Question about Whirlpool GHW9200L Front Load Washer
GHW9100LW is the model will not drain, F2 and
GHW9100LW is the model will not drain, F2 and sud error code. removed large filter and cleaned out drain, could not feel any debris in pump impeller area. put back together, same thing, ohmmed out pump motor, showed infinity.
any suggestins, i am fresh out of ideas.
thanks mike
  • missingvoree Dec 11, 2009
    further diagnoses indicates the pump motor is clog free. removed it completely from machine, no socks nothing inside, impeller is free of debris as well.
    the pump ohms out at 15.9 ohms
    the black wire going to the pump motor shows 39.5 volts.
    still does not drain, have to clean out with shop vac each time. could this problem be a hot or cold water solenoid, or a sudsing switch or ?
    ohm out the pressure swich perhaps?
    it appears i will have to replace the bellows around the door. it is leaking as well.
    any suggestions would be appreciated.
  • 88 Answers
'Infinity' as ohms reading for pump means it's broken - there is a break in windings.
You'll need a new pump, I think.
Posted on Jan 31, 2018
2 Suggested Answers
  • 1417 Answers
SOURCE: WASHER DOES NOT DO FINAL DRAIN AND SPIN. USUALLY
Hello.
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work
down to the more difficult causes.
BELOW ARE TOOLS AND INSTRUCTION THAT WILL HELP IN SOLVING THE PROBLEM.
1 A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Thanks.
Posted on Nov 08, 2011
Gives code f02 and sud
The F2 error codes means LONG DRAIN TIME and the suds code the washer detected water in tub after normal alloted drain time...so basically the F2&SUDS means the same thing. A lot of times when it does not drain fast enough,its caused by a blocked filter on the pump being biult up with debris. This tip i wrote will show ya how to clean the pump filter.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Sep 21, 2011 | Maytag EPIC MFW9700S Front Load Washer
It won't drain or sometimes it drains slow.The F2 code will appear or the Suds code will show up.
The drain filter is blocked and needs to be cleaned. Unplug the machine or disconnect power then remove the three screws attaching the bottom of the lower front access panel and pull the panel down and off. Once the panel is off, you'll find the drain filter attached to the drain pump.
Place a container or a piece of towel
underneath the filter to catch spillage. You may need to drain the water from the machine by putting the end of the drain hose over a container on the floor. Position the container as low as possible to extract as much water.
Remove the filter by turning the knob counterclockwise and clean it.
Also take a moment to inspect the drain pump impeller by reaching it in with your finger and turning it. The impeller should turn freely. Otherwise, replace the drain pump.
Click on the link below if the problem persists after cleaning the filter.
Kenmore Elite and Whirlpool Duet Sud/F02 Error Code
Jul 20, 2011 | Washing Machines
Code 2f
Hello & Welcome to FixYa
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display suds and then F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Duet front loader.. once it starts washing it stops and an error f2 code comes up and it will not complete the washer the clothes are left wet. if i move to spin only it still wont same code comes up
Kevin
Jun 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Won't finish cycle 21 F- flashing on panel
F21 error code is indicating that it is taking too long to drain water.
Your details indicate that you are using too much detergent or the wrong type of detergent and causing excessive suds. The drain pump can not pump suds out. The washer requires HE (High Efficiency) detergent formulated for front loading washers.
Cut back on the detergent and it will most likely operate correctly.
NOTES:
* After four (4) minutes the "Sd" error will be displayed, and then four (4) minutes later the "F21" error code will be displayed.
* Press STOP two (2) times to clear the display.
Possible Causes:
- Using too much High Efficiency (HE) detergent and causing too much suds.
- Using NON-HE detergent causing too much suds.
- Kink in drain hose
- Debris or foreign objects in drain pump filter.
The drain filter is located behind the lower access panel.
NOTE: Disconnect the power cord before removing the lower access panel and cleaning out the drain pump filter.
Remove the two screws (key#21) securing access panel. The filter cap (key#14) is removed by turning it counter clockwise. NOTE: Be sure that all the water has pump out before removing the cap. Have some large towels handy because there will be water coming out the filter/pump once you remove the cap. Check and clean the filter and remember to reduce the amount of detergent and the washer should perform as designed
Hope helps (remember to rate and comment this free answer)..
Jun 10, 2011 | Kenmore HE2 Plus Front Load Washer
I have an error code F or F2...?? that comes up when there is only 2 minutes left.
Hello, Welcome to FixYa.
The F2 error code explained below which can also manifest as F21, sd, or a Suds error applies to all washers manufactured by Whirlpool which include, many Kenmore, Maytag, and of course Whirlpool.
The F2 is an error code typically associated with an obstructed drain pump, pump filter or the back-flow ball in the sump bellows.
**Unplug the washer from the wall before performing any service suggested here at FixYa, unless otherwise stated...safety first**
Here's what to do and check for and possible resolve it...
1) Remove the service panel at the bottom of your washer, i.e.
2) Once removed you'll be greeted by the pump with the removable filter...this is where most obstructions occur, i.e. (some differences may be obvious but same procedure apply)
If the washer hasn't drained and still has items in it or water, it may be a good time to have some towels close by or empty the machine with a wet-dry shop vac...unless you're fortunate to be close to a floor drain.
3) Turn the removable filter counter-clockwise to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removable filter.
4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to verify the unit drains and spins now.
5) If all appears OK after your efforts, well your efforts paid off...pat yourself on the back. You just saved yourself potentially a couple hundred bucks !
**NOTE: if this still fails to remedy the error code or if it returns immediately during the next drain you may require a pump or you'll need to check the hose/rubber bellows from pump to tub...back-flow ball...as I alluded to previously for other obstructions ).
To inspect the back-flow ball...there is a large clamp which secures it to the tub, but if you remove it to clean out all the dirt built up inside, make sure you get it good and secure when putting it back.**
Once the clamp is pulled back/loose you can pull the bellows from the tub to inspect for obstructions or "gunk" built up causing the ball to stick. i.e.
If a pump is required, you can check with your specific model number for available pumps at "searspartsdirect.com" or "repairclinic.com" to name a couple.
Thanks for choosing FixYa. Please take a moment to rate the solution and a short testimony provided for you here today. Good luck
Regards,
Macmarkus :)
Apr 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore elite mod 42832 has a error code f2 does not drain or spin
Hi
Error F2 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 23, 2011 | Kenmore HE2 Plus Front Load Washer
The washer is giving a code of "F2" & not draining properly.. any idea?
This code indicates a pump issue. First, remove and clean the filter. Then you need to check out the pump.
Whirlpool F2 = Long Drain error code.
If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed.
Press, PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the "F2 error code" will be displayed.
Potential Causes:
(1) Check the drain hose and make sure it is not plugged or kinked.
(2) Check the electrical connections at the pump and make sure the pump is running.
(3) Check the drain pump filter for foreign objects.
Mar 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool GHW9100LW started making a strange sound and not wanting to finish the spin cycle about a month ago. up until now it will finish off and on. I cleaned out the thing that twists off in front...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9200L Front Load Washer Logo
182 people viewed this question
Sal De
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
