Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Panasonic PT-47WX53, Would replacing the convergence ICs STK392-110 incorrectly make it so that the tv would not turn on at all and not give a blink code?
  • Panasonic Master
  • 8,617 Answers
If the pins were bridged with solder it could blow the main fuse. I would check the fuse since a panasonic will always light the led if the fuse inst blown, another possibility would be the wires not seated properly especially the bridge connectors bewteen the boards.
Posted on Dec 10, 2009
I have a Panasonic Projection Monitor PT-47WX52C.When I turn on power it blinks 3 times .What do I have to do to repair it? Thanks Kathy
You will need to replace both convergence ICs and also possibly the associated low ohm resistors, since the 3 blinks is indicating that the convergence has failed. The PT47WX52 convergence repair kit is available from www.tvrepairworld.com which has the two ICs , heat sink paste, low ohm resistors and the CD with repair instructions.
Aug 22, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Tv blinks 3 times when trying to turn it on
Thats a convergence issue The PT53WX53 convergence repair kit from www.tvrepairworld.com should solve the issue. The kit contains both ICs the six resistors and the CD with detailed repair instructions.
Feb 26, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt-47wx53, no power, 3 blinks
3 blinks is indicating that the convergence has a problem The PT53WX53G convergence repair kit from www.tvrepairworld.com is the correct kit for your model. The kit contains the ICs, Resistors and the CD with repair instructions.
Feb 17, 2011 | Panasonic PT-47WX53 47" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47wx53 just shut off
Your convergence ICs have failed. Thats what causes the led to blink three times. The PT53WX53 convergence repair kit from www.tvrepairworld.com will usually repair that issue. The kit also contains the CD with detailed repair instructions.
Apr 01, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Green arc across bottom of tv,and a little purple.
Replace Both of your convergence ICs STKs, big black ICs.
Jun 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT 47WX53G does not turn on
If the indicator blinks three times its the error for the convergence ICs and resistors. You can get the right repair kit for your model at the following link which contains the Two ICs the 6 feed resistors and detailed step by step instructions with pictures.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Jun 10, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic 47wx53 covergence issues
Is the power indicator flashing three times? If so the Ics have shorted shutting the set down. You will need two STK392-110 convergence ICs. You can get replacement ICs at the following link with free installation instructions.
Aug 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt-47wx42f
Yes you can get replacement IC STK392-110 convergence ICs at the following link and they provide free instalation instructions with pictures. The Ics are located on the board on the left side attached to a large heatsink. You will need to replace both ICs heres the link.
May 19, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53
Your convergence ICs have failed thats what 3 blinks means. You will need both convergence ICs number STK392-110 you can get replacement ICs at this link and they provide free instalation instructions with pictures plus free on line tech support when you do the repair. here is the link.
Apr 30, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
151 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
