Question about Linksys Wireless-G Broadband Router
Limited or no network connection
I have had a problem with my router from the word go, it keeps coming off the network, now my computer is telling me that i have limited or no network connectivity. please help i'm getting a bit sick and tired of ringing them with the same problem.
  • timebomb53 Nov 04, 2008
    I've had the same problem as above, and I tried your manual ipconfig trick with no results. Whenever I try to enable DHCP again it goes back to 169.254.13.154 as the auto-assigned Host IP and Gateway. Any other suggestions?
    Novelist:
    Scholar:
  • 136 Answers
Looks like the dhcp is your problem.
the error is telling you that its an internal network providing limited access.
go to run cmd then in the dos prompt type in ipconfig /all
see your network card's ip address. if its 169.x.x.x then thats the problem..u are not getting the ip address from your computer.
go to your network connections right click the network card then go properties in the tcp/ip area assign yourself a manual ip address of 192.168.1.xx
the xx is a number that u like 2 digits only but it can't be 1
your default gateway is your router so give it 192.168.1.1
this should solve ur problem
good luck
smeags
Posted on Jan 20, 2008
Linksys E1000 Wireless Router limited or no connectivity
What is the operating system on your computer?
Are you trying to connect to the wireless network?
on Windows XP computer you will get this message when the computer is not able to connect to the wireless network.
There are 2 reasons. You might have entered incorrect password or your computer is not getting IP address.
Read Limited or no connectivity
Oct 03, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 | Computers & Internet
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
One of my computers wont connect to internet keeps saying limited acsess other computers are working fine
It means there is issue of tcp ip address. Limited connectivity means network adapter tcp ip not correct or not getting ip from DHCP server. For that set static ip in network adapter tcp ip property ac your local network range. Let me know if you need further assistance. Thanks for using FixYa.
May 25, 2011 | Computers & Internet
The wireless computers on the network are working. The computer that is wired to the router keeps giving the message Cannot renew IP address. The icon shows limited or no connectivity
reset the router if not change the network cable. if it does not fix the problem you need to call your internet provides be cous my be need to configure the settings from router
Nov 22, 2010 | 2wire 2700HG-B Router (2700HGB)
My wireless keeps saying limited access and connected to unidentified network. When i trouble shoot it takes me the security settings where i have a choice of no authentication (open) shared wps2-personal...
Are you sure you aren't connecting to another network by accident?
Could just unplug your router, and check to see if you are still connecting to something.
Otherwise it could be the router needs rebooted, or you need to reconfigure the security on it.
What kind of device are you connecting from... phone or computer?
Oct 03, 2017 | Computers & Internet
My netgear usb connects to my wireless belkin..but no internet ?
this message comes when your computer is not getting the IP address from the router.
There are possible reasons for that.
1. DHCP on the router may be disabled.
2. If your network is secured , then you might not be typing the correct network key.
In both the cases , you will need to check the settings of the router.
You will need to access the router set up.
Click Here for more info about router settings
Nov 24, 2009 | Computers & Internet
I have installed the ruter and the adapter on another computer so I can connect wireless to the router but the adapter keeps saying it has limited or no connectivity but the strength is good. This has been...
There must be security on the wireless network and you might be typing the wrong password of the wireless network .
Or your computer is not getting IP address from the router.
First Check the wireless network key or the passphrse.
Click Here for more info about networking
Oct 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Connected with limited access
This actually sounds like the device is not getting proper DHCP settings.
First of all, power cycle the router, and reboot the computer to make sure a fresh connection from both devices is achieved.
If the issue persists, check to make sure the computer does not have any static IP settings stored in the adapter.
The following steps will tell you how to do so:
-Start
-Control Panel
-In Classic View, select network connections
or
-In Category View, select Network and Internet connections, then select network connections
- Right click the appropiate network adapter (Local Area Connection, for cabled connections, wireless for wireless connections)
- Select Properties
- in the "This connection uses the following items:" Box select the "Internet Protocol (TCP/IP)" (making sure to keep the checkbox selected (selecting the name helps) then click properties.
- If obtain an IP address automatically is selected (and the boxes below are grey), and Obtain DNS Server address automatically (again grey boxes below) are selected then something else may be happening, which will require more advanced steps.
If the boxes are not grey, then you may have incorrect settings, select the appropriate radio boxes (listed above) to make the boxes greyed out, and that may resolve your issue.
Feb 26, 2009 | Belkin (F5D7230-4) Router (587009)
I have a Lenovo Ideapad S10 and it will not connect with the desktop PC. It keeps telling me I have limited or no connectivity. It also tells me the network did not assign a network address to the...
It needs an IP address. A router hands out IP addresses using DHCP in most default settings. Your computer has to be set to "Obtain an IP address automatically: and "Obtain DNS server address automatically" in (TCP/IP) Properties of LAN Properties for your Device name. You can also use hardcoded IP addresses. It's pretty complicated.
Dec 26, 2008 | Computers & Internet
Linksys Wireless-G Broadband Router Logo
148 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
