Question about Yamaha RX-V2090 Receiver
Can I use AppleTV as one of the inputs/sources? AppleTV needs RGB + the L/R audio channels.
  • djvisocky Dec 10, 2009
    Is the real answer to bite the bullet and swap out for a new A/V receiver that has the 4 in/1 out HDMI?
  • 35 Answers
Since AppleTV does not have a composite output, you'd have to either buy a converter (which is pretty expensive), or use a software modification (the latter probably voiding your warranty and/or violating your AppleTV's EULA).
(There's also a 'trick' that might work, but you need to buy/borrow a HDMI-DVI adapter somwhere first to complete the procedure.)
Hope this helped,
tS
Posted on Dec 10, 2009
Rgb internal wires which ones can u use to convert it into red, white and yello at other end for tv
RGB is a term that means the guns in the crt or other display are only driven by amplifiers for that color. So you have to have seperate signals and inputs for red,green and blue. Those come from the source in that method. They are then fed into the monitor for which each of those colors has its own channel and amplifier. If you dont have something that is supplying the RGB singals then it is of no use. The colors that you listed as red white and yellow are for COMPOSITE video with AUDIO. The yellow is the whole video signal and the red and white are stereo sound signals. No attempts at making that work will correct this unless you buy a converter.
May 14, 2014 | Philips 107E66 17" CRT Monitor
Color is not bright and looks green
This can be caused by an incorrect signal feeding your LCD. Normally, the green channel can carry the synchronizing signal along with the green part of the picture, but if it does not terminate properly it will make the whole picture green. The Syncmasters usually have Composite, RGB/Yr-y b-y, VGA and RF inputs. It could also be that the LCD is in RGB mode and you are feeding it Yr-y b-y. (or vice- versus). Make sure, if your using the component input, (RGB) that the source matches the LCD setting. RGB to RGB and Yr-y b-y to Yr-y b-y.
Jun 12, 2011 | Samsung SyncMaster 920NW Monitor
I have an RGB port on my visio, but my remote does not have any buttons to get to RGB mode, I have all the others like HDMI AV and component... How do i get to RGB mode if it is not on my remote. going to...
There is a video/input/source buuton on the side of tv. Push it and all inputs will be there use volume control to move the highlighted input when you get to the one you want push input/video/source it will change the channel
Dec 13, 2010 | Vizio Televison & Video
Get hd channels to work on panasonic tcp46c2?
your unit has the format of 1080i and you have an ATSC color wih 600HZ movement. HD has to be transmittet or HDMI inputs or RGB input or comp input. what are you using as a source?
Nov 04, 2010 | Panasonic TCP46C2 46 in Plasma TV
When hooking up r,g,b via component or vga input only the green channel displays.
reset the settings to factory default, then make sure if you are using component that the input selected is component and not vga. is the source rgb-yb?
Oct 03, 2009 | Christie Vivid Green Multimedia Projector
Connecting hd cable box to philips 60 rear projection
So, You have Five cable leads, The rgb get plugged into there corresponding colors and the other two are your Red and White Audio Input ------Correct? You do not use the in4, that is for a pc with horiz and vert sync. You use input 1 rgb and plug the red and white into the audio input.....your done!
Jun 06, 2009 | Philips 60PW9363 60" Rear Projection...
Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Jun 05, 2009 | Yamaha RX-V463 Receiver
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
No audio on vizio from source
there should not be a special setting that you need. When hooking the analog audio to the HDMI 2 input, it should read automatically. Note: The HDMI Input is for HD Video and will only support 640x480 at 60Hz from a PC. Use the RGB
PC input for a greater selection of PC formats.
Mar 23, 2008 | Vizio GV42L 42 in. LCD Television
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Yamaha RX-V2090 Receiver Logo
96 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
