It takes continous printing of the same document
Reset the last command from the printer folder.... you have command a multiple printing on a document by mistake ....when the printing wizard ..came to the point where it let you choose the no of copies ...it was enough to press 2 zeroes when the mouse was pointing ...and it will not stop ..until will to all 100 ..:D better just reinstall the driver ..
so disconnect the machine ...go to add remove programs ... remove the program with the printer name ... than to be sure go to C drive ...on program files ..and remove the folder with the same name ...( sometimes the printer has a name and the folder its named by the manufacturer ) in this way you removed any anterior commands ( tasks) and any trace of it ...
than just insert the disc ....and plug the printer and let it install auto ..or install it manually if you think you know how ....usually when you plug it ..it appears the wizard and ask for the disk ...with the driver ...
