Question about Cabela's Optics
How do u sight in a pine ridge rifle scope with tactical turrets
5 Suggested Answers
SOURCE:
  • 243 Answers
SOURCE: 1. HOW TO READ SCALING OF SCOPE.? 2. What is
You have not provided enough information for us to help you. What type of rifle? What do you mean by scaling?
With the scope on 3 power you should be able to sight it in at 25 meters. Going to a higher magnification may cause blurring at that distance.
You also may have mounting problems that are causing the scope to move around when you shoot. Your rifle may be fine.
Posted on Oct 14, 2010
  • 2418 Answers
SOURCE: How do you sight it true for the rifles prior to
You can get a base line by bore sighting the scope. Bore sight kits are a bit pricy, might be best to take it to a gun range an start at 15 yards shoot a few move out to 25 the 50 then 100. Yes your scope should be sighted for one gun one round, with a cold barrel. Let it cool between shots.
Posted on Oct 18, 2009
agent91
  • 2100 Answers
SOURCE: I just purchased a savage .17 HMR with a cabelas
A quick and easy way to bore sight your rifle, if it is bolt action only, or an AR, mount the rifle in a cardboard box with cutouts so it will sit without tipping, remove the bolt and sight down the bore at a target 100 yards away, a mail box, or the corner of a building, make sure the rifle doesn't move, then peek through the scope, it should be seeing the same target your bore is seeing, if not, adjust your scope to it, if it won't travel that far, shim the front with pieces of 35 mm film. then check it again, if you can get it to stay there, it will put your bullet on paper at 100 yards.
Posted on Mar 09, 2010
Have a pine ridge rimfire scope need to know what mounts i need to atttach to a marlin 60
1 inch dovetail mounts medium height if your marlin 60 has 11 mm dovetail rails . if not will need to get receiver drilled for rail mounting and mounts of your choice better to get a competent gunsmith to do it
Jan 18, 2014 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
I dont understand what the extra dial on my new 6-18x44 scope is for or how to use it.Or what range evry line and dot in the reticule should be ranged in at.
The third turret is for parallax and approximate range
And the lines on the reticule are round and velocity specific plus magnification comes into the distances between substension
On my scope 100 yard zero the next substension down is 176 yards at 10 magnification
The best way to use the reticule for ranging is to get a ballistics program and enter rifle round and scope stats and get a chart for that round and reticule
And the drop chart will change for different velocities and ballistic coefficients of rounds and temperatures a summer chart will be different to a winter chart due to denser air in the cold
Apr 14, 2011 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
Is there a way to lower my turret after i've found my zero? my zero is at the 4th vertical tic mark on the 0.
No. The turret is what it is. If you want to re-set the turret to zero so that it is easy to return to for a specific distance, there should be a setscrew you can loosen, adjust the turret to zero, then re-tighten to lock it in place. If you are simply trying to lower the turret, you need to purchase a scope without target turrets.
May 24, 2010 | Leupold Long Range/Tactical M1 Mark 4...
On the adjustment turrets, after loosening the set screws, how do you get it to go down so the yardage lines up?
after you sight the rifle in at say 100 yd. lift the turret and line up the 100 yard mark on the turret to the mark, then push the turret down onto the scope and set the screw. some times the turret takes a lot of pressure to push back on.
Mar 29, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
I just purchased a savage .17 HMR with a cabelas pine ridge 3x9x40 tactical scope and I'm having problems siteing it in. It is shooting aout 4 inches low regadless of adjustments I try and make.
Mar 07, 2010 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
I have to use reading glasses to use a simmons blazer rifle scope.....othewise the image is blurry.
You can't see the cross hairs or the whole picture is blurry? I know that the rear ring on the scope will bring the cross hairs into focus, glasses or not, and the scope itself should be clear all the way down, I can't see a thing either without glasses and it has really hampered my shooting. It ain't no fun , it's frustrating. Try turning the rear eyepiece, see what happens, hope this helps.
Feb 27, 2010 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
Adjustment Issue
the scope should all ways be fitted with the wind adjustment on the right as you look down the rifle, therefor the top ajuster is for up/down,
right ajuster is wind,,left/right, the easy way to set it up is to aim at some sand with the rifle on a stand or in a jig, shoot one round see were it hits and without moving the rifle, turn the turrets till the cross is over the point were the bullet landed, having a pall to move the turrets for you helps a lot here, the main point is dont move the rifle till the turrets have been moved first,, its that or bore sight it,,, jig the rifle up pointing at a target at say 200yds look down the bore aim the bore at the target lock down the rifle check it by looking down the bore again then set the cross up in the scope on what you see down the bore
you will need to tweek the scope a bit as you havent taken the bullet drop into the ajustment that way,,
Dec 17, 2009 | Zeiss 3-9x40mm Conquest Rifle Scope...
Got moisture in scope and it is fogged up
take it into a camera shop, they will have the tool,, but if you undo the scope it will need to be regased again the "o"ring seals have worn out or broken and thats how water got into it,, it also let the nitrogen out of it,,,if its a cheepy scope buy a new one,,,
what i mean by a cheepy is less than £1000,,,,
Nov 16, 2009 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
How do you sight it true for the rifles prior to using the windage and elevation turrets. All other scopes I,ve seen with range compensators have the ability to be sighted in. I can't figure out how to...
Oct 14, 2009 | Tasco 3-9x32 .22 Riflescope W/ Rings,...
Optics Logo
842 people viewed this question
Top Cabela's Optics Experts
Marvin
Marvin
james laughton
james laughton
ray gallant
ray gallant
Are you a Cabela's Optic Expert? Answer questions, earn points and help others
