Question about HP Media Center M1050Y PC Desktop
Every time i turm my computer on the monitor comes on and then says going to sleep the computer shuts down will not stay on. I can"t do anything, it keeps shutting down and the monitor shuts down.
  • 478 Answers
This is a computer problem not a monitor problem whens the last time you cleaned out the computer as in air blasted to clean out any dust if the power supply over heats this would cause a shut down the other thing would be a problem with the mother board open case look at the stuff inside and see whats dirty cpu, power supply , motherboard dust a #1 killer of motherboards
Posted on Dec 10, 2009
SOURCE:
My monitor won't come out of sleep mode
when the computer enter the sleep mode, it is possible that the computer remove the check mark from this output activation.
When you have multiple ouptut like a internal LCD and output on a monitor, when going into sleep then waked up, laptop reactivate the internal LCD without reactivated the secondary monitor.
you could need to go in desktop property and reactivate the secondary monitor with the check mark listed : Activate.
If you only have one monitor but still a dual output card or two separate video card same thing can happend. try to connect the monitor on the second VGA or HDMI output and see if the video goes there.
then reactivate your secondary output and make it principal.
Does also happend when your computer is connected to a UPS power and your monitor is directly on the sector. (laptop issu also)
if a brief power outage arrive then the monitor shut down (no power) and the computer continu, as there is no monitor on the output any more Windows will automatically deactivate this monitor. when power goes back, this output is no longuer providing video. I suggest putting the monitor on a UPS as well.
Jan 03, 2014 | Westinghouse Electric L1916HW 19" Monitor
My HP 2009m goes into sleep mode & shuts down
hmmm is it your monitor going to sleep..or the machine? might the computer still be running?
if it's the computer go to power setting and change to your pref
Feb 15, 2010 | Computers & Internet
Every time I shut down my monitor stays on. How do i get it to shut off. It says monitor locked off . I always shut my computer off when I am done
Right-click on Desktop, go to "Properties."
From there you want to go to your power (or energy) settings. Here you should notice some settngs on your monitor and when it should sleep/shutdown.
Hope this helps!
Nov 10, 2009 | HP Computers & Internet
My computer keep shuting saying monitor going to
start button >settings >control panel > Power Option > set time for monitor to sleep if inactive...if you dont want the computer to sleep go up to the hibernate tab and uncheck it. If you want the computer to stay on regardless, move all drop down menus to "never" instead of a time.
Sep 01, 2009 | HP w1907 LCD Monitor
Monitor going right to sleep mode on start up
Sounds like a bad graphics card. Try using monitor wit another computer and see if the problem still exists. This rules out the display.
Jul 25, 2009 | HP w1907 LCD Monitor
Sceptre 20" Monitor will not stay on
First check the monitor sleep mode for your monitor in windows control panel, check that its not going into hibernation/stanby. if thats not it. and the monitor keeps shutting down. You may have to replace it newer models have more features and could be cheaper by saving you the hassel check newegg.com or orverstock.com
Jul 08, 2009 | Sceptre X7GNAGAV 17" LCD Monitor
Monitor willnot come out of sleep mode
turn off everything and restart computer in safe mode,do this by holding down f8 as you reboot,then go in your setting and remove time limit on sleep mode.
Apr 10, 2009 | HP w1907 LCD Monitor
Monitor shuts off
You can set your power management to ignore or control the time that your monitor, hard drive or other peripherals stay on in Control Panel or BIOS setup. It powers your monitor down to save the battery power so the computer itself does not shut down thereby losing data you may be working on. Familiarize yourself with the battery power length of time so you can determine whether this is normal or if you have a dying battery.
Oct 29, 2008 | IBM ThinkPad X60 Tablet PC
Monitor goes to sleep and won't wake up
Yeah, im not sure about how to fix the problem with it shutting down like that, but one option is to go under your control panel and taking off the sleep function, or putting it on a 4 hour timer so that doesnt go into sleep mode anymore. However, the problem is not your monitor but your computer. Id just take the sleep mode off, there is no need to have it on.
Dec 24, 2007 | Computers & Internet
Screen does not turn on
Sounds like the 90w power adaptor. This has happened to my 23" Apple monitor several times. (I'm on my third 90 watt "brick"!) It seems to happen after about one year of use. All you can do in the meantime is never shut down or let the monitor go to sleep.
Oct 29, 2007 | Apple Cinema Display 23" HD Monitor
HP Media Center M1050Y  PC Desktop Logo
168 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
