Question about Canon DR-2010C Flatbed Scanner
Canon DR 2010C not recognised by computer at start-up
Canon DR 2010C using Captureperfect software shows message "no devices found" on first use each time computer has been started. When usb cable is disconnected then reconnected, the scanner operates as normal. It works well until the next time computer is turned on, same problem.
    Scholar:
  • 124 Answers
Go here:
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=16044
The one you want is the CP Upgrade 3090
Hope this helps
Please leave feedback
Posted on Dec 10, 2009
Testimonial: "have not checked to see if the fix works yet"
I hava a canon dr-2010c scanner. but when I scan the paper through capture touch 2.0 than scanning very fine but when I scan through capture perfect 3.0 than show black page scanning.
Normally it is advisable to use only one Scanning Software. The software has various files which may overwrite the previously installed version. The later version works good.
It is also possible that the brightness/contrast settings in Captureperfect 3 is not proper. Try scanning after altering these.
S. Mohan, India
Apr 03, 2014 | Canon DR-2010C Flatbed Scanner
Twain canoscan
It looks like the manufacturer has what you need - http://www.usa.canon.com/
Nov 26, 2013 | Canon DR-2010C
I have canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device...
Question
canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device -4630".
Answer :- change USB cable which is connect with scanner to PC or laptop definitely it will resolve.
By:- shyam shyam.lal@teamcomputers.com 9210845186
Sep 13, 2011 | Canon DR-2050C Path-Through Scanner
Can not install canon dr=5020 scanner/ installed scsi card then went to canon's site and downlaoded drivers for windows xp-computer asks to add hardward but does not find an "inf" file in the 6...
First ensure that the SCSI card is installed properly. Download DR 5020 drivers from http://software.canon-europe.com/products/0000672.asp and install them. Use CapturePerfect ver 2 or 3 to scan documents. With SCSI based scanners/devices, one should power-on SCSI device first before starting the Computer.
S. Mohan, Chennai, India
Feb 17, 2011 | Canon DR-5020 Path-Through Scanner
My scanner won't scan. I get the message " Scanner is busy, operation can not be completed. Canon DR-2010C Driver Version 1.1.10805.18001 (-4437).
This may mean that something is using it or that something is interfering with it. Try turning everything off, your computer AND your scanner. Wait a minute or two and then turn your scanner on first and the turn your computer back on. When your computer boots back up don't open anything except the scanner. If your still getting the message then there is something else (another attached peripheral) that may be interfering with the scanner.
Oct 29, 2010 | Canon DR-2010C Flatbed Scanner
Getting error 4359 driver in use by another program
It is because there is another instance of CapturePerfect process running. You might have "X"ed it previously, but it did not terminate. To solve this, open up Windows Task Manger and kill "Cappe.exe" in the process tab. When you restart CapturePerfect, the error should go away.
Nov 03, 2009 | Canon DR-2010C Flatbed Scanner
We use Abby 8.0 finereader with kofax VRS. We can not gt the scanner or Abby to reconize the VRS with the scanner hooked up. Everything works fine with another scanner.
Use CapturePerfect ver 2.0 downloadable free. Ver 3.0 is priced. http://software.canon-europe.com/software/0022439.asp?model= though this is under Canon 5020, it works with 9080C.
Have you loaded Device drivers, if not download from http://software.canon-europe.com/products/0010035.asp
Once the driver is loaded you can even use Microsoft Imaging to scan. CapturePerfect is easy and brings out the added features of Canon 9080C.
S. Mohan, Chenai, India
Aug 12, 2009 | Canon DR-9080C Path-Through Scanner
The cannon DR 2580-C resinstalled to new computer
Capture perfect is scannig software, it is not a driver. You can download driver from this site. http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11360
Install driver and use Captureperfect to scan.
Feb 21, 2009 | Canon DR-2580C Path-Through Scanner
Scanner command invalid in current state
I have not used CapturePerfect 3.0. Hope the scanner is just fine. Try count only mode to check if it is okay.
Uninstall Captureperfect. Run chkdsk/scandisk to check if OS is ok. Reinstall Captureperfect again and it should work.
S. Mohan
Jan 31, 2008 | Canon DR-9080C Path-Through Scanner
Canon DR-2010C Flatbed Scanner Logo
564 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
