Question about HTC VX6900 Battery
My HTC smartphone wont turn on or charge and when I plug it in it shows a red light instead of an orange one. Do you know why?
  • 35 Answers
Have you tried leaving it to charge (with the red light on) for a few hours. The red light usually means a completely drained battery that needs a few minutes/hours to recharge.
Also, try cleaning the battery connectors with a rough toothbrush...
Posted on Dec 10, 2009
SOURCE:
Htc chacha wont turn on and orange light flashing
The battery is completely dead, charge for about 1 hour; if flashing light continues then you need a new battery, I've just done this to my phone..
Mar 29, 2012 | HTC Chacha Smartphone
My phone wont turn on and when I try to charge it, it flashes orange on and off instead of showing a solid orange light.
First thing to do is try to replace battery for a test,usually when phone is often used,it can easily discharge like using wifi or any,then simultaneously charger is plug in.this will damage the battery and can be easily drained.
Aug 06, 2011 | HTC Evo Shift 4G (2 GB) Smartphone
My HTC mobile not going to on after pressing power button and on connection of charger it is showing red LED. Same there here. I woke up this morning and my phones just dead. Even if i connect the charger...
Remove the battery then connect the charger without the battery. Then hold down the power button for a few seconds. The red light may come up for a quick second during this process.
Don't remove the charger. After the red light goes off then insert the battery and check if the light turns amber or orange.
Leave it in orange or amber light state for about 2 minutes. After that, try to turn it on. If it turns on then it is resolved. If not then there is a hardware problem with your phone and it needs to be checked at any HTC Service Center.
Jan 28, 2011 | HTC Touch P3450 Smartphone
I have a HTC Touch and he stoped working. and
seems like the battery is deeply discharged or drained off.. try putting the charger for a long time & see if the red light turns orange after a couple of hours.. if not, you need to change your battery..
Mar 10, 2010 | HTC Touch P3450 Smartphone
My htc wont open and when i connect charger, led light goes red what happen?
Maybe your battery is dead and will not charge. Normally when you connect the charger the led must become orange after a few seconds and green when the battery is fully charged. If it stays red the battery is not charging.
Jan 24, 2010 | HTC Touch Dual Slider Smartphone
I see red light instead of orange
did you try the following?
1. disconect you phone from power supply.
2. take the battery out
3. connect the phone back to the charger
4. place the battery back
if it does start charging (after 3 seconds you see the orange light) just leave it for about 60 minutes to charge. if you still get the red light, try again the 1-4 steps one or two times.
if it does not help you, you might need to replace the backup battery in the motherboard. this is a small CMOS battery, very close to the mini USB connector onboard. I think you should send the device to an HTC service center to do this kind of repair, since electronics ans soldering skills will be required for that job.
Aug 22, 2009 | HTC Touch P3450 Smartphone
HTC S710 Smartphone not switching on
The battery is flat.
If the battery is very flat sometimes the phone will not start charging or turn on even when a power cable is connected.
This worked for me:
- Remove battery
- Insert power cable/usb cable
- Orange charge light should start flashing
- Re-insert battery
- Leave phone charge for a couple of hours
- Turn on
Feb 03, 2009 | HTC S710 Smartphone
HTC VX6900 Battery Logo
719 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
rrackman
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
