Question about Canon Cameras
Icon of a shaking hand on LCD screen
I have what looks like a hand shaking on the bottom of the display screen. I've read the user guide, but can't seem to find what this is. I'll appreciate an help.
  • 1,305 Answers
The shaking hand icon has to do with the Image Stabilization control.
If it's continuously shaking, it's set in continuous mode, etc.
You can access control for the "I-S" via the menu...scroll down to IS settings. and you can adjust as desired.
Posted on Dec 10, 2009
How to replace a ccfl backlight bulb on presario cq60-419wm
Whoa!
Let's talk for a minute..........
CCFL = Cold Cathode Fluorescent Lamp. (Bulb)
Similar to Fluorescent lighting used in homes, and businesses; but on a MUCH smaller scale.
Average thickness is 2mm. That is a little thicker than 1/16th of an Inch.
Or about the width of this capital -> O <-
Average length is almost as long, as the LCD screen is in height.
Just like it's larger 'cousins', it has Mercury in it. A POISON.
Point?
They break VERY easily, and have Mercury inside.
I usually suggest changing the LCD screen itself, to replace a Backlight.
More expensive?
YES
If you are talking about price of LCD screen compared to a CCFL bulb.
SAFER?
YES
There is NO price for a human life.
Okay, moving on..................
1) http://www.insidemylaptop.com/replace-lcd-screen-hp-g62-compaq-presario-cq62-laptop/
2) http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
3) Service Manual:
HP Support > Compaq Presario CQ60-419wm Notebook PC >
Manuals download page, (User Guides)
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=3966262&
Scroll down, click on the blue -
Compaq Presario CQ60 Notebook PC HP G60 Notebook PC - Maintenance and Service Guide
[Ignore if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name it may take up to 30 seconds, before the first page comes up.
(The PDF file will not show until fully downloaded )
Go to the top left corner, and click on the small square icon -
Toggle Slider.
Becomes two small square icons.
Show Thumbnails on the left, Show Document Outline on the right.
Click on Show Document Outline to see the Bookmarks menu.
The Zoom In icon ( + ) at the Top, increases the view size when you click on it.
The Zoom Our icon ( - ) decreases the view size.
When I refer to a page number, it is for the Adobe Reader page number box at the Top. (To the right of the Down Arrow) ]
The plastic frame in front of the LCD screen is the Display Bezel.
I may be wrong, but I believe the Display Bezel can be removed, WITHOUT having to remove the entire Display Assembly from the laptop.
Makes life a lot easier.
There is a Philips head screw in the Bottom/Left corner, and a Philips head screw in the Bottom/Right corner, to remove from the Display Bezel.
They are under Screw Covers. The Screw Covers are made of synthetic rubber, or plastic. They are held in place by a type of rubber cement.
I take a computer pick, and gently pry up at the base of the Screw Cover.
If you are careful you should be able to reuse the Screw Covers.
If they do not stick anymore, apply a TINY dab of rubber cement to them, with a toothpick.
The Display Bezel has TABS going around the exterior perimeter of it's inside edges.
These snap into matching LATCHES on the Display Cover.
There also may be some sticky tape, at the bottom/inside edge of the Display Bezel. Means CAREFULLY pry the bottom edge of the Display Bezel when removing.
The best method, of removal of the Display Bezel that I have found, is to flex it.
It is made of space-age plastic, and is pretty tough stuff.
(Of course there are those, who could destroy a steel ball bearing with a rubber mallet, in a sandbox)
I cut a piece of thick construction paper, to just fit the inside edges of the Display Bezel.
Display Assembly laid as far back as possible, the thick piece of construction paper will stay in place.
It is used to prevent scratching of the LCD screen, from your fingernails.
Come to the Inside edge (LCD screen side), of the right/middle side of the Display Bezel. Sliding a fingertip of one hand under the bezel to lift up slightly.
Can't get in? Move over a little. You are at a Tab/Latch.
With one fingertip under the bezel, slide another fingertip under from your other hand. By now a Tab/Latch should have released.
SNAP!
Sounds like you're breaking something.
Keeping the bezel slightly up, move along with the fingertips of one hand, and move towards the Top.
Go along the Top popping Tabs/Latches loose.
Then come down the Left side.
As you reach the bottom ease up on one side a little, and wait for the tape to start releasing. Then ease along the bottom until all the tape releases, and the Display Bezel pops off.
Once the Display Bezel is removed, then disconnect the small cable that comes from the Video Cable (Display Cable - HP), TO the screen Inverter board. (Left side of screen Inverter)
(screen Inverter is mounted behind the Display Bezel, and at the bottom of the Screen Frame.
The Screen Frame is the thin metal frame which surrounds the LCD screen assembly)
[The LCD screen is an assembly of layers. The layers are held in the factory set position by the Screen Frame]
Disconnect the small cable that goes TO the screen Inverter, on the Right side of the screen Inverter.
Remove the screen Inverter, and lay aside.
Remove the Philips head screw at EACH top corner. Holds the Screen Frame TO the Display Cover.
Tilt the top of the LCD screen towards you, remove the clear adhesive tape over the Video Cable connector on the back of the LCD screen.
