Question about Samsung V20 XVC 2400 Notebook
I lift the notebook from the left hand corner and laptop switches off
    Guru:
  • 1,481 Answers
Visit a computer store to fix the issue...
other option is dont lift the laptop at all...
Posted on Dec 10, 2009
How to reset bios on compaq v2000 laptop
Remove A Cmos Battery From A Compaq V2000 Laptop
The Complementary Metal-Oxide Semiconductor (CMOS) in a computer is responsible for storing hardware settings and time on your computer. The CMOS is powered by a small battery and is able to store information whether your computer is turned on or off. While the standard CMOS battery lasts for up to ten years, you may need to replace your CMOS sooner than that. If you password your BIOS and forget the password or need to reset your configuration back to the default, you can remove the CMOS and re-insert or replace it.
Instructions
1. Unplug the computer from the wall outlet and unplug the AC adapter from the computer.
2. Turn your Compaq Presario V2000 face down and slide the battery release latch to the left to disengage the battery from its position. Remove the battery.
3. Unscrew the screws over the hard drive cover, which is located in the lower right corner of the laptop if your laptop is placed with the battery away from you. Lift the hard drive tab, located on the left side of the hard drive, and slide the hard drive to the left to remove it from the computer.
4. Unscrew the single screw located directly under the optical CD/DVD drive. Insert a very thin item, such as a paper clip or pin, into the hole located on the optical drive to open it. Slide your optical drive out of its tray to remove it.
5. Remove the two screws located on the switch cover, which is directly under the battery. Turn the computer right-side up and open it as wide as it will go. Use a flat tipped screwdriver to lift up the switch cover that is directly above the "F1," "F5," "F11" and "Insert" keys.
6. Unscrew the four screws that hold the keyboard in place. These screws are are located in the upper right corner of the computer under the switch cover that you just removed. Lift the keyboard up and slide it forward until it rests on the palm rest. Unplug the zif connector, which is located directly above the palm rest, to disconnect the keyboard. Lift the keyboard up and out of the laptop.
7. Turn the computer upside down again and remove the memory modules by unscrewing the two screws over the memory compartment located directly below the battery slot. Unclip the two clips located on each side of the memory module to release it from its slot and slide it out of the computer.
8. Unscrew the two screws on the PCI cover directly beneath the memory module. Disconnect the two wireless antennas above the card. Spread the two clips securing the mini PCI card into place and lift the card up and out at a 45-degree angle away from you.
9. Flip the laptop back up on its right side and disconnect the display cable located in the upper left corner above the keyboard area underneath the switch cover you removed earlier. Then remove the two pieces of tape in the upper right corner that hold the wireless antenna in place. Remove the two clips located beneath the tape pieces. Unscrew the two screws on the upper left corner and the two in the upper right corner that hold the display into place. Remove the display assembly.
10. Turn the computer back upside down and remove the remaining 19 screws. Lift the base enclosure straight up out of its place.
11. Locate the CMOS battery, a small circular object, and lift it up out of its place. Leave it out for five minutes and reinsert it to reset your settings. Re-assemble the computer without the battery and plug it into the wall.
Remove Cmos Battery From Compaq V2000 Laptop
Jul 02, 2014 | HP Compaq Presario V2000 Notebook
Touch pad locked on HP dv6 Laptop. There is a switch above the pad. White and orange when switched.
Hi Harry, I figure you will have had this answered by now but anyway,
double tap on an area in the upper left hand corner of the touchpad. This is how you disable and also how you enable it.
Feb 17, 2014 | HEWLETT-PACKARD ProBook 4520s Notebook
White patch on corner of my laptop
Has it been damaged? Bumped? Dropped? on that corner?
Jan 20, 2013 | Samsung R730 Notebook
Laptop is getting hot in upper left hand corner above the start button.
Laptops getting hot when use is common,it is just some models are too hot,you can buy a Netbook Cooler Pad to prolong the life and use of your DV9910US 17-Inch HP Laptop PC Notebook
Nov 22, 2010 | HP Pavilion DV9910US Notebook
The right shift key does not work as well as a few of the upper left control keys...everything else seems to be working just fine.
Hi there , this might be the ribbon cable connecting the keyboard to the laptop , lay the screen flat , look at the left hand side of the lap top , there is a strip you can lift up , where the power switch is. lift the strip up , you will now see the two screws holding the keyboard down, unscrew them , slide the keyboard up slowly and lift , gentaly you will now see the small riben cable, lift the small black catch , then reseat the cable , push the catch back, and reseat the keyboard. now retry the keyboard ...
Nov 13, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Where do i find the hard drive for the amilo li2727 to remove it?
before you start unplug and switch off!!
turn lap top upside down hinges to lit at the top
at the bottom left corner there is a 2 inch by 1 inch strip
remove the 2 screws
lift off plastic cover
pull plastic tab which is attached to the hard drive
the hard drive will slide out
Oct 24, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
How do i turn on the bluetooth in my advent notebook
Hold in the Fn button bottom left hand corner, and press the F11 key. Sometimes need to do this twice to switch on the bluetooth. (icon goes blue)Same to switch it off (icon goes red)
Aug 12, 2010 | Advent Netbook
What keys do i press to reboot acer aspire notebook
i have an acer aspire 3680 laptop when i switch it on the power indicator os on but i cant get past a black screen with a small white line in the top left hand corner please help
May 27, 2010 | Acer Aspire 3680 Laptop
How to remove hard drive fron siemens lifebook s7110
Turn Laptop over, looking at it so the battery is at the top edge. In the bottom left hand corner is a rectangular access cover with some air vents, unscrew the 2 screws and take off the cover, you my need to use a flat screw driver to lift it, you should now be able to see hard drive. Remove any screws holding drive and slide it either left or right to to disengage it from its connections and lift it out.
Mar 31, 2010 | Fujitsu Siemens LifeBook S7110 Notebook
HP TX1000 Tablet The cursor on my screen keeps going to the bottom left hand corner and stays there. The problem remains even when I used a USB mouse. Anyone knows what the cause?
click start button in lower left hand corner, then a pop out menu will come up, click control panel, then find mouse, click it, then go to pointer options and click it, see if theres a box checked that says something like (automatically move pointer to the default button in a dialog box). uncheck that box......hope this helps you.......
Jan 06, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
Samsung V20 XVC 2400 Notebook Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
