Question about InFocus ScreenPlay 5700 Multimedia Projector
Hi, My Infocus screenplay 5700 gave a message to change lamp, but after turn it off and then on, i kept working good, after an hour suddenly turned the lamp off but the fans kept working. Now when I try to turn it on, it makes a "click" noise about 2 seconds each but the lamp never turns on. It should be a Lamp issue, Should I to replace it? I don't know how many hour has on it, since I buy it in ebay it came with "7 hours" I guess it was reseted without changing the lamp. Thanks
  • 2,237 Answers
The lamps are good for about 2000 hours. but it sounds like it's time to get a new lamp. but after you put it in, go into the menu and reset the lamp timer.
Posted on Dec 11, 2009
Infocus screenplay 5700 I've had this product for
Hi!
Just had the same problem and I want to sincerely thanks rey francis basa !
I went down and changed C16 as you said. Exactly where you said.
Works perfectly now!
Jan 05, 2013 | Office Equipment & Supplies
Blinking red light. projector won't turn on
The lamp life may have exceeded its safe limit, check your manual as you may have to press a specific button on the unit/remote for a length of time to reset it.
Good luck
Aug 03, 2011 | InFocus ScreenPlay 5700 Multimedia...
Hi, it doesn't power up when I plug it in.
Sounds like the power supply has gone bad. If you interested in getting it repaired you can find me on ebay. Gtitubro is my screenname.
May 22, 2010 | InFocus ScreenPlay 5700 Multimedia...
InFocus ScreenPlay 5700, ceiling mount, installed new 4 - 5 years ago, was working fine, now won't turn on. Gave me a high-speed flicker on the power button, but now nothing, even when plugged into a...
Most probable cause is a faulty power supply. The capacitors inside tend to overheat and burn out. They can be tested with ohmmeter for 25-30 ohms if you can get power supply open. Most people change entire supply. You can test power from supply to main circuit board with a voltmeter.
If you have a fuse, check to see if it is good. It will probably be next to power supply.
Last possible cause could be faulty control board usually due to faulty capacitors or resistors.
Oct 25, 2009 | InFocus ScreenPlay 5700 Multimedia...
Bulb is working fine, how do i get rid of replace lamp on the screen?
go into the menu and select settings. in there there should be an option for lamp hour (or timer) reset. select and chose yes.
Oct 17, 2009 | InFocus ScreenPlay 5700 Multimedia...
My Infocus 4805 suddenly blackout
First check what is the lamp you using please use lamps recomended by SONY only. That lamps might run up to 2000 hours so.......try checking your lamps and let me know.
Jan 26, 2009 | InFocus ScreenPlay 4805 Multimedia...
Screenplay 5700
Because these units have dangerous high voltages inside, there are a number of safety interlocks throughout. Take out the lamp and reseat it. Also, make sure that the access door is installed correctly and securely. Both have interlocks that will prevent a poiwer up is not installed correctly.
If this is not the case for you, please update this and we'll look for other causes.
Thanks,
Dan
Jan 05, 2009 | InFocus ScreenPlay 5700 Multimedia...
Lamp won't stay lit
I've got the same problem, I'm wondering if it has to do with some sort of auto shut off kicking in due to overheating or something, I was gonna try replacing the fan to see if it's something to do with that
Jul 07, 2008 | InFocus ScreenPlay 5700 Multimedia...
InFocus ScreenPlay 5700 Multimedia Projector Logo
307 people viewed this question
Top InFocus Office Equipment & Supplies Experts
neOen
Level 1 Expert
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
