Question about Cell Phones
I get emergency phone calls only message when inserting a t-mobile sim card in phone and trying to make phone calls from sciphone i68+ phone.
  • christhomp76 Dec 10, 2009
    I also need to know how to enter the codes to get into engineering mode to be able to unlock it to use a t-mobile sim card in it so I quit getting the emergency calls only message
    the sim works fine in the phone I received when I got service with T-Mobile, so don't buy that solution, sorry
  • Cell Phones Master
  • 4,924 Answers
Try another card ..this is the case only when the network is not available ....or incompatible ... if it doesn't say insert sim card ..means that it sees the sim and the contacts are ok ... so ...it might be a problem that your provider do not has covering in that zone ... and the phone only has access to the emergency (free ) services on that area ...this is an agreement between most networks to provide signal for whatever sim ...might be ...for calls like 911 ...etc...
Posted on Dec 10, 2009
    President:
  • 2,187 Answers
Check first if the phone is locked to a different phone network. With emergency calls only, you get the signal regardless if it is your network or not and allows you to access it but with limitations.
Sciphone on messaging it randomly presses letters
After inserting my SIM card, switching on the phone, "Insert SIM" is displayed and when trying to make a call, the message "Emergency call only" is displayed and
Dec 26, 2009 | Cell Phones
I have sciphone i68 but it does not work on 3g sim card what i should do?
You need to get a non-3g sim card, or get a 3g phone. Only the very latest Chinese mobile phones are 3g compliant, as China (apparently) does not have a 3g network as yet. Unfortunatley you can't modify the sim card or the phone to fix this problem.
Oct 20, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
How do i set up my sciphone i68+ with tmobile, i only have the sim card. And no manual, bought phone on ebay.It's saying emergency calls only
Ask at chinamanuals.com - send them your provider and country and they will come back with the settings. They also have a i68 manual for download (which includes some settings).
I searched and found that for you, pls leave a good rating.
Sep 28, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I68 sciphone can't recieve or make call or txt messages
try putting a 1 then area code then number.
(13215556666) this will also help with contacts names showing up when you rcv a call or text instead of just a number.
good luck
Jul 21, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Hi my sciphone has worked realy well for 3 weeks went to make a call the other morning and got the message your phone has a block on it emergancy calls only
This means that either the sim card has become dislodged (try re-inserting the sim card)
Alternatively, you will need to call your phone company to investigate. Have your sim card number and details ready, as they will probably need those details.
Best of luck
Jun 22, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
My sciphone i68 says emergency calls only when i try to use it
We had the same problem on both of our new sciphones. After long hours of research we finally found an easy solution to it so hope this helps.
1) Shut down your phone completely (you will know because a red sign will come up on your phone and you have to confirm that you are shutting it down).
2) Take our your battery and then your sim card
3) Make sure that your sim card is in the right way. (It has to be on the highest slot, not the one closest to the bottomof the phone, and the metal plates have to be facing down, or towards the phone).
4) Reinsert your battery and then start your phone up again
5) Go to restore factory settings and plug in the code 1122 when it asks for one. NOTE: Your phone will reboot, and when it turns on it should be okay.
We tried everything and this is the only thing that worked. We had t-mobile sim cards for both phones and it worked fine. Good luck!
-twins-
Jun 20, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
My sciphone i68 + doesn't read my sim card
flip the sim card over and cutoff the other sim slot example"if chip is face down make it face up" if that doesnt work switch to other sim slot and repeat the steps above if that doesnt work you can go to this link for more help
http://www.freewebs.com/sciphone/index.htm
Jun 10, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I just get sciphone i68, and i inserted the sim card [virgin mobile precisely] and the network bar shows 5 bar, which suppose to indicate that the network is ok, but if i try to call, it always indicated...
i have a i68 8g sciphone i put my sim card in the phone and it won't let me dial any numbers i mean i can dial but all it says is fail and it won't let me choose a network i have service but when i look at my main screen it says sims card 2 closed because i closed it but in slot one it says emergency how can i fix the problem please help!
Apr 10, 2009 | Dual Electronics CECT P168 Cellular Phone
Sci-phone applications
Most of these I68 SCIPHONES have the same imei number, and alot of these are being blocked. So dont be suprised if you wake up one morning and it doesnt work.
Mar 18, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Cell Phones Logo
80 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
