MY TV WONT COME ON, BUT A YELLOW LIGHT IS BLINKING
  • 11,896 Answers
This is usually due to either a faulty power supply or high voltage transformer depending on which one your model has. You can use a voltmeter to see if there is power to the main circuit board and other components.
You can get parts at:
tigerdirect.partsearch.com
Posted on Dec 10, 2009
What does it mean when green power light turns yellow and blinks on and off. tv will not come on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Dec 03, 2014 | Televison & Video
TV will not turn on? Blinking LED,won't turn on? Changing back and forth from Blue and Yellow; which is on and off from panel lights?
the red picture is because the optical block is bad now this part cost about $500 plus labor , when you took the lamp out you need to put the door back otherways the tv wont wort
Jan 27, 2012 | Toshiba 62MX195 62" HDTV
I recently replaced a 915P026010 bulb for a MiTSUBISHI WD-62628 tv and it gives me a blinking yellow light in the lamp led indicating that the lamp housing is not installed properly. I have re-installled...
Make sure lamp cover is also fixed on tv cabinet after lamp installation.
If lamp cover has not been put on its place, tv wont turn On due to safety switch inside that place that gets press with lamp cover.
Thanks.
Jun 24, 2011 | Televison & Video
Tv wont turn on
maybe theres a defect in your tv, in the board or theres a shorted parts on it. you need a qualified technician to fix your tv.
Jun 28, 2010 | Westinghouse Electric SK-26H730S 26 in....
TV wont turn on, there is a blinking yellow light ...
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power suppply board just have dead leakages gases capacitors.These capacitors alway bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole rerfurbish power supply board for the replacement.
May 21, 2010 | Samsung LTM1755 17 in. HD-Ready LCD...
Yellow light keeps blinkingand the tv wont turn on
If the status light is blinking yellow it means the filter cover is open ( On the left side of televison)
If the lamp light is blinking yellow it means the lamp cover door is open. ( Behind front lower panel) If both covers appear intact the switches may be defective or not engaging properly.
Dec 11, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Solid Yellow light and blinking yellow status light after bulb replacement. TV wont turn on.
Sounds like Mitsu is getting sued left and right about their DLP problems. There is a potential overhaul if you contact their parts department.
Oct 13, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Jul 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
When turning on the TV the green light on the front does not come on. You hear a click and then about ten seconds later you hear another click but the tv never comes on.
What light do you get, green blinking, red blinking, yellow steady light or yellow blinking light. The led lights will tell what is wrong with your tv.
Jun 12, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Yellow status light blinking
tour air filter cover door is either not tight, or off, or the small switch behind it is bad. it is on the side opposite the ac plug.
Dec 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Open Questions:
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
