Question about Kodak EasyShare C713 Digital Camera
My camera will turn on and sometime it doesn't even when i put new batteries in it and i have cleaned the the battery parts and battery for good connection. I have to take the batteries out and put 'em in and it only sometime comes on. it still didn't work but even if I put new batteries in it doesn't work just takine the batteries out and put 'em back in only makes it work randomly and the battery on the negative side seems lower than the other like they're unleveled. there wasnt any corrosion on the battery terminals only had it a few months
  • 4,924 Answers
If I understood correctly ..it a 2 batteries camera ...and the reason they are not leveled is cause at one point they was wrongly inserted and forced the cover door to close...and the contact blades inside just bended in on the side of the negative ...and it has either a miss-contact or just have to level it back by level out the metal contact inside ,,, just take an instrument like a eye pincers to get to that fine contact blade and pull it out a little to make it contact again ..if the bend is permanent and you have no way to pull it out ...try to level the batteries with a little metallic piece smaller that the diameter of the battery ...but big enough in height to be just enough to level the batteries...in this way you assure proper contact with the cover - lid's metal contacts
Posted on Dec 11, 2009
New battery but still wont swith on
Be aware the Kodak Lithium CRV3 battery can't be recharged. Even if you have a charger where the battery can be connected to, it is dangerous to do so. It is an non rechargeable battery, and putting a current through the battery can overheat the battery and it even can explode. You never can get any electrical charge in that battery.
But your camera can be used with rechargeable AA NiMH batteries.
You need two and they can be chafed on most commercial (cheap) battery chargers. I do advice to buy a good brand of batteries, because even the better ones will only set you back 15 or 20 dollar. Sometimes you even can buy a set of 4 batteries, with charges (I advice the set) for little more.
When having a set of 4, still try to keep 2 sets of 2 batteries, that you always use together. On set in the camera one as spare.
When you do have new batteries, and the camera still won't switch on, carefully check is all contacts in then camera are clean and shiny. New batteries should have shiny contacts.
Contact can be cleaned with a dry cloth. Never use any sharp tool in or close to a camera. Scratches on a contact will cause oxidation and the camera will be damaged in a short time.
Success
Feb 11, 2014 | Kodak ZD710 Digital Camera
Battery level quickly empty
I recommend you to buy a new battery. If this doesn't work. Just buy a new Camera, because the engine probably broke.
Dec 28, 2011 | Olympus SP-570UZ Digital Camera
HI GOOD DAY I CANT TURN ON MY CAMERA IT DOESNT WORK EVAN WITH NEW BATERY THANKS
Check to make sure the batteries are inserted correctly.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.Close the [Memory Card / Battery Cover] securely, and then turn the power on.
If your camera still does not work even after you have performed the above procedures, your camera may be malfunctioning. Please have the camera serviced in this case.
Apr 19, 2011 | Canon PowerShot A460 Digital Camera
New battery is considered Empty
Some cameras, even the expensive Nikon professional cameras have the same problem. Sometimes turning it on and off fixes it, sometimes removing and reinserting the battery works. Sometimes, going into the menu and finding "reset" works.
Feb 11, 2010 | Olympus SP-310 Digital Camera
My Kodak M853 does not turn on and off as it did when new. the lens extends and retracts slow and the lens cover opens and closes slow, sometimes not closing at all. This happens under all battery...
1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 21, 2010 | Kodak EasyShare One Digital Camera
My camera cant charge if I put it on the light it dosen't CHARGE EVEN IF I PUT MY USB CORD WHAT SHOLD I DO?
Please note that the camera will only charge from the computer if the camera is turned off. Also try a different USB plug. 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 09, 2010 | Kodak EasyShare M863 Digital Camera
Hello
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 02, 2010 | Kodak EASYSHARE M1063 Digital Camera
Wont come on even when a new battery is installed.
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
My camara turns off when i turn it on even with new batteries
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 4. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 08, 2009 | Kodak Easyshare M753 Digital Camera
Kodak EasyShare C713 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
