Question about Epson Stylus CX3200 All-In-One InkJet Printer
EPSON STYLUS CX3200 PRINTER
ITS NOT ACCEPTING THE COULOUR CARTRIDGE AND NOT PRINTING
  • Epson Master
  • 691 Answers
Then either the cartridge is faulty (quite likely if it is a refilled compatible) or the head has a fault.
Try another new genuine cart and expect the problem will clear.
Posted on Feb 17, 2008
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson stylus cx4300 series is not printing because there's no black ink but colored ink cartridge are almost full.
Hi guys i need help
i have problem printing to the epson cx4300,it s not printing black,i have change the ink tested it,made sho that the ink is not dry,reconfigured my computer but still,uninstall drivers reinstall on the computer.it jus not printing,what is the problem.
please help
Dec 05, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Need to change ink cartridge on a epson stylus sx 215
remove the ink, then turn on the printer, then hold the power button in 2 seconds, wait for the ink cartridge to go to the center, then change the cartridge
Oct 26, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Not printing clearly even after cleaning the head
Are you using refill? Or original cartridge? But it seems that imposible to happen on original cartridge, Try using the Printer head decloging solution, Watch this video http://www.youtube.com/watch?v=Ztl_SiUdPLw&feature=fvw
Hope this helps
Oct 21, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Won,t print
Take it back and buy an Epson brand.
Feb 05, 2009 | Epson Stylus CX3200 All-In-One InkJet...
I am printing from my epson stylus cx3200 i have just put in a new black ink and it is not printing
a) did u remember to remove the sensor cover tape from the cartridge b4 u installed it? and also the tape covering the hole where the ink draws from? if u have... try banging it on a desk or something to loosen up the ink a bit... this might help moisten things up, make it work. also make sure u have the right drivers, for that product AND ur OS i.e. windows xp or vista, and the right version of that OS, 32 or 64 bit
Dec 16, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson cx3200
EPSON Stylus CX-3100 Printer Driver for Windows 2000/XP
Download File Name : CX3100_win2000_XP.zip (4.4 MB)
Note - epson Stylus cx 3100 is similar to cx 3200.
Mar 17, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
107 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
