's a pretty easy do-it yourself project.
To do this find where your battery is connected, remove the negative battery cable (black with a - sign) then remove the positive terminal ( red with a + sign). Clean both the terminals and cable end with a wire brush. If heavily corroded, use a paste of water and baking soda on a toothbrush to scrub then rinse off. This may bubble and foam when it comes in contact with the corrosion. After you've rinsed off any remaining baking soda, replace the positive terminal first and tighten, then replace the negative terminal and tighten.
If that doesn't solve the problem, I'd have the alternator tested and replace if necessary.
Good luck,
Brian
Sep 05, 2012 | 2006 Ford Focus
The red light shows when the phone is charing, but the phone is not taking charge sonyericsson vivaz
Please do this basic steps.
* try to change the charger to see if its just the problem,even you see the light indicator of the charger,might the cord got intermittent wires due to improper handling or usage. this might happen when you try to roll the entire cord so tight.
* changing the battery is another option,when the battery got drained,the charging current doesn't able to get up,in this case it needs a replacement,might been using this battery for a long time.
* also check the charging pins or terminal if its clean and align,sometimes moisture or corrosion takes place,try to clean it using any pin and scratch the corroded or dirty part or the terminal so the current will continue undergo charging.
I hope this simple steps will definitely solve your problem... Thank you for visiting fixya.
Jul 03, 2011 | Cell Phones
Ti nspire calculator. calculator will not turn on. installed new batteries, calculator only 2 years old with moderate use by daughter for school. ti cares sent me a link on troubleshooting, methods did not...
I have fixed several TI calculators for a school that had loose or corroded battery contacts. Cleaning the contacts and bending them a bit to get a good grip on the batteries got them going. You can try this on yours and see if you have any luck. Also try another set of batteries on the off chance one of the new ones you installed is bad (it does happen, and isn't one of the first things you'd think to check) or use a battery tester. If the batteries are good and the calculator still doesn't work, something inside has failed. Either go for the refurb or (if that specific model isn't required for school) see what similar brands and models are available. There might be something suitable for less than the TI price.
Jun 30, 2011 | Texas Instruments TI-Nspire Graphic...
I have the Hunter remote control fan model UC7848. The remote has stopped working, although the light does come on when the battery was replaced. There doesn't seem to be another way to turn the fan on. ...
have you sanded the terminals off on the battery contacts in the battery compartment in the remote,even new batteries at 3 volts between the 2 batteries cannot pass alll the signals if the tabs of the battery are corroded,i know ,you will say,they look shiny,but any glossy corrosion will inhibit battery voltage,use a nail file board lightly
Jul 28, 2010 | Hunter 52" Ceiling Fan With Light And...
Turned off my 2006 Escape & now it won't start.
battery failure ,it does happen,cleanbattery terminals pour boiling water over terminals if they are corroded loosen clamps by undoing nut wiggle clamps back and forthand and retighten if no lights then ,iwould suspect computor failure -------- youdoit.com
Jul 25, 2009 | 2005 Ford Escape
No Sound/No Power
I used your site to research the problem further. I found an answer which recommended rubbing the suspect terminal lightly with a pencil eraser. It worked! I now have battery power and my headset works fine.
Nov 30, 2008 | Bose QuietComfort 2 Consumer Headphones
Meade ETX-90EC (325 x 90mm) Telescope Logo
155 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
