Question about FIC P4M-865G MAX Motherboard
I cant find where to connect the power cable?!
  • 35 Answers
ATX Main Power (20-pin) is located next to the IDE-drives, the P4-connector (square, 4-pin) is a few centimeters behind the USB-ports.
Posted on Dec 10, 2009
Says cant make connection
I recommend powering down your streaming device, computer etc.
Power off the router by unplugging the device, but leaving the cable attached. Leave this powered down for 5 minutes. Plug device back on and allow the all lights to power on. Than attempt to connect to Netflix again.
Dec 27, 2014 | Netflix
How to connect mercury PVM 900 motherboard
you need manual here it is http://www.driverssoftwareupdates.com/p/pvm_900m_manual.html
Jan 15, 2013 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
WHEN I POWER ON IT CANT DISPLAY MY COMPUTER IS
there is a possibility that you are having no post issu.try to drain power, remove all cables conneted specially power cord then press and hold the power button to drain power on the system. connect all cables try powering on the system. if still no go try using diff monitor if still not showing any indication you might need to have replacmeent for the motheboard.
Jul 21, 2010 | Dell OptiPlex GX260 PC Desktop
My router cant connect to the internet through the modem and i cant acces my rfouter setting cause cant install it
How to quickly install and use your Belkin wireless G router 1. Step 1
Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2
Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3
Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4
Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
5. Step 5
Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
or folow the link you will get all your solution
http://www.google.co.in/images?hl=en&rlz=1R2SKPB_en&q=linksys+router+setup&um=1&ie=UTF-8&source=univ&ei=PzPPS_e-I4a1rAeYxryFAQ&sa=X&oi=image_result_group&ct=title&resnum=4&ved=0CCEQsAQwAw
Apr 21, 2010 | Linksys WRT300N Wireless Router
I cant get power to my motherboard
Please check first your power supplier is connected with motherboard with certain probability.
Check the power cable is not detected as corrupt.
If these causes occurs then change your inbuilt power cable.
Nov 15, 2009 | ASUS P5S800-VM Motherboard
Psu
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
Power stop working all the sudden i cant get no power at all
make sure that there is light on POWER cable and power adapter and cord are connected together. try to plug power cable in anothr wall socket and then turn printwer ON. ur issue will be resolved
Aug 17, 2009 | Office Equipment & Supplies
Cant connect my mobile to a computer via usb keeps
connce ur mobile to computer after swiff off mobile i hope it will be connect
if it will not connect please change ur data cable
May 14, 2009 | Microsoft Windows XP Professional
I cant get out to the internet when I connect the netgear router.
Be sure that your cable company has enabled your internet. Power down the cable modem, power down any routers and computers. Start cable modem first, after internet connectivity is indicated, power up the router (if you have one) and then power upi the pc
Dec 27, 2008 | Arris Touchstone 450a (CM450) Modem
Wireless key on my laptop it wnt work
Check all cable connections
Ensure devices are powered on
Check the cable connection or to the hub ensure you have green link light
Make sure you are using the proper cables - CAT5e ? CAT6 - not crossover
Jun 09, 2008 | Computers & Internet
FIC P4M-865G MAX Motherboard Logo
168 people viewed this question
Top FIC Computers & Internet Experts
Marvin
Marvin
madadam1965
madadam1965
Vernon Taylor
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
