WHY POWER BLINKS CONTINUSELY AND WITHOUT NETWORK CONNECTION INDICATION LID IS GLOWING
  • 8,404 Answers
And you rebooted everything and it still blinks? Blinking on a router power supply is not a good sign.
You dont mentionthe brand, but I believe if you look at the case you will fild a small hole. Insert a paper clip and gently depress the button for about 30 seconds. Unplug the device, of course.
If this doesnt change anything, your device may be among the departed.
Posted on Dec 13, 2009
Lg 32 lv 3500 some times power on .standby led is glow on glow off .what problem plz help me
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Aug 18, 2015 | LG Televison & Video
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Continus short beep coming from mbd(mother bord) no display?
try removing the memory card then power on again without the memory card and see if you have a display now if so then replace the memory card.
Feb 27, 2012 | Gigabyte GA-945GCM-S2L Motherboard
My d-link router name no longer appears in my wireless networks list - I can not find it to connect to the internet wirelessly
Hi, this seems to be either an issue with your router's hardware or local computer wireless adapter hardware. In order to determine which one is it do the following:
1. Go and check the LEDs on your wireless router to see if there are any blinking or switched off as stated in the official manual documentation for DLink products (can be found here or here more specific).
LEDS are as follows (left to right - per official user manual/doc):
- Power LED = A solid light indicates a proper connection to the power supply. cdekatrr_0.png
- Internet LED = A solid light indicates a proper connection to the Internet port. This LED blinks during data transmission. cdekatrr_1.png
- WLAN LED = A solid light indicates that the wireless segment is ready. The LED blinks during wireless data transmission. cdekatrr_2.png
- Local Network LEDs = A solid light indicates a connection to an Ethernet-enabled computer on ports 1-4. This LED blinks during data transmission. cdekatrr_3.png
2. Check the laptop's or desktop wireless adapter if it is disabled or enabled and if is disabled enable it by going to your computer's Control Panel (either winxp or vista/win7) and go to network connections (in vista/win7 put the control panel in detailed view to see more options) and then right click on your wireless connection and click enable.
3. In a case that also the wireless adapter is enabled but you still cannot see any access points/wireless networks please go to your current wireless connection and right click go "Diagnose", this feature is mainly available in windows 7 or Vista. For windows XP, go to the command prompt by going to Start->Run->type in the box "cmd" without the quotes->Then type in the following set of commands.
ipconfig /release ---> This will refresh your wireless card IP settings/configuration to 0.
and after that command finishes, type in:
ipconfig /renew --> This will get new settings if the wireless card has problems finding an address from your router.
You can always reset your router (unplug from power supply, wait 2minutes then plug it back in)
or:
Reset the wireless adapter (right click from on the wireless adapter shown in the network connections, disable and then re-enable it) or computer.
Thanks please let me know if you need anything else.
Mar 20, 2011 | D-Link Wireless N 150 Home Router 4Port...
DELL Inspiron 530, green LED in the back under power cord glows solid, but the CPU will not power up, no fan, no beeps, no nothing. If I press the power button it glows amber briefly, and if I hold the...
This is a hardware related problem. The issues you described indicates that your power supply has gone bad. You will need to replace the unit.
If possible please rate this solution.
Aug 26, 2010 | Dell Computers & Internet
I shut down my laptop but it is getting shut down but after that one flash light or background light is not going . what can i do for that?
If you mean the led-indicator lights typically placed on a row with small icons engraved in the plastics assigned to each light, normally the battery led-light indicator will glow if the power adapter is connected to the laptop, some devices may have a network led indicator, which might glow if a tele-wire or RJ-45 cable is connected to a network port. If the 'sleep indicator' (typically a moon-shaped symbol) is glowing it means that the device is in sleep or hibernate mode, and not properly shut down.
May 26, 2010 | Lenovo 3000 G530 Notebook
Hi. I have a Bosch 1400 washing machine - it's 3 years old. It has just started not spinning when the drum is full. If I take about half of the wet laundry out it's fine. It doesn't seem to be unbalanced.
What is happening, is your capacitor is faulty. Remove screws holding the lid on to the machine, Lift off lid and with power being off, look for a typical white cylinder that has 2 wires connected to it. On it will read 16micro farad capacitor/ 440vplts etc. Remove it, take it to the parts store and ask for a replacement. Reinstall capacitor and then try running machine on the usual program. If all ok, switch off then replace lid and away you go. Do not continus to run motor as it is now.
Nov 12, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
My network switch LEDs all blinking even without LAN connected
The LEDS blinking normally would indicate reset internally or when the unit has just been powered on. Continous LEDs lighting up or flashing with or without a connection is an indication of extensive hardware failure. This could have been brought about by a near lightning strike, a power surge or simply component failure. Unfortunately the repairs is not economically reasonable and therefore a replacement might be better off. Sorry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 28, 2008 | Cnet PowerFAST Networking Hub
Network Lockup and all indicator lights ON after popo
If the ports still glow without any device plugged in , there is a hardware problem
Nov 02, 2007 | Linksys EtherFast EF4124 24-Port Ethernet...
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
