Sound cuts out and switches between stero and mono on both TV input and DVD input
  • 8,457 Answers
Unplug,replug an hour later,reset all audio setting to factory setting.It should be back to normal or ur backlight video board it dead,must change if same problem occur again n again.
Posted on Dec 10, 2009
Philips Magnavox TV TS 3260 C121
Audio decoder section circuit fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Jun 22, 2016 | Philips Magnavox 27MS343S 27" TV
Can you hook up a DVD player to this TV? It is a DTQ 13V5FC purchased in 2003.
I took a look at the specs for this set, and it has both front- and rear-panel audio and video input jacks. There's a button marked "VIDEO" on the remote that switches to the AV input so you can watch what you have connected. So yes, you can hook up a DVD player, but there are some limitations.
This isn't a stereo TV, so you'll need a Y-adapter (like this one from Radio Shack) to combine the right and left channel sound from the DVD player into a single mono input for the TV. This means you'll lose any stereo effects from the DVD. Also, even though there are two sets of AV input jacks, the TV can only use one at a time. You can't select the front or rear input separately.
Hope this helps. Thanks for using Fixya!
Mar 26, 2011 | Daewoo DTQ-13V1FC TV
Some DVD's sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it?
" Some DVD\'s sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it? "
I wrote a short article for someone who had a similar problem a few days ago.
I will edit it for you so that it fits. Here it is.
Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO (or MIXED ) Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo(or MIXED) then the dialog will be sent to the CENTER channel output. If you have no center channel speaker you will not hear it. Thus no dialog.
NOTE: In your case for the TV that is mono, here is the solution.
1 Connect a stereo pair of RCA cables (red and white "male" connectors at each end) to the Mixed or Stereo Output of the DVD player (NOT ANY SURROUND OUTPUTS).
2 Purchase an RCA type "Y" connector that has 2 female to a single male connectors on it. Walmart about 3 dollars.
3 Plug the single male plug of the Y connector into the back of the TV set's single mono audio input.
4 Connect the stereo RCA pair from the MIXED output of the DVD player into the Y connector that is now on the back of yourTV.
5 Run your yellow Video output from the DVD into the Back of the Set's yellow input.
That should do it. The sound should be clear and correct with dialog, effects and music.
Hope this helps,
Best,
Mark
Jan 27, 2011 | Audio Players & Recorders
Hello, i am trying to move the tv from mono to
Take your remote, go to menu, scroll down until you see sound settings, when you see mono/stereo, use the right arrow and click it until cursor is over stereo, next press enter, that should restore your stereo sound.
Jan 12, 2011 | Jensen Q2049J 20" TV
Set up for panasonic tc-50ps24 tv with hd cable box to home theater and dvd recorder
Man the best i can tell you to do is to keep everything strait starting with your video and then your audio. If your running Hi def you might can possibley run S-Video being that your DVD recorder may only have the input and out for that. If so you would take your video being S Video run it into the Home Theater Reciever and then go monitor out of the reciever into the DVD recorder. Keep in mind you must run S Video into your Home theater then to your DVD. More then one cord may likey go into your Home theater but only one should come out to go to the DVD player and then to the the TV but thats just for your Video. Now for your sound you have a few options. You can run anlalog to the Reciever or run from the Digital side either Coax or Digital Optical and again this is for your sound and is marked on the reciever. Your better sound will be Digital but you can still run analog if you want to do so. It may be easier for you to understand that anlalog is unsually in mono and not stero which means your sound will not have the defination you may want but never the less you will still have sound.
Jan 04, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Left speaker works in all modes except the tv mode
It sounds like there must be a bad connection on that input. Try switching the left and right input cables for the TV and see if you get the left cahannel working. If so, investigate a possible bad cable or output issue from the TV.
Dec 26, 2009 | Bose 3 2 1 GSX System
Poor sound when playing dvd
Have you checked your TV audio inputs try using a separate audio lead from the DVDR to the TV most will have an AV input normally with two mono inputs this will also identify which channel has the fault if any.
LOL
Jul 12, 2009 | Philips DVDR3380/05 DVD Recorder
Mono to stereo
You can't convert mono to stereo since the TV only has a single input, and not the separate right and left channel circuits needed for stereo. If you are connecting a stereo source like a DVD player, what you can do is combine the right and left channels into one and connect that to the mono input. You need an audio Y-adapter with two RCA jacks going into a single RCA plug. These are available from Radio Shack. If you are outside the US, there should be local sources such as a stereo shop where you can find the adapter. This won't give you stereo, obviously, but you will have all the sound.
Jun 22, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
How to connect surround sound system, at the moment its connected through cable, each time we use the dvd player we have take them out of the cable box then into the dvd player, we have a LG 42PC55 tv.
In order of picture and sound quality -- from best to worst:
1. The best way to connect, assuming your TV and A/V Receiver and/or Cable Box have the jacks, is to use a HDMI cable ( this cable is for both sound and video).
2. Use Component Video out to input (3 RCA plugs, Red, Blue & Green) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
3. Use S-Video out to input (1 din plug) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
4. Use Video out to input (1 RCA plug, yellow) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
Be sure to select the correct inputs on your TV and Audio/Video receiver when you are watching TV. For example if you have connected your TV to HDMI 1 and DVD to HDMI 2, you will not see or hear anything if you don't select the correct input on your TV and A/V receiver for the input you want to see and hear.
Detailed connection instructions will be found in your owners' manuals.
Hope this helped you. :)
Mar 30, 2008 | Televison & Video
RCA 27V412T TV Problem
Just to see if the set reacts and it does something different tap the sides of it,dont over do it ,I should not take much to see a reaccion if it has a loose conection,If it reacts check for loose conections in the power supply,horizontal driver transformer and any overheated areas specially after the output transformer.If you are familiar with tv service this should help but if you are not be safe and call for assistance from a servicer.
Oct 03, 2006 | RCA 27V520T 27" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
