Question about RCA DRC8060N DVD Recorder
Cannot turn on power untill i disconnect power and reconnect
My hp photoshop 3210 printer is showing error 0xc18a0206 message when I changed the cartridges.
Step 2: Reset the printer.
In some cases, removing the ink cartridges and resetting the printer can clear the error message.
  • Turn on the printer.
  • Wait until the printer is idle and silent before you continue.
  • Disconnect the USB cable from the rear of the printer. If your printer has a network or wireless connection, leave your printer connected to the network.
  • Remove the ink cartridges from the printer.
  • With the printer turned on, disconnect the power cord from the rear of the printer and from the wall outlet or power strip.
  • Wait at least 60 seconds.
  • Plug the power cord back into the wall outlet.
  • NOTE: HP recommends connecting the printer power cord directly to a wall outlet.
  • Reconnect the power cord to the rear of the printer.
  • Turn on the printer, if it does not automatically turn on.
    The printer might go through a warm-up period. The printer lights might flash, and the carriage might move.
  • Wait until the warm-up period finishes and your printer is idle and silent before you proceed.
  • Reinsert the ink cartridges, and then close the ink cartridge access door.
  • If you receive a prompt to print a calibration page, do so.
  • If you disconnected the USB cable, reconnect it to the rear of the printer.
  • Try to print.
Jul 19, 2018 | HP Office Equipment & Supplies
Show error
E indicates an Error condition.
1.Without turning off the product, disconnect the USB cable from the rear of the product.
NOTE:The USB cable connects to the port on the rear of the product. The port is labeled with the USB icon ( ). If your printer has a network or wireless connection, ignore this step.
Figure 1: Example USB connection (your product might not look exactly the same as this example)
2.Remove the cartridges from the product.
3.Wait until a message to insert the cartridges displays. If you do not see a message within a few minutes, skip to the next step.
NOTE:If your printer does not have a display, wait until the cartridge lights blink. If the cartridge lights do not blink within a few minutes, skip to the next step.
4.Disconnect the power cord from the back of the product.
5.Wait 60 seconds.
6.Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7.Reinsert the cartridges, and then close any open doors on the product.
8.If you receive a prompt to print a calibration page, do so.
9.If you disconnected the USB cable, reconnect it to the rear of the product.
10. Try printing again.
5.Wait 60 seconds.
If that doesn't work you can log on to HP.com/Support and Drivers.
Find your device and search the error codes listed.
You can also download a real good Utility, HP Print and Scan Doctor.
Apr 27, 2012 | HP DeskJet F380 All-In-One Printer
I refill the cartridge of my canon mp496 printer.I print images and everithing is ok but the ink lamps are orange .I don't know what to do ! Please ,help me !!
One of these reset methods should fix the problem
This is the procedure I used for an MP470. It is basically a modified version of that previously posted for the MP460.
1. Disconnect the power cable.
2. Hold down "On/Off" button.
3. Reconnect the power cable.
4. With the power button still down, press the "Stop/Reset" button twice.
5. Release the "On/Off" button.
6. The printer is now in "factory mode".
- wait until "idle" is displayed.
7. Press the right arrow button (next to the "OK" button) repeatedly until "Shipping Mode 3" is displayed.
8. Press the "OK" Button
9. Wait until "Without Cleaning" is displayed and then presss the "Stop/Reset" button once. (I pressed the ok button after Stop/Reset button on my MP470).
10. A test page should print.
11. Open the cover.
- the cartridges should position themselves at the far left - the cartridge removal location.
12. Disconnect the power cable.
13. Remove both cartridges.
14. Close the cover.
15. Reconnect the power cable.
16. Press the "On/Off" button once.
17. Wait until a "Replace Cartridges" message is displayed.
- insert cartridges.
18. Wait until the printer is operating in its normal mode. The display shows the normal start menu (ie: Copy).
The ink levels have been reset.
- check by going to printer>properties>maintenance>view printer status
this is what i had to do to get it to work with canon mp460
2. Hold down power button
4. With the power button still down, press twice the "Cancel/Stop" red button
5. Release the power button
6. The printer is now in factory mode...(wait about 30 seconds until it says "idle")
7. Press the down arrow (next to the "OK" button) until it says "Shipping Mode 1"
9. Now with it displaying "Without Cleaning" press the power button
11. Now open cover
12. Disconnect the power again
13. Take both cartridges out like normal
14. Close cover
15. Reconnect power cable
16. Press power button
17. Replace cartridges
MP-160 is different from MX300 so I tried my best with it...
The main solution is to reset the entire printer:
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The printes turns into a kind of factory mode...(wait for about 10 seconds, utils it says "Idle")
6. Press the ">" (next to the "OK" button) once."Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print..
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
Jul 01, 2011 | Office Equipment & Supplies
Replaced ink compatable cartridges in my cannon pixma 350 and now its telling me to replace them cause the ink is empty Help
This will reset your cartridges to full settings. I have found these resets to work on many Canon models. Try the top one first.
11. Open the cover.
11. Now open cover
14. Close cover
Mar 27, 2011 | Canon PIXMA MX350 Wireless All-in-One...
Canon np258 cant operate after refill
You may need to reset the ink counter. Try one of the following solutions.
THis is the procedure I used for an MP470. It is basically a modified version of that previously posted for the MP460.
11. Open the cover.
11. Now open cover
14. Close cover
Mar 27, 2011 | Canon Office Equipment & Supplies
How can i reset the Ink Level on Canon MP240
Here are three methods that have worked on Canon printers. Have no fear. None of these will cause damage if they do not reset the ink counter. Once reset you will have to monitor the cartridges by weight, as the system will always show them to be full.
The first is basically a modified version posted for the MP460.
9. Wait until "Without Cleaning" is displayed and then presss the "Stop/Reset" button once. (I pressed the ok button after Stop/Reset button on my MP470 to get the test sheet).
11. Open the cover.
11. Now open cover
14. Close cover
Mar 09, 2011 | Canon PIXMA MP240 All-In-One InkJet...
WHEN I PRESS POWER BUTTON NOTHING HAPPENS
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard. GOOD Luck.!!
Aug 27, 2009 | Insignia D400a PC Desktop
How do you reset the blinking protect banner on the ag-v8520?
Try disconnecting the power cord then disconnect the speakers. Plug the power cord back in then hold in the power button until the unit "clicks." Then disconnect the power cord and reconnect the speakers, then the power cord and turn it back on.
Jun 13, 2009 | Teac AG-V8060 Receiver
Can use the phone it is only reading searching on the display.
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances
Apr 07, 2009 | Uniden DECT 6.0 Cordless Phone ID
Electrical fault in a '99 2.5 20V V70.
hi volvo
sounds like an poor earthing problem. in dc circuits offs go to ground, try cleaning up all earths and also look for any lives that may be shorting to the body or chassis
Oct 27, 2008 | 1998 Volvo V70
RCA DRC8060N DVD Recorder Logo
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
