Samsung HDTV HPS5053 - Can main board Rev be swapped?
I have the sparkle problem several others have reported which seems to be universally attributed to a bad main board. I know there were three revisions to this board and I know mine has BN94-00925A.
My question is will the B or C board also work or do I have to find an A board? I've been looking and A boards are scarce and far more expensive.
  • 8,457 Answers
Must buy ur version of ur board because the power supply it work with that version.
Posted on Dec 10, 2009
Samsung LN46C610N1FXZA SOUND fine no picture.no backlight. flashlight test shows video is fine. voltage test on power board is double on all voltage points,
Sorry to hear that, it seems video processor chip failure on main board and entire main board swapping is needed, please note that there are various different version of main board utilized in this one mode so it is very important to get identical main board as replacement that has same part number.
Jan 07, 2018 | Samsung Televison & Video
Where to buy a Samsung BN97-00964 main board?
There are several on Ebay, just make sure you go with a Top Rated Seller W/a reasonable return policy.
Nov 09, 2012 | Samsung Televison & Video
My Samsung 32¨tv´s black
reseat your LVDS cable and clean both ends with lighter fuel. This shouls solve your problem if not upgrade your firmware . go to the samsung site on the web with model#. If you still have a problem replace the main board.
Nov 04, 2010 | Samsung LN-S3241D 32 in.LCD HDTV
Screen keeps losing colour and ends up with a blue tint
On this model there tend to be two problems. One is that the power supply capacitors fail early and often. While this typically caused no power or slow power-on, it can cause other issues as well.
Loss of color typically means the 'Main Scaler board', which is the main board where all the inputs are attached, is having an issue.
There are some problems reported with a faulty crystal on the board causing loss of color, although most techs would just swap the board as these TVs are meant to be serviced at the board level, not the component level.
I assume that this loss of color happens on any input source, including when using the internal setup menu of the TV? This would help to confirm that the loss of color is not related to a faulty input signal caused by a bad cable.
Oct 16, 2009 | Philips 32PFL7332D 32 in. LCD HDTV
Red sparkling on dark areas
BNeed to get service ,
It should be very complicated to adjust all the voltage on Power Board & Y-Main Board.
Sep 10, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung HPS5053 Plasma TV
It may due to the Logic board, or Logic Scan board, or the Panel failure.
Apr 19, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Samsung Big Scrren HDTV monitor
reseat the LVDS cable inside the set, this is the multi wire connector from the display panel to the main board. remove it and reseat it several times on both ends. if that doesn't solve the problem replace the main board.
Feb 17, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Sparkles
Makes you wonder why nobody is taking on the problem, doesn't it?
Well , to the best of my knowledge, it is because nobody really can.
To understand why you have to understand what do they sparkles come from.
They are random electricity discharges coming from capacitors or other components that act like capacitors, but mostly capacitors.
When laymen hear about capacitors they usually associate the word with bulged electrolytic capacitors, which often cause problems in electronics of all kind.
Well this time it isn't about them.
It's about all other capacitors - or other components exposing similar qualities - which are installed on the board. Most of them are small filter capacitors put in parallel to the big ones or to other passive components such as diodes and resistors.
The excessive heat developed by the sustain boards damages those capacitors. It hardens the electrostatic material they are made of and small breaks in it start occurring at voltages that shouldn't otherwise be causing issues.
The trouble is, they can be everywhere. You can't just pinpoint which ones were caught at fault and causing the sparkles.
When it gets REALLY bad eventually the whole capacitor burns and either shorts or, more commonly, just breaks.
Believe it or not I've seen a board that exploded before my very eyes and , after the explosion, started working LIKE A CHARM!
Turned out a small filter capacitor had blown. It as not essential for the board's functionality and after being problematic for so long and causing image deffects it had eventually shorted completely and literally exploded.
Luckily, the short it had created was too short in time and apparently in a circuit that could take the load for a short while without getting damaged.
So after it blew everything worked just great!
it's a real story from my repair experience.
Hope this helps all consumers, DIY enthusiasts and competitors alike :-)
For more you are welcome to visit our site and read our tech repair blog at
http://www.coppelltvrepair.com
and
http://blog.coppelltvrepair.com .
Aug 26, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG 32LC2D HDTV
Many TV's with an LG plasma display (or built by LG for other manufacturers) have a manufacturing defect that has been reported widely on the Internet. LG, Akai, Samsung1.gif and Zeneth among others.
The sparkles are (usually red) visible on a black background with all inputs after the set has been used approximately one year. Soon after a pop is heard and the picture no longer shows at all.
LG and some other manufacturers using the LG displays have not acknowledged this defect and will only repair them free during the warranty.
Often techs will merely adjust voltages and or picture controls, which does not fix the problem but it just disguises it -- until the display blows -- usually after the warranty expiration.
I own a 42" Akai that is 9 months old that has recently been showing the red sparkles. My set is being replaced.
You should contact service if your set has this problem is under warranty and it should be replaced at no charge.
Good luck. :)
Aug 07, 2007 | LG 32LX3DC 32 in. LCD HDTV
Televison & Video Logo
205 people viewed this question
Top Televison & Video Experts
