Question about Toshiba Satellite Pro L300 Notebook
I turned on my toshiba l305s-5900d on day and it is asking for a bios password, but i never put on on it. does anyone have any help. i would apprediate any help. thanks john
    President:
  • 763 Answers
Before attempting to bypass the BIOS password on a computer, please take a minute to contact the hardware manufacturer support staff directly and ask for their recommended methods of bypassing the BIOS security. In the event the manufacturer cannot (or will not) help you, there are a number of methods that can be used to bypass or reset the BIOS password yourself.
Try this first :
manufacturer name : Toshiba
password : Toshiba
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
Method 1 : Removing the CMOS Battery
The CMOS settings on most systems are buffered by a small battery that is attached to the motherboard. (It looks like a small watch battery). If you unplug the PC and remove the battery for 10-15 minutes, the CMOS may reset itself and the password should be blank. (Along with any other machine specific settings, so be sure you are familiar with manually reconfiguring the BIOS settings before you do this.) Some manufacturers backup the power to the CMOS chipset by using a capacitor, so if your first attempt fails, leave the battery out (with the system unplugged) for at least 24 hours. Some batteries are actually soldered onto the motherboard making this task more difficult. Unsoldering the battery incorrectly may damage your motherboard and other components, so please don't attempt this if you are inexperienced. Another option may be to remove the CMOS chip from the motherboard for a period of time.
Note: Removing the battery to reset the CMOS will not work for all PC's, and almost all of the newer laptops store their BIOS passwords in a manner which does not require continuous power, so removing the CMOS battery may not work at all.For eg:  IBM Thinkpad laptops lock the hard drive as well as the BIOS when the supervisor password is set.
Method 2 : Using the Motherboard "Clear CMOS" Jumper or Dipswitch settings
Many motherboards feature a set of jumpers or dipswitches that will clear the CMOS and wipe all of the custom settings including BIOS passwords. The locations of these jumpers / dipswitches will vary depending on the motherboard manufacturer and ideally you should always refer to the motherboard or computer manufacturers documentation. If the documentation is unavailable, the jumpers/dipswitches can sometimes be found along the edge of the motherboard, next to the CMOS battery, or near the processor. Some manufacturers may label the jumper / dipswitch CLEAR - CLEAR CMOS - CLR - CLRPWD - PASSWD - PASSWORD - PWD. On laptop computers, the dipswitches are usually found under the keyboard or within a compartment at the bottom of the laptop.
Please remember to unplug your PC and use a grounding strip before reaching into your PC and touching the motherboard. Once you locate and rest the jumper switches, turn the computer on and check if the password has been cleared. If it has, turn the computer off and return the jumpers or dipswitches to its original position.
Method 3 :
Jumping the Solder Beads on the CMOS
It is also possible to reset the CMOS by connecting or "jumping" specific solder beads on the chipset. There are too many chipsets to do a breakdown of which points to jump on individual chipsets, and the location of these solder beads can vary by manufacturer, so please check your computer and motherboard documentation for details. This technique is not recommended for the inexperienced and should be only be used as a "last ditch" effort.
Method 4 :
Password cracking software
The following software can be used to either crack or reset the BIOS on many chipsets. If your PC is locked with a BIOS administrator password that will not allow access to the floppy drive, these utilities may not work. Also, since these utilities do not come from the manufacturer, use them cautiously and at your own risk.
Cmos password recovery tools 3.1
!BIOS
RemPass
KILLCMOS
Posted on Dec 10, 2009
When I turn the laptop on I see the Toshiba screen for just a second and then it instantly goes to this lovely black screen that says password= How this got there I have know idea. Can anyone help?
Dear beanbean,
This "lovely black screen" is a BIOS password screen. This shows up because somebody has set a boot-up password in the BIOS Setup. If you're lucky, the BIOS Setup is still unprotected, and you can access it as follows:
When you turn it on, look for something that says "Press [button] to enter Setup" or "Press [button] to enter Setup Utilities." Press the corresponding button on your keyboard, and you should enter BIOS Setup.
