Question about Sharp Office Equipment & Supplies
SHARP AR-P350 CALL FOR SERVICE CODE:H5-01
Check paper jam it's cleared
the paper exit sensor it's OK
still show me ''CODE:H5-01''
I Need Help !!! Thanks!!!
Soulvisitor
  • 1113 Answers
SOURCE: oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Posted on Dec 21, 2007
jaylex
  • 417 Answers
SOURCE: sharp al 1655 false paper jam message,
Check that the paper feed roller is clean as if the roller slips it causes a late paper pickup jam but nothing will be in there also maybe a small torn piece in the machine some where. and check the fuser make sure that is it not stuck in there if no to all these then is will need a control board.
Thanks J
Posted on Feb 17, 2008
  • 2072 Answers
SOURCE: Sharp AR-287 Copier error code H5-01
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
Posted on Mar 17, 2008
  • 148 Answers
SOURCE: SHARP AR337 COPIER - CODE
This code means you have had to many paper jams in the fuser without removal or sensor is bad. Make sure all is clear in the fuser and exit sections.
Then on the control panel you will press a series of buttonsas follows.
Press the P, Press interrupt, Press clear, Press interrupt, Enter # 14, Press start, Press execute to reset, Press clear all or cycle on/off.
Hope that helps...
Lbcoaster
Posted on Jul 02, 2008
  • 17 Answers
SOURCE: Paper Jam
Look into the configuration settings of the printer.. there should be something like disable message on something...
if you can't find it.. try to rest your printer.
Turnit off -- then press Go (or something similar) button while turning it back on.
Posted on Jul 20, 2008
How do I correct error h5 on a Sharp printer AR-5620N?
Hello Sudhir,
The error code H5 means there was at least 5 pages in a row where the paper did not come out of the printer correctly (most likely paper jams. The following manual will direct you on the steps needed to clear the code, please note especially page #8-3
Service Manual SHARP AR 5618 5620 5623 SME
The following video should help also;
Jan 09, 2017 | Sharp Office Equipment & Supplies
I have error code h5-01 on my copier ar 275. how do i fix it?
Check for jam paper in the fusing section.
(paper winding, etc.)
Check fusing unit installation
Clear the trouble with SIM 14.
To clear the trouble with SIM 14, enter the SIMULATION mode.
Enter # INTERRUPT C INTERRUPT, then hit 14 and the START key. Then hit either OK or START again.
Exit the SIM mode easiest by turning the machine off and back on again.
Sep 25, 2009 | Sharp AR-275 Copier
Call for service
Cause The fusing JAM is not completely
removed. (Jam paper remains.)
Fusing unit installation failure
Check and remedy:
Check fusing unit installation.
Check the jam sensors in the fuser.
Aug 24, 2009 | Sharp AR-M237 Copier
Error code H5-01
HI.H5-01
it shows there is some problem in exit sensor .it is in fuser unit.may be its lever is broken .
sensor is dirty clean it
check lever home position and its movemment
check its cable
reset this code
press ,p,*,clear,*
screen will go dead press 14 ,start code will bi reset
never forget to rate the solution.MIAN AKHLAQ
May 07, 2009 | Sharp AR-M350U Copier
SHARP AR5316 SHOWING PAPER WHILE NO PAPER JAM
try to chek if the actuator of the exit sensor is ok you will find it when you open the side door exactly attached to the heater try to check the end is it in plase or not if not use sim 30 sub1 to check all sensors you wil solve your problem
Mar 23, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp 5316 showing paper jam sign at right door but no paper
Shut it off, wait 30 seconds, turn it back on. If the path IS clear, the error will be gone.
Feb 23, 2009 | Sharp AR-5316 Advanced Digital Imager...
Help
H5-01 indicates tha the paper sensor is defective in the fusing unit. The only way you can try to reset that one is buy turning the power off, wait 30 seconds and turn the power back on.
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor.
Jul 20, 2008 | Sharp AR-M237 Digital Copier
Sharp Copier AR-C270 Code Problem
jam in the fuser unit, try simulation 14
and/ or possible bad sensor switch actuating as tho paper is stuck in the fuser. check that exit switch is not stuck open or bad. if jam elsewhere , fuser will not allow operation untill jam somwhere is removed.
Jan 30, 2008 | Sharp AR-160 Copier
Ar-c160
Make sure there is no paper jammed in machine, H5-01 means 5 jams same location. Use quality paper not recycled and make sure it is fresh not old stock
PROGRAM INTERUPT CLEAR INTERRUPT must be SUPER FAST then 14....WILL RESET CODE
Dec 16, 2007 | Sharp AR-C160 Color Copier
334 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
