Question about Hardware & Accessories
Theban 16amp 24 hour analogue synchronous time with red and blue plug-in pin type. Runs the water feature, got stuffed up during electicity failure and I've lost instructions on how to get it started and program time. Appreciate any help, technically dysfunctional woman
  • 17,970 Answers
What is exactly the model of your Theben Timer ?
Posted on Dec 10, 2009
  • ZJ Limited
    ZJ Limited Dec 10, 2009
    If I dont mistake, your model is one Theben Timer 26, if this is right, just find the catalogue.
    So, if you need other details, can contact with Theben Support
    I really hope helped with this, if I find more info, I send you.
NVRAM Failure oki
OKI provides live customer support 24/7 at 1-800-OKI-DATA (1-800-654-3282) in addition to a live chat feature during "normal" business hours. Visit www.okidata.com and look for the red "chat" button on the right. The skilled technical support staff should be able to fix your problem promptly.
Jan 25, 2013 | OKI B6500 Led Printer
How to program 110123-130 24 hour timer
1) Copy following link to how to set FM1 series 24-hour timer by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
2) With your timer, move override button to center position.
Each pin located around edge of dial represents 15 minutes.
Move pin outward for ON, and inward for OFF.
Set current time by rotating dial until current time appears on clock face.
http://waterheatertimer.org/pdf/Armstrong-FM1-timer.pdf
3) Include photo in your question so expert can see timer and make possible identification
Dec 03, 2012 | Hardware & Accessories
What is a minimum timer setup
Question is not clear, timer is not identified.
Add a comment with in-focus photo of timer posted on flickr.
Minimum on-off time for digital timers is usually 1 minute.
Minimum on-off time for plug-in-type 24-hour analog timers is 1/4 hour or 1/2 hour depending on width of tripper-pin-segment.
Minimum on-off time for plug-in-type 7-day analog timer is usually 3 hours.
Plug-in vacation timers are set for random on-off and cannot be set.
Minimum on-off time for box timers with 24 hour dial and wide tripper is 1 to 1-1/2 hours
Minimum on-off time for box timers with 24 hour dial and narrow tripper is 1/4 hour.
Minimum on-off time for box timers with 7-day dial is usually 3 hours
Open following link for information how to set analog timers
Jun 12, 2011 | Intermatic 10 Amp Mechanical Indoor Timer
How to take out cage---need to replace psu----hard to unplug 24 pin also is their manual for the disassembly hp m7760n desktop
is not that hard but before you start this task you should un plug any cable at least half hour before for better results. theres a press pin in the middle just pull it out and all the type molex connectors...replace the power supply for an compatible psu...the same watts power is very inportant in order to avoid blue screens and boot failures..good look
May 27, 2011 | HP Pavilion m7760n PC Desktop
The hot water recirc pump in my new house was equippped w/ this timer. There was no user manual, but it was set by the installer to run the pump during awake hours and shut it off during sleep hours. ...
1) Open link below so we are talking about same type of household system
http://waterheatertimer.org/Water-heater-recirculation-system.html
2) 15 minute interval is misleading.
Pins located on timer dial divide 24-hour day into 15 minute intervals.
You set timer pins and decide which 15 minute intervals you want ON-or-OFF. Do this by moving pins inward or outward with your thumb or ink pen. To check settings, manually rotate timer dial clockwise and listen for pump turning on-off..
Set timer pins for 4 consecutive 15 minute intervals, then timer runs for 1 hour.
After pins are set, then manually rotate dial to set current time.
Dial rotates as time passes, and pins click a lever that turns pump on-off.
3) 5-year Life span. Like all things plumbing, if you have hard water or sand-n-dirt in water lines, then pipes clog. And pumps clog.
Once motor begins to slow down, it overheats and burns out.
Water softener can keep sediment out of lines, but shortens life of water heater.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
4) Real question: do you need a circulation pump? Do you need hot water at your faucet? Can you schedule hot water use, or does recirculation pump have to run several hours per day?
Recirculation pumps causes water heater to run more, the pump consumes 25+ watts depending on pump, and water savings claims of 15,000 gallons per year are fabrication.
Realistic water savings is 700-2000 gallons per year, assuming several folks in the home use water sporadically across a full day, and each time water is used people are waiting for hot water. It also assumes that you never want cold water at the tap and that refrigeration ice maker line prefers hot water to cold.
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on pump/timer or any do-it-yourself project.
We are always less expensive than a service call.
Dec 18, 2010 | Taco 265-1 / 563-2 Combination Analog 24...
GE TBF 17DB 17,2 cu.ft. refrigerator/freezer runs continuously.
Set both controls to their middle settings. Put a glass of water in the frig with a thermometer in it and check the temperature in 48 hours. I is normal for the newer appliances to be on longer than off. Power consumption is highest during start up and it is more efficient to start less often and run longer. When adjusting controls ONLY change one by one number and wait 24 hours before making another change.
Eric
Apr 18, 2010 | Refrigerators
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Looking to put remote start and bypass module in 2007 saturn vue need wiring diagram
12 VOLT CONSTANT ORANGE (+) IGNITION SWITCH HARNESS STARTER YELLOW(+) IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 PINK(+) IGNITION SWITCH HARNESS IGNITION 2 N/A IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 N/A KEYSENSE LIGHT GREEN (-) See NOTE *1 IGNITION SWITCH HARNESS PARKING LIGHTS ( - ) N/A PARKING LIGHTS ( + ) BROWN (+) @ BCM, PIN B10, GRAY 24-PIN PLUG, See NOTE *2 POWER LOCK RED/BLACK (TYPE A) @ BCM, PIN A8, 16-PIN GRAY PLUG, See NOTE *2 POWER UNLOCK ORANGE/BLACK (TYPE A) @ BCM, PIN A7, 16-PIN GRAY PLUG, See NOTE *2 LOCK MOTOR WIRE GRAY (+) IN DRIVERS DOOR HARNESS DOOR TRIGGER See NOTE *3 @ BCM, PINK 24-PIN PLUG, See NOTE *2 8957_VUE_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf DOMELIGHT SUPERVISION WHITE (-) @ BCM, PINK 24-PIN PLUG, PIN A1, See NOTE *2 TRUNK RELEASE N/A SLIDING POWER DOOR N/A HORN BLACK (-) @ BCM, PIN B2, PINK 24-PIN PLUG, See NOTE *2 TACH ANY WIRE NOT PINK or RED @ IGNITION COIL WAIT TO START LIGHT N/A BRAKE LIGHT BLUE (+) @ SWITCH ABOVE BRAKE PEDAL FACTORY ALARM DISARM DISARMS with FACTORY REMOTE ONLY ANTI-THEFT YELLOW (+), ORANGE/BLACK (-) and RED/WHITE (Not used) GM's PASSLOCK 2 System, these wires exit the Ignition Switch Tumbler together and are in the Main Ignition Switch Harness in the Column.
Feb 27, 2010 | 2007 Saturn VUE FWD 4
Setting GE Plug in mechanical timer 24 Hr Model 15119 instructions
pull the pins up for off, down for all, so pull all the pins up then push down the pins for the time you wan the time on
Dec 13, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
Hp compaq dc 7100 psu 24 pin SLIM LINE
why wont you buy a new power supply or a plug that converts from a 20 pin to a 24 pin
Mar 31, 2009 | HP Compaq dc7100 PC Desktop
Hardware & Accessories Logo
734 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
