Question about Linksys WRT300N Wireless Router
When i connect to computer ethernet light does not come on
  • 35 Answers
The most probable cause of this is a disabled network adapter.
Go to Start > Control Panel > Network Connections.
You should see an icon named 'Local Area Connection'. If the icon is greyed-out, you right-click it, and select 'Enable'.
If these steps aren't working/visible, try reinstalling your network adapter driver. (check your computer documentation for more info)
The problem might also be a faulty ethernet port on your pc and/or router. In this case you will have to replace the router or install a new network card in your pc.
Hope this helped,
tS
Posted on Dec 10, 2009
  • Linksys Master
  • 32,281 Answers
If the link LED does not light up on the computer then the fault is most likely a faulty LAN cable or the LAN card is faulty.
Replace the cable first and if this doesn't work check the LAN card and reinstall the LAN driver. If this doesn't work then then LAN card is faulty and needs to be replaced.
Only power light goes on when I reconnect to electricity. WLAN and LAN lights stay off
It sonds like you are ethernet connected to the Edimax from your home computer. Can you access a wireless connection? If so Try This:
Unplug the ethernet connection between the PC and the router. Exchange the connection (The ethernet connected to the PC place it in the Edimax and Put the connection from the Edimax into the PC) Check to see if you have a connection light on both devices.
Reboot you Edimax and PC. First turn on the PC and let it power up to the desktop. Once the PC is on then power on the Edimax. Now check to see if you have a connection. If these steps don't work I suggest you try replacing the ethernet plug connected between both devices.
Aug 14, 2012 | Edimax EW7416APn (EW7416APN) Pre80211n...
New modem installed and router won't work now
First step is to make sure if the modem is working. Connect your computer directly to modem with ethernet cable and see if you can log on to internet! if yes
next step connect modem to your router's WAN port with an ethernet cable and then connect your computer to one of the LAN ports of router with ethernet cable. Power down all devices and power up modem first wait until all lights are on and then router wait until all lights are on then your computer! 9 out of 10 times this works! try good luck!!
Sep 23, 2011 | Dynex 4-Port Ethernet Broadband Router...
No internet or lan lights on? Tried reset, hard reset. All other lights, power, wireless, router are on and green. No lights on internet and lan connection. I have tried another wireless router and have no...
The LAN lights will only turn on once you have an Ethernet cable connected to it and the other end of the cable is connected to a working computer.
If you already have a computer connected to the Ethernet port of the router via an Ethernet cable and the lights are still off. Check if the computer you have connected recognizes a network via LAN.
If the lights on the router are still off and the computer doesn't recognize a network then that means that the port for the ethernet of your Router is bad and sadly there's no way of getting that fixed but to have the router replaced.
Otherwise if the lights are off and the computer recognizes the Network and lets you connect to the internet or other computers on the same network then its just the LED of the LAN light that's broken and I think you can live with that.
Hope this helps!
Jul 18, 2011 | Buffalo Technology AirStation Nfiniti...
Cannot connect to web.
Follow this steps
1. Connect the provided power adapter from the gateway's POWER port to an electrical outlet. The POWER light on the front of the gateway should be green. 2. Connect the provided gray phone cable from the gateway's PHONE LINE port to the DSL filter jack labeled DSL/HPNA. 3. Connect the yellow Ethernet cable provided with the gateway from the LOCAL ETHERNET port on the gateway to your computer's Ethernet port
With your computer completely started, verify the POWER and ETHERNET indicator lights on the front of the 2Wire gateway are green. If they are not, see "Understanding the Indicator Lights" on page 15. The INTERNET indicator light will not turn green until the gateway software has been installed and an Internet connection has been established.
Mar 22, 2011 | 2wire Computers & Internet
Cannot connect to the internet on my home computer. Can connect on laptop. Just got a new modem and is working. Ethernet light is not on when plugged into the home computer. Ethernet light is on when...
Check that the Ethernet driver is up to date on the home computer.
What modem manufacturer and model do you have, now, and what modem manufacturer and model did you have before, when it was working with your home computer?
Aug 04, 2010 | HP Pavilion a420n PC Desktop
Modem:AZTECH DSL605EW Hi i have no lights on my ethernet (1,2,3, &4) lights. What does this indicate?
It will be lit up if there's a Ethernet Cable Connected to either of the 4 ports. If you will be using a Hardwired connection to connect the Computer to the router you will see that the light on the port where the ethernet cable is connected will lit up. However if you will be using wireless connection then it wont lit up.
Thanks for using Fixya.
Jul 29, 2010 | Aztech Computers & Internet
I cant install my router. The internet, power, WLAN, and DMZ lights are all on, but none of the Ethernet port lights are on, but when I try to complete the install I get the following error message: Unable...
If the ethernet light is not coming that means your router is not detecting your computer. Try to plug the computer on any other port.
To check if your ethernet ports are fine you can perform a loop back test. You can take a cable which is not connected to anything. Than put one end of the cable to one ethernet port and put other end of that same cable to any other ethernet port. If the light on the ethernet ports led up means your ports are fine and u need to reinsatll the drivers of the ethernet card on your computer. Else your routers ethernet port are not functioning. If that is the case you can try to reset the router.
Let me know your finding.
**If this works please rate else let me know in case of further help.**
Jul 03, 2010 | Linksys Wireless-G WRT54G Router
How do i connect up my router
To physically install the router
Step 1: Connect the power adapter Connect the power adapter to the router and plug it into an electrical outlet not controlled by a wall switch.
Step 2: Connect the router to the computer Disconnect the ethernet cable that is connecting the broadband modem to the network adapter in the computer. Connect the ethernet adapter in the computer to one of the LAN ports on the router.
Step 3: Connect the router to the modem Connect the ethernet port on your broadband modem to the WAN port on the router.
Step 4: Check link lights and connections
Check the front of the router to make sure the Power, WAN and LAN1 lights are on.
Jun 29, 2008 | Computers & Internet
Linksys WRT300N Wireless Router Logo
53 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