Now two things can happen. Either you are permitted to access Setup, or you are prompted for the password.
If you can access Setup, navigate to the Security tab and clear all set passwords.If not... then you can either reset BIOS by unplugging the computer, taking off the back, and removing the CMOS Battery (unrecommended), or you can call Toshiba support and ask for the master password (Most manufacturers have a master password, which will allow you to access Setup and remove the boot-up password)
Hope this helps,Ericthecmh
Sep 13, 2011 | Toshiba Satellite A105 Notebook
TE2100 ASKING ME PASSWORD AT POWER ON
If your notebook asking you a password while you turn it on, probably someone is set your basic input output system(bios) configured to prompt for a password. There are two ways to clear your systems password 1. is you have to guess for the password 2. you have to clear the cmos or bios settings by removing your cmos battery from your motherboard for about 10 seconds. Then put it back again then on your computer. That's all have a nice day!
Dec 29, 2010 | Toshiba TE2100 Notebook
My toshiba laptop is asking for a password it will not boot without it as soon as you turn it on it wants a password
BIOS is set to password on....
did anyone make changes to ur laptop....
if so then only he can unlock it....as BIOS passwords cannot be unlocked....they are embeded in the BIOS microchip...
only a BIOS update can undo it...and that's very RISKY...
Oct 31, 2010 | Toshiba Satellite A215-S7437 Notebook
Hdd1/ssd1 password
I have bought a used toshiba satellite L555D-S7006 with windows 7 home premium 64 bit with the amd processor, it was working great. Well the other day I turned it on and it said to enter the bios password, I never put a bios password into the computer. I did some research on this and took the motherboard over to a freinds and he removed the cmos battery, after i reinstalled the motherboard now its asking for a HDD1/SSD1 password. So does anybody have any ideas about how to fixx this problem
Sep 24, 2010 | Toshiba Satellite L455S5980 Notebook
MY TOSHIBA SATELLITE A215-S6804 SHUT DOWN ONE DAY AND I TURNED IT BACK ON AND IS ASKING ME FOR A PHOENIX BIOS PASSWORD I HAVE NO IDEA WHAT THAT IS CAN SOMEONE HELP MEPLEASE?
The BIOS password is necessary to allow the computer to load it's basic startup programs before Windows begins to load. If you don't know the password or have forgotten it, you will have to have someone clear and reset the BIOS by disassembling the computer.
Jan 06, 2010 | Toshiba PSAFGU-058002 Notebook
Locked out of Toshiba laptop, Help!
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Some Toshiba bios passwords can be reset using the Key Disk.exe utility, to do this you need a 1.44Mb floppy disk.
Format the disk to be BOOTABLE using Windows and then with a hex editor, change the first five bytes of the second sector to 4B 45 59 00 00.
Then put the floppy into your machine and boot it up, you’ll be asked for a password, just press Enter. Then when you’re asked to set the password, type Y then Enter, this will get you into the bios configuration where you can then type in a new password.
Mar 26, 2009 | Toshiba Satellite A135 Notebook
BIOS PASSWORD
take out the bettery, take out the CMOS battery. unplg the AC
hold down the start buttom for 2 min.
reisntall all power try again.
Jan 29, 2009 | Toshiba Satellite A205-S5823 Notebook
Bios password was changed and now i cant get into it
my tosiba is asking for bios password. Ive put in the only password that weve ever used and its not working. can anyone tell me how to do this?
Nov 29, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite A215-S5818 bios password
I think there is a power on password on it. Please reset it from motherboard. I Think u need to open it. and reset. Take Professionals help if you are not aware of technical details. Else this will damage Motherboard and you no longer you wil be able to use it. Please rate and ngive me feedback
Mar 22, 2008 | Toshiba Satellite A215-S5822 Laptop
Bios password
Remove the case, find the BIOS reset jumper and short it for a few seconds, or remove the bios battery for 5 s, put it back and that's it !
Jan 16, 2008 | Toshiba P205-S6267 Notebook
Toshiba Satellite Pro L300 Notebook Logo
808 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
