Question about Singer 7442 Mechanical Sewing Machine
Singer 7442 Bobbin Will not wind
Whenever I engage the bobbin to wind, and press the foot switch, it immediately locks up and all lights light up. To get it to do anything but blink, I have to flip the on/off switch. Then it starts for just a second, winds two or three rounds and locked up again, with a high pitched electronic squeal, all lights blinking again.
  • 1 more comment
  • jomath Jan 19, 2008
    The bottom is molded and a part of the right half or left half of the case, rather like a clam held vertically. After removing the screws, was still unable to get it open--must be some tiny catch hidden to make it difficult to get inside unless professionally trained. I did not get a manual with it, so have only past experience with various machines for operational info.
  • Reynaldo0419 Aug 24, 2008
  • rcrosby05 Apr 17, 2009
    The same thing happened to me. I shut it off, called the manufacturer, and was told it had to be sent in to a warranty center 3 states away. Looked online for further support, then I decided to try it again an hour later and it worked. I think it might get hot, and not work, just my theory. I am just happy I don't have to send it away!
My wife had the same problem with a high pitched electronic squeal, all lights blinking. A quick cleaning of the machine cured the problem. Raise the needle to the highest point and remove the needle plate by removing the 2 screws. Remove the bobbin case and clean all the fibers out and your machine will run like new.
Posted on May 01, 2011
  • 133 Answers
I had a similar problem I connected a voltage stabilizer to the machine and all works fine guys this machine is sensitive to voltage so plz see that the voltage is perfect.
Posted on Mar 14, 2009
I accidentally used 220V for my singer 7442, I don't know if there is a fuse that I can change? can someone help me with this?
Posted on Sep 07, 2008
2 Suggested Answers
SOURCE: Singer 7442 Bobbin Will not wind
to wind a bobbin you get thread and put it where it usually would be put it behind those 2 metal piece (see pic in manual) and there put it around the thread guide and then u put the tip of the thread through the hole of the top of the bobbin from the inside to the outside  and u are really to start, u should already have the bobbin and the spinning metal piece, then u move the metal piece to the right into the notch and press the presser foot and hold it until it stops you and you're done :-)
Posted on Mar 27, 2008
How to fill the bobbin
sorry no make nor model we don't know who to ask
Mar 15, 2015 | Sewing Machines
How do I wind the bobbin on the Baby Lock Bl9?
will the bobbin winder spindel not move to the right at all?
Apr 02, 2012 | Baby Lock Sewing Machines
I only want to know if the wheel must be loosened to wind the bobbin and if so with direction, to the front or backwards and press and turn or pull and turn.thanks
Which make and model sewing machine do you have?
None of my sewing machines need the wheel to be loosened for bobbin winding. The Singer Touch & Sew bobbins are filled in place. Use the handwheel to get the needle into the highest position (just turn the wheel). Wrap the top thread around the screw that holds the presser foot; open the slide plate part way and press the bobbin wind button. Hold the top thread and then begin winding by stepping on the foot pedal.. The thread should break after a few winds.
The Kenmore and the Husqvarna Vikings both get wound at the top. Place bobbin on winding pin. With the needle up and metal presser foot in place thread the top thread up to the bobbin (through the guides) and up through the hole in the bobbin. Slide the bobbin winding switch over towards the bobbin. Hold the thread tightly and begin winding (step on the foot control). After a few winds are on the bobbin, cut the thread that you were holding flush with the top of the bobbin. Continue winding the bobbin. (The newest Viking in the group has a computer screen; on that one, do not press OK until done winding the bobbin.)
However, if the handwheel is not turning and the needle is down, first find out why it isn't turning properly. This could indicate a tangle of thread somewhere in the system. (The older Husqvarna sewing machine in my home has a non-functional handwheel. The machine will still sew but you have to use the needle up/down switch that forces the needle to stop in the up position before you run out of bobbin.)
Please add a comment with the specifics of your sewing machine and I'll be glad to add additional information.
I hope this helps.
Feb 28, 2012 | Sewing Machines
Singer Touchtronic 2000 - it will not wind a bobbin, I have found a manual onlin that says you just drop it in and push the foot feed and it will wind the bobbin but it doesn't do anything.
Take your thread that is under the presser foot and wind the thread on the tension disk. It is located right above and to the left of the presser foot. Then you will drop in the bobbin and slide the thread into the **** in the top of the bobbin. Push the little white tab in the bobbin slot all the way to the right until it is in the center of the bobbin. Then press the foot feed and the bobbin should wind.
Oct 24, 2010 | Singer Sewing Machines
We have 2 singer 7442 machines and they will no longer wind the bobbin. Up to this point we followed the instructions the manual gave on how to thread and wind the bobbin. How do we fix?
If you have followed the instructions and the winders do not work, the machines will need to be repaired, or you could purchase a Sidewinder Bobbin Winder and forgo the expense of having the machines repaired.
Mar 08, 2010 | Singer 7442 Mechanical Sewing Machine
Singer touch n sew 750 winding bobbins
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Jun 21, 2009 | Singer 7442 Mechanical Sewing Machine
Singer 7442 Mechanical Sewing Machine Logo
692 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
