Question about Hitachi 60EX01B 60" Rear Projection Television
Is my TV HD Compatable?
I bought it in 2000 and it has the red, green, blue jacks for a component.
I don’t have the specs and would like to know if it would be worth it to get HD.
Is the resolution high enough?
Thanks, Ken
  • 301 Answers
The component jacks on the back might only be good enough to take a progressive input(480p) does you tv say anywhere on it HDTV? run a search of your model number through the internet and see if you can find any information or the user manual
Posted on Feb 22, 2008
How to you conect a kawasaki dvd to a hd tv
The best connection the kawasaki dvd has is a Component connection. This connection separates the Red, Green and Blue colour signals. Your HD TV should have a component input, just look for Red, Green and Blue RCA inputs labelled "Pr", "Pb", and "Y".
You don't need the red, green, and blue colored RCA's specifically for this type of connection. The colors are there to help make it easier to connect. You can use any coloured RCA as long as you have the Pr on the DVD connected to the Pr on the TV and likewise for the other two connections.
In addition to these connections you will need two more RCA's (Red and White) for the audio signal. You will need to connect the audio output of the DVD, to the audio input corresponding to the same Component Video input you are using for Video. This should be fairly self explanatory when looking at the DVD's and TV's connections at the back.
Oct 27, 2012 | kawasaki 5-DVD Home Theater System - 1152...
What am supposed to do if my t dosen't have HDMI
Either HDMI to DVI adapter cable if TV has DVI in. Or component video cable (Green,Blue,Red jacks, plus White,Red for audio. Both will do HD.
May 01, 2010 | Vizio L30WGU 30 in. HD-Ready LCD...
I need to know where to plug in my connectors for my cable box. I have two red ones and one blue one I can't find the right holes to plug them in. I have a green one and white one fixed so I have a black...
This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video.
Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb
Plug each pin in same color to get color picture.
Jan 08, 2010 | Proscan 32LA30Q Television
I bought a 3 year old Sony FD Trinitron WEGA KV SW29M50 29 and it did not come with a manual question thereare 5 jacks above the video jacks what are they for i have surround sound speakers how do...
The inputs you refer to should be colored as follows.
(not necessarily in this order)
These are what are called Component Video inputs and is one of the way that HD capable equipment connect to your television. It will not get true HD picture but this input will provide you with a crisper clearer picture.
Good Luck and Happy New Year.....
Jan 03, 2010 | Sony FD Trinitron WEGA KV-SW29M50 29" TV
No red when hooking up component cable for dlp hd tv. Only blue and green colors show on hd component input for charter hd cable box. Are there any internal adjustments that need to be made through either...
Check the red cable this is where the red comes from, you may have a bad cable, maybe use the blue or green one just to see if the red will come through, it can be the cable box or the tv or the cable itself.
Nov 03, 2009 | JVC HD-61Z456 Television
I have a KP-15WS51C Sony and I want to know how can I have HDTV?
Does the TV have either a HDMI/DVI input (as labeled) or Component inputs (red green and blue colored jacks)? If not than it is not HD ready.
Sep 21, 2009 | Sony Televison & Video
My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
Mar 16, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Hd connection for wii
The red and white ones, that should be linked or the same are sound.
Dec 26, 2008 | Nintendo Wii Console
KP-53HS10 Real HD
On this TV there is only one input for any HD resolution. Input # 5 is the component input i.e. red/green/blue cable. Just get the correct cable and match colors from cable box to TV this will allow the TV to display 1080i resolution ( only one this TV supports ). FYI you will also have to connect the red and white cables to the appropriate inputs to get any sound because red/green/blue connectors are just for video display not sound. Once your connected you'll be able to access video # 5 be sure to set your cable box to 1080i resolution also. I hope this helps later J.
Dec 02, 2008 | Sony KP-53HS10 TV
Wii component cable - how to connect it?
on your tv, there should be color coded ports that tell you which cords go where but im almost 100% sure that the red and white cords are for sound and the blue and green cables are for hd video hookups.
Oct 14, 2008 | Nintendo Wii Console
Hitachi 60EX01B 60" Rear Projection Television Logo
82 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
