Question about Maytag PYE2300AY Electric Dryer
I have a Maytag Model pyet224ayw electric dryer, The belt broke and I replaced it. Now when I put the new belt on, every time that I turn it on the belt jumps off the tention pully. Can the problem be that I have the wrong belt? Or is something else wrong? Any help will be great. Rod
    Scholar:
  • 49 Answers
Http://www.applianceaid.com/maytag-dryers.html
this site has proper belt routing pictures for several brands maytag included might be helpful the only other thing i can think of the idler may be worn out or bent or drum may be tight not turning properly should turn freely with belt loose from inside dryer
should be able to push vanes and rotate drum easily
good luck ron
Posted on Dec 10, 2009
In my Maytag dryer model SDE305DAYW the heating element works; however, the tumble drum stopped moving. What's wrong?
This sounds like the drum's drive belt broke. But also ensure there isn't a problem with the drive motor. Do you still hear a motor running when you turn it on? If so, you'll need to replace the drive belt.
I hope this helps! :)
Dec 15, 2010 | Maytag HYE3657A Electric Dryer
1991 Maytag dryer Model #LD 68424AAL Serial # A0190126HY
Are you sure that you hooked the belt up correctly, as it sounds like you may have missed the tensioner pulley. As this will tighten the belt around the middle of the drum
Jul 20, 2010 | Maytag Dryers
Thump
The drive belt broke and the thumping was caused by a flatten roller on the belt tensioner. Replace the tensioner pulley and the belt to get it running like new again
May 25, 2010 | Maytag MDE9700AYM Electric Dryer
Dryer blows air, but the tub inside the dryer does not turn. What is the most likely problem?
The belt has broke. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the replacement. You might have to watch a different video for disassembling your model. Enter your model # for diagrams and illustrations of your specific model.
Mar 31, 2010 | Maytag PYE2300AY Electric Dryer
The belt broke on my maytag dryer. how do i replace/repair it?
Try this link. I am assuming your model number is MED6300TQ though it is not mentioned in your text (but it's on the image on the side).
Aug 23, 2009 | Maytag MED6300TQ Electric Dryer
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
I think belt broke need to replace
Go to maytag.com then service and parts then use and care manuals then model no. hopefully you can find info. there if not call customer care 800 number. Most times you have to remove the top of dryer then the front to get to the belt. You will have to locate what type fasteners it uses some use a snap lock type fastener others use screws.
Apr 07, 2009 | Maytag Dryers
MDE5500AYW Drum belt
I dont think you broke the belt, I think it may have just come off the belt tensioner. Take the bottom of the back panel off and I think you will see it hanging in there. Just put er back on.
Nov 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Electric Dryer - replace belt
The belt needs to be above the metal. Otherwise the repair looks good. Easy fix. Thanks for the pic.
Oceti
Jan 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
151 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