(DO NOT remove the tape all the way. Just carefully peel it back far enough, so that you can get to the Video cable connector, at the back of the LCD screen. This way you should be able to reuse the tape)
Disconnect the Video Cable (Display Cable) from the back of the LCD screen.
Remove JUST the screws which hold the Hinge Brackets TO the Screen Frame.
The Screen Frame can be taken apart. Of course you will need to do this, BUT ONLY after removing the LCD screen assembly.
THREE screws on each side for the Hinge Brackets.
(Display Panel Brackets)
One towards the Top, two down towards the Bottom.
Pages 64 through 80 in Service Manual.
Page 66/ Bottom; shows the Screw Covers, and Screws to remove from Display Bezel.
Page 68/ Bottom; shows disconnecting the screen Inverter.
Page 69 shows screws to remove in order to remove LCD screen.
(Display Panel)
Page 69/ Bottom shows screws to remove for removing Hinge Brackets.
Pages 128 through 133 - Recycling/Display: shows taking the Screen Frame apart, and accessing Backlight.
For additional questions please post in a Comment.
Regards,
joecoolvette
(WEAR gloves -> BE SAFE)
Feb 25, 2013 | Computers & Internet
I can NOT find the icon on my lcd screen in my user manual for the canon S5IS. It looks like a hand upright, with 2 gusts of wind next to it.
If it's the one shown on page 18 of the Advanced Guide, it's the wind filter. See page 56 of the Advanced Guide for more details. If you need the guide or other documents, you may download them from here.
Oct 18, 2011 | Canon PowerShot S5 IS Digital Camera
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
I am getting stretched images and text on my new LCD Dell monitor 19"
The resolution on your computer isnt set properly to the monitors native. Right click on your desktop and depending on your OS you will either see screen resolution or properties. Adjust until your screen no longer seems stretched.
Either that or your experiencing what is called over-scan. To solve this issue you need to go into your video-cards settings and change them. If you have nvidia then this will be rather easy. Simply search in your start menu for nvidia or in your bottom right hand corner you should see a green slanted eye looking icon when hovered over says nvidia control panel. In there look for the option "adjust desktop size and position"
With radeon drivers (catalyst) its equally as simple, search for catalyst or a red icon in the bottom right hand corner that says catalyst or radeon control panel. From there repeat the steps above.
May 09, 2011 | Computers & Internet
A small icon is displayed at bottom of screen It looks like a hand in brackets. (hand) What does it mean
It means that you may see bluriness in the photo due to camera shake. You will usually see this when the image is being shot indoors or in relative darkness, and you have the flash turned off. It will also be displayed if you are manually setting the shutter speed and have selected a very slow shutter speed for the conditions.
If you see this symbol, try turning on the flash, getting more light on the subject, or use a tripod or place the camera on a very stable surface when taking the shots.
Oct 21, 2009 | Canon Cameras
Hour hand does not match digital time
Hi, activate the touch screen, touch the middle of the screen 3 times slowly until you see the OPT in the LCD. press the middle big button on the side of the watch once until you see the 24H screen, then hold down the same side middle button for 5 seconds, the display will then say SYNCRO.
You first move the hour hand with the top and bottom side buttons to 12 touch the middle of your screen to set then move the minute hand to 12 as straight as you can, then press the middle of the screen to set to exact digital time. Thanks Mark ;-)
Sep 22, 2009 | Tissot T-Touch T33159851 Wrist Watch
When i turn on my digital camera, in the upper left hand corner, there is a red, flash symbol which i don't know how to turn off??? Thank you in advance for your assistance.
You should be able to turn off your flash, or change the flash to a different flash setting by using one of the buttons on somewhere on your camera. The proper button is identified by the flash symbol, that looks the same as the one on your LCD screen, a jagged, down ward facing arrow, that looks something like a bolt of lightning. Simply press this, it will ether change the setting on your LCD, or bring up the settings that you can change manually by selecting whatever setting you want for the flash.If you don't want to change any of the settings, but want to clear the symbol off of your LCD screen simply hit the Display button that will hide those icons from your view and can be seen again simply by hitting display once more. I hope this is of some help to you, if not, consult your user guide or manual that came with the camera, it should explain exactly what to do. I hope that you have success, God bless...
Aug 16, 2009 | Cameras
My daughters nintendo ds lite bottom screen will not stop shaking
you recalabrate the screen five times , then tap it gentally on your hand
Jan 22, 2009 | Nintendo DS Lite - Onyx
Transferring slides from JVC GR-D72US to pc
edawood
The problem most likely is that another device has the G drive reserved. So in Disk Management try to change the camra to another driver letter to see it will show up in My Computer. The link below will help you do this.
http://www.fixya.com/support/r4183994-change_drive_letter_in_windows_xp
Issken
http://www.fixya.com/users/issken
Dec 21, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Screen colors
possibly screen color depth is set to 16 colors. - open control panel display - settings tab, slide the color depth to 16 bit. - change resolution to 800 x 600 for now. reboot and see if that does the trick, then readjust settings to your tastes.
Aug 26, 2007 | Compaq CV 7500 17" CRT Monitor
Cameras Logo
443 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
