Question about Microsoft Windows Vista Home Premium Edition for PC
I had my laptop fixed 6 months ago and i was told i no longer have safe mode. I recently made a mistake and set my computer to start in safe mode. Now i can't get it back to normal mode. The screen says safe mode up the top and down the bottom but there is no start button and i can't left or right click anything. I was able to hit f1 during start up and perform a system restore but it still only stasts in safe mode. i have vista on a dell laptop.
    Guru:
  • 1,481 Answers
Who ever fixed your laptop must has done some thing that has led you to this issue....it's just not possible that you wont have Safe Mode, it's one of the inbuilt safety system of Windows OS....press F8 to get into the option to go to Safe Mode or.....Normal mode of operation.....
You need to press F8 before the Windows screen appears...after you switch ON your laptop.
Posted on Dec 10, 2009
Kdcom.dll status 0xc0000221
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a serviceyou can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
if this hails to fix the problem
http://support.microsoft.com/kb/307545/
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
Select safe mode with networking to download
you could select the option start with command prompt you should be in DOS mode black screen
typechkdsk/r/f which will scan for and attempt recovery any bad sectors and automatically fix any corrupt files on your hard drive
you should have no input while chkdsk utility is in progress any input might further damage your hard drive
or you could use another operating system
http://www.ubuntu.com/download/ubuntu/download
which can repair what windows has ruined and is unable to fix fix the problem
Feb 20, 2014 | Acer Aspire One Netbook
What do I do?!
Try this:
Reboot your PC into Safe Mode With Networking:
Start your computer in safe mode
Safe mode starts Windows with a limited set of files and drivers. Startup programs don't run in safe mode, and only the basic drivers needed to start Windows are installed. For more information, see What is safe mode?
Safe mode is useful for troubleshooting problems with programs and drivers that might not start correctly or that might prevent Windows from starting correctly. If a problem doesn't reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes. If a recently installed program, device, or driver prevents Windows from running correctly, you can start your computer in safe mode and then remove the program that's causing the problem. For more information about troubleshooting problems in safe mode, see Diagnostic tools to use in safe mode.
  1. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer.
    Click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, click the arrow next to the Shut Down button eb058ccf-b21e-4dfe-9bb7-1ad6c83b705c_47.jpg, and then click Restart.
  2. Do one of the following:
    • If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you'll need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
    • If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to start in safe mode, and then press F8.
  3. On the Advanced Boot Options screen, use the arrow keys to highlight the safe mode option you want, and then press Enter. For more information about options, see Advanced startup options (including safe mode).
  4. Log on to your computer with a user account that has administrator rights.
When your computer is in safe mode, you'll see the words Safe Mode in the corners of your monitor. To exit safe mode, restart your computer and let Windows start normally.
Once in Safe Mode With Networking
Click on the two links below and go to the download now tab. Save Rkill and Malwarebytes to the desktop.
First run Rkill then Malwarebytes.
http://www.bleepingcomputer.com/download/rkill/
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
Aug 14, 2012 | Acer Computers & Internet
I have a used Dell Inspiron 8200, it has not been cleaned out but it worked fine when I got it, I ran a System Restore and used it until about four days ago when the computer froze. I shut it off, (did not...
Severe corruption. Since you can no longer boot in any way in it it's going to be extremely hard to fix it. Better just reinstall Windows from scratch. Use the recovery cd that should have come with the laptop. If you don't have it then just use a disk borrowed from a friend and the key on the label.
Jun 14, 2011 | Dell Inspiron 8200 Notebook
Switched on my laptop this morning,and i noticed that it took unusually longer to start.Then the black and white screen appeared-it said: "WINDOWS ERROR RECOVERY windows failed to start.A recent...
Hi it may be virus issue. i suggest you to try with last known good configuration so that it will take your computer to last good working state. for that tab F9(Function key) continously immediately once you turn on your computer until you get the advanced option on your screen. highlight last known good configuration and hit enter and it will boot in that mode once you get the main sceen CLICK start - > all programs- > Accessories - > system tools -> system restore and wizard will open and select Restore my computer to an earlier time click next next finish to set your computer to last good working condition. If that doesnt work reinsatll the OS
Dec 26, 2010 | Acer Aspire 4730-4947 Notebook
Bought Dell 13Z one month ago. screen shows faded colour . what may be the problem?
Do you see this issue in safe mode?
Reasons to tell you about safe mode: Users who may not be able to boot into normal mode, or are not able to troubleshoot their computer properly, may need to boot into Safe Mode bypassing normal windows settings and startup programs and allowing the user to fix their computer.
Aug 31, 2010 | Computers & Internet
Charger Mistake: Computer Frozen
While the computer boots up, start hitting the F8 key on your laptop and try to boot into Safe Mode, try System Restore to restore computer to a earlier time.
May 28, 2010 | ASUS X83Vm-X1 Notebook
Problem not fix
Boot the machine in safe mode, then reboot as normal, if the problem persists after reboot did you
install software proir to this try reinstall. Use anti virus and spyware malware scans etc.
Running in safe mode, is exactly that safe while most problems exist in OS.
Let me know how you get on.
Jun 10, 2009 | Dell Inspiron 6000 Notebook
Sony vaio not loading windos
Try booting XP with the installation CD & use the recovery console to boot the laptop.
From the Setup CD-ROM
Insert the Setup compact disc (CD) and restart the computer. If prompted, select any options required to boot from the CD.
When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R. If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console. When prompted, type the Administrator password. At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command.
To exit the Recovery Console and restart the computer, type exit.
Dec 10, 2008 | Sony VAIO PCV-V210P PC Desktop
Laptop doesnt starts
reboot the computer and keep tapping on f 8
select safe mode
when ur computer is on desktop of safe mode
go to run<type msconfig<a new win will *** up sys config
look at the top of the same window ull see start up clk on tht tab
down at teh bottom ull c disable all clk on tht
clk apply then ok
it will ask to reboot
ur computer will reboot
now when u get the blue screen start tapping on space bar
ur comptuer will boot
once ur on desktop ull get another window
on tht window ull c a small check box check tht it will sya dont show this mesg again
and ur done
May 19, 2008 | Computers & Internet
Microsoft Windows Vista Home Premium Edition for PC Logo
65 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
