Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Attachment will not aspire - Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
b
Posted on Sep 29, 2010
I have a Braun KS32 Kitchen Machine with several attachments. Two attachments are missing instruction manual/uses: KS 32, Shredder/Slicer Attachment, and KGZ 2 Meat Grinder Attachment. Is it possible...
I have a braun machine KM32 CDN 120 Vac/3A/60h2, No. 4122912 and I was wondering if there is an attachment for a pasta maker for this machine. If there is how much is it and can I get one in Saskatoon SK Canada?
Nov 29, 2010 | Vacuums
How do i release. the hose to attach the attachments?
Near the carpet attachment, on the lefthand side of the hose, there should be a release mechanism that you simply push in with your foot while pulling on the hose/wand. Once the carpet attachment is removed, you can connect the other attachments. Push the release toward the hose.
Nov 04, 2010 | Kenmore 23313 Whispertone Bagged Canister...
How do you put on the attachment hose to clean stairs
Assuming the rug nozzle is currently attached, lift up the headlight hood. Twist the belt lifter (black plastic square) on the rug nozzle counterclockwise to remove the belt tension. Then pull the accessory lock up until the rug nozzle comes loose of the Power Plant. You will notice two hinges at the bottom that hook on the the Power Plant's attaching bar. Gently lift up the rug nozzle to unhook it from the attaching bar.
Now your Kirby is naked. You will notice two small hooks on the hose attachment--hook them over the attaching bar, place the end of the hose attachment firmly against the Power Plant, then push the accessory lock down to clamp the hose in place.
You are now ready to use your Kirby with the hose attachment.
May 20, 2010 | Kirby Heritage II Vacuum
Cannot remove attachment from proteam super quarter vac
Greetings, The ProTeam backpacks us a 1.5" hose and attachments. The way that the floor tool is removed is by unscrewing the collar of the attachment. Simply turn counter clockwise on the the part of the attachment that is secured to the wand and doesn't rotate. This should loosen the floor attachment, and you may then pull it off. The other floor attachment can be fitted, and then screwed on by rotating the opposite way, clockwise which will secure the attachment to the wand. I really hope that this information was helpful to you. If you ever need parts or supplies for your ProTeam, please be sure to check out GoVacuum dot com. If this was helpful to you, please rate the repair as helpful by clicking the 4 Thumbs up icons in the top part of the repair. Thank you very much, Chris J. GoVacuum
Mar 23, 2010 | Vacuums
ATTACH UPHOLSTERY ATTACHMENT
What is the Model Number of the Steam Vac?
It should be something like F58XX-XXX
Sep 29, 2009 | Vacuums
How to attach the upholstry cleaners
Easliy download the manual at Hoover.com.
The hose attached in the front of the unit on the clear front panel. Lift up the center cap and attached the hose. Then attache the supply hose to the side of steam vac for your solution.
May 25, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Putting on the attachments for the kirby g4
Well... some attachments you may end up not using at all... some of them are very handy...
I have online manual for attachments HERE
Good Luck
Mar 02, 2009 | Kirby G4 Bagged Upright Vacuum
I have the same problem with intermitant power, however, it does not make sense that the problem is in the upper powerhead (which is what a repair guy told me) because-- when I use the other attachements...
You can test the auxiliary plug to the roller/beater attachment with a volt meter if you know how and take precautions. Check for 115-120 volts at the beater/roller attachment plug. If voltage is there and the beater/roller doesn't run, the problem is with the attachment. If not, then the problem is in the power switch or somewhere else that feeds power to the lower attachment.
Feb 23, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
BISSELL PROHEAT SHAMPOOER WITH SCOTCHGUARD ATTACHMENT
If one attachment works ok, but another doesn't, then there must be a problem with the attachment and will have to be replaced.
Nov 25, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
