Cant open an avery file - Heating & Cooling
  • Bill Schilz
    Bill Schilz May 11, 2010
    Do you have Avery Design Pro? What are you trying to open it with?
    Problem Solver:
  • 14 Answers
HOW DO I CREATE A DATA BASE FOR FILE LABELS USING AVERY LABELS 6646? THANK YOU, BARB KOWALSKI
you can do it in excel
then mail merge excel file with
word https://support.office.com/en-us/article/Mail-merge-using-an-Excel-spreadsheet-858c7d7f-5cc0-4ba1-9a7b-0a948fa3d7d3
and use avery template in word
http://www.averyproducts.com.au/avery/en_au/Templates-%26-Software/Templates
Jan 27, 2017 | Avery Office Equipment & Supplies
Label maker
Try to reload avery with the new word.
Sep 08, 2017 | Avery Computers & Internet
I have installed Avery for my Word 2007. I am trying to do labels from an existing excel spreadsheet, also 2007, and when I get to the point to select from existing file it says there was an errora and...
Jill (guerinje),
I might have a solution for you.
I recently ran into this issue as well. When using the Avery Wizard (Avery Wizard 4.01 - US 20111209.exe), I was able to select the Avery Product template, the customization Design, and could select the 'Merge data from an existing data file' option, but when I clicked 'Next' to continue, I got an aborted list of recently used data files and then an error pop-up stating that the Avery Wizard encountered an error and needed to close. There was also the option of notifying Microsoft of the error.
Here is the solution that worked for me - TAKE CARE - This solution makes changes to the computer's Registry: WARNING: Using Registry Editor incorrectly can cause serious problems that may require you to reinstall Windows.
These instruction are for Windows XP. Other operating systems will most likely require adjustments to the steps below.
Step 1: Open the Registry Editor: Click the Start Button -- Select 'Run...' -- Type regedit -- Click 'OK'
Step 2: Select the Registry Entry: In the Left-Hand pane of the Registry Editor, double click on 'HKEY_CURRENT_USER', then on 'SOFTWARE', then 'Avery', then 'Avery Assistant', then '4.0', then single click on 'Recent Data Files'.
Step 3: Backup the Registry Entry: On the 'File' menu, select 'Export...' -- Select your Desktop for the 'Save in:' field -- Enter a name for the backup of this registry entry: I used 'Avery Recent Data Files' -- Make sure the 'Save as type:' is Registration Files (*.reg) -- click the 'Save' button.
Step 4: Delete the Registry Entry: In the Right-Hand pane of the Registry Editor, ignore the entry for '(Default)', select the entry for File1, hold down the 'Shift' key on your keyboard and then select the last file value (for me it was File9 - File10 was actually listed between File1 and File2) -- When all the File entries are selected, right click on them and select 'Delete'.
Step 5: Exit the Registry Editor: Either Select the File menu's Exit option or click the red 'X' button in the upper right corner of the Registry Editor Window.
Step 6: Restart the computer
Step 7: Login again
Step 8: Test the Avery Wizard in Word to verify it works. If it does not work: You should restore the registry values you deleted by double clicking on the 'Avery Recent Data Files.reg' backup that you saved to the desktop in Step 3.
Step 9: If the Avery Wizard works again: You can delete the 'Avery Recent Data Files.reg' backup that you saved to the desktop in Step 3.
And that's it. This process worked on the two computers that were having this issue at my office. Hopefully it will work for you as well.
Good Luck,
fnis
Apr 14, 2011 | Avery Wizard for PC
Can't open up Avery Design Pro 5 with .zdl files but can open up the files by running the Design Pro 5 first and finding the files. Why is this and how do we fix this?
Start -> Control Panel -> Programs -> Default Programs -> Associate a file type or protocol with a specific program. Scroll through the list of file extensions for .zdl. Double click on the extension. In the Choose the program that you want to use dialog box, choose Avery Design Pro 5 if it is listed. If it's not listed, click on the browse button and locate it. It will open into the C:\Program Files directory. If you don't know where the Avery Design executable (exe) is, you can right click on the icon on you desktop and select properties to find it's location.
Disclaimer: these instruction are for Windows Vista/7. If you are using a different Windows OS the steps will be different. In the future you may want to provide that information.
Mar 21, 2011 | Avery Design Pro 5.0 for PC
I would like to use my printer to print Avery Name Badge Lables 05146. Will you please let me know how to set up in my computer?
Welcome to FixYa!
Set it up by using the Avery CD. Just insert the CD and follow the instructions.
If it does not open automatically, go the CD Drive and look for a file that has the word setup. Double click it and follow the instructions.
You can also choose, download and install a variety of Avery Software from this link http://www.avery.com/avery/en_us/Templates-%26-Software/Software/?Ns=Rank&No=0
Rates and comments are appreciated.
Thank you for using FixYa.
Jas
Feb 24, 2011 | Avery Computers & Internet
How do you convert a .zdp file to a .jpg file
It doesn't look like you can export directly from Avery Design Pro to JPG, but you can download a free copy of Design Pro Limited from Avery's site. Then, you can load you .zdp file and use alt-printscreen to get an image of the Design Pro window. Then, paste the image into Photoshop or a similar program and crop out everything but the label.
Avery Design Pro Limited (free download) at http://www.avery.com/us/Main?action=soft...
Jan 16, 2011 | Avery Design Pro 5.0 for PC
I have a Kodak ESP 5200 series printer. When I try to print Avery 8160 address labels the sheet comes out not printed.
Hi
You can try and download the label again from below link--
Avery 8160 label download
Click the "Download Template" button. Enter your info and click "Submit". Follow the prompts to download the file. After you download your Avery template, be sure to remember where you saved the file on your computer and the file name. Open Microsoft® Word or an Adobe® program for your template and select File > Open to navigate to the drive and folder to open your template. Use the program's formatting and printing features to edit and save your template. For Microsoft® Word users - If the template looks like a blank page, select Table > Show Gridlines to view the template layout.
Hope this helps... Please post back if you need more information.
Daniel
Dec 18, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Can't open a Word Perfect document with .avery at the end.
Please have a look at the FAQ for Avery label maker and see if your question is not answered there.
In general, wordperfect document files will have a .wpd extension. If your file has a .avery extension, it must have been saved by the Avery application and should therefore be opened by the same application.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 28, 2009 | Computers & Internet
Heating & Cooling Logo
696 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
