Question about U-Line 75R Refrigerator
My 75R is about more than 8 yrs old. The thermostat has in and out connectors. The new one has 3 and 4 labels. Which is which? Please help. Thanks
  • 57 Answers
Shouldn't really matter. 3 is in and 4 is out. There is sometimes a 6 aswell as this is a constant feed for a light in the fridge.
Posted on Dec 10, 2009
Wher do i find a thermal switch for whirlpool water heater
1) Call whirlpool and give product type, model number, and serial number that shows on label on side of unit.
1-877-817-6750
2) For gas: Likely they will send whole assembly
http://waterheatertimer.org/How-to-replace-thermocouple.html
3) For electric thermal switch, just replace upper thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
4) Repost question and include information on label
5) Call service technician
Jan 01, 2013 | Whirlpool Water Heaters
Tip
U-Line 75R: Replacing Thermostat when unit will not run
<span>I am reposting <b>Don Willis's</b> EXCELLENT but hard to find tutorial on how to replace a thermostat on a <b>U-line 75R</b> as a HOW-TO Since he spelled "refrigerator" incorrectly (Refidgerator), </span><span>Google cannot find it easily! I followed these instruction and finished in about an hour. </span> <span><br /></span> <span>Got the thermostat part on eBay from a venfor called Part Peddler.</span> <span>The U-Line part number is 2766-S, cost me about $30,shipped.</span> <span><br /></span> <span>Don's post follows, my comments in {} brackets: </span> <span><br /></span> <span>The light worked so it was getting power. </span> <span><br /></span> <span>I used an electrical tester (pencil like device I bought at Lowe's) to figure out that power was making it to the thermostat (black wire) but not after the switch (blue wire). </span> <span><br /></span> <span>To change the thermostat. </span> <span><br /></span> <ol> <li><span>Take covers off the front bottom (one flathead 1/4" hex screw) and back panel (about 10 flathead 1/4" hex screws) of fridge.</span></li> <li><span>Unscrew the old thermostat (2 screws). Leave black and blue wires on it so you will know where to put them on the new one.</span></li> <li><span>Take out glass shelves on inside. Unscrew back panel {note: there are spacers that will fall out} . There are 2 phillips screws {on nuts} that hold the end of the thermometer to back panel. {I removed one and loosened the other to free the "coil" thermostat) reach hand under the back panel and feed the thermometer back through hole and out back of fridge. You will notice a putty like substance that fills in the hole in the back where the thermometer gets fed through. Make sure you keep it to fill in the hole in the back. </span></li> <li><span>Feed new thermometer {coil} end through hole in the back {I found that using a Phillips head screwdriver to guide the coil through was useful} and install to back panel {using those two Philips screws and nuts}. </span></li> <li><span>Put the putty back in the hole from the back to insulate around it. </span></li> <li><span>Feed the electrical end of thermostat through bottom of fridge</span></li> <li><span>Take the wires off the old one and attach to the new one. </span></li> <li><span>Attach the thermostat to its mounting location </span></li> <li><span>Reinstall all the screws in the front and back and you are in business.</span></li></ol><span>Had a hard time finding someone to service it. They wanted $200 to come out to the house + parts and labor. The new thermostat cost $33 at All Brand appliance. I am from Mass and picked it up in Brockton. I emaile dU-line and they sent me the new part number. The allBrandappliance site had the old part number (2766-s) I am notan electrician and this was a few hours work.</span>
on Apr 10, 2011 | U-Line 75R Refrigerator
Installed a new Filtrete thermostat on a new Carrier high-efficiency furnace. I followed instructions exactly. It doesn't work. What did I do wrong? Furnace was installed in December. Broom handle...
Hi smargyle,
Welcome to fixya!
I can provide you with diagrams for the old Carrier therm and for the new Filtrete therm. But, I would need to know what the model numbers are for each therm plus how many speeds AC you have.
Please reply back with that information and we will get your AC back in working order.
Thanks,
Handie Andie
Jul 22, 2011 | Heating & Cooling
U-line 75R was not cold. Shorting the two wires at the thermostat, the motor runs and starts to get cold. Replaced the thermostat, but it didn't run at all. Please help. Thanks
There is a slight possibility that the unit's defrost timer just happen to be in defrost when you replaced the temperature control. Try advancing the defrost timer (or just let it sit for about 1/2 an hour and see if it comes back on). If you have more questions, let me know. Hope this helps!
Dec 11, 2009 | U-Line 75R Refrigerator
Refrigerator compressor motor will not run.
Does the fan work? If yes then the compressor has a relay and overload that might be bad. Or it could be a compressor that is bad. If its a compressor then you will need to have a tech verify that it is the problem. If nothing is running then it could be a thermostat thats not switching it on. Let me know if you need any more help with it.
Aug 11, 2009 | U-Line 75R Refrigerator
Switching old thermostat to Hunter thermostat model 44155c
By describing the wires from your new thermostat and your old one, it sounds like your new thermostat is not compatible with your system. If you have seven wires now, then you more than likely have a heat pump system and you have to get a thermostat that is compatible with this type of system. Then you will have the connections you need.
Jul 11, 2009 | Hunter Fan Company 5/1/1 Programmable...
Uline 75R refridgerator stopped working
Sounds like you did everything right
Jan 24, 2009 | U-Line 75R Refrigerator
Lighns on - nothing else
well i have a 75r also with the same symptoms but there's no freezer in this model so I don't know how it could be the defrost timer.
Dec 03, 2007 | U-Line 75R Refrigerator
U-Line 75R Refrigerator Logo
174 people viewed this question
Top U-Line Refrigerators Experts
billconfused
Ilia Bichin
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
