Question about Rheem Paloma PTG-74XN / RTG-74XN Natural Gas Outdoor
Rtg-74xn-1 owners manual download, how can I find the manual?
4 Suggested Answers
SOURCE:
SOURCE: I have a Rheem tanklees water heater, model
Contact Paloma/Rheem 866-720-2076. Super nice! I just called regarding mine. Having same problem Rheem Paloma sending parts out tomorrow overnite. Try turn it on/ off by moving tiny switch under the unit that tells you the temperature. Run your fingers along the bottom to find it. That is a temporary fix. Below is a website with all the error codes, so you know what is wrong. Good luck and blessings!
http://www.palomastore.com/paloma_error_codes.html
76
Communication Fault with Remote Control Check remote control wiring for loose or damaged connections. Bypass remote control cable by connection remote directly to remote control terminals on PCB (replace cable if found to be faulty). Replace remote control. Replace PCB
76
76
76
Posted on Nov 09, 2010
SOURCE: We have enjoyed a Rheem Thermostat and a Paloma
Before calling service technician, open following links for Rheem troubleshooting resources, including generic error codes and contact information for Rheem and recent manuals:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://www.fixya.com/tags/rtg_74pvn
Error codes are start place for troubleshoot, and multiple error codes can indicate bad PC board.
Same error code on one machine can be different cause and solution than another machine.
Error 76 is usually communication problem with remote control.
Disconnect wires from machine, and clean terminals is a start point.
Wire between machine and remote might be bad, or remote control is bad, or PC board or wiring connections are bad.
The problem might be solved by having technician catch the machine up on yearly maintenance.
Manual for same-similar product shows maintenance and troubleshooting and a few error codes, but not 76:
For the most part, the manual recommends calling service technician instead of offering DIY details.
http://waterheatertimer.org/pdf/DirectVentManualRTG-74PVN-1.pdf
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jun 09, 2011
  • 5353 Answers
SOURCE: I NEED THE OWNERS MANUAL FOR RHEEM RTG-74XN-2
Open following link for rheem tankless resources, including manuals, error codes and typical maintenance.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on May 19, 2012
Need repair and diagnosis
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#no-error
Fix any tankless problem quickly yourself today for $380... and install tank-type heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Don't buy tankless... don't buy Rheem products... seriously now.
Gene
h
Jan 23, 2014 | Rheem Tankless Water Heater RTG-74XN-1,...
What can cause Hot/Cold spikes on an RTG74-XN
Crossover, low hot water flow, low water pressure, sediment in water lines or heater, heat exchanger needs to be de-limed, water filter needs to be cleaned, water heater temperature set too high, incoming water temperature too high or too low depending on model, MUD or PUD districts with pressure spikes, dirty faucet aerators, loose wires, bad sensor, faulty PD-board, bad venting, dirty burner and combustion parts, etc.
Crossover
http://waterheatertimer.org/Crossover.html
Clean water filter monthly, de-lime tankless yearly
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
No error code:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Overcoming fluctuating temperatures:
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
Resources:
Sep 20, 2011 | Rheem Paloma PTG-74XN / RTG-74XN Natural...
MODEL NO. RTGL 74XN\r\nNOT WORKING SAYING CODE [C211]
Before calling service technician, open following links for Rheem troubleshooting resources:
C2 11 is no ignition:
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Tankless water heater should have yearly maintenance that includes cleaning burner parts, with check of ignition parts, wiring, ignition sequence, gas supply, and bleed gas line if needed.
Chances are that your unit needs to catch up on maintenance.
Maintenance can also catch any condensation problems and make venting adjustments so parts are not degraded due to vent issues.
Tankless should also be delimed each year to preserve efficiency of heat exchanger.
Jun 29, 2011 | Rheem Tankless Water Heater RTG-74XN-1,...
We have enjoyed a Rheem Thermostat and a Paloma Eco Sense tankless gas water heater #RTG-74XN-2 for 2 and 1/2 years, but now there are error codes flashing and resetting the thermostat doesn't hold. ...
Upvote the help.
Jun 05, 2011 | Rheem Paloma PTG-74XN / RTG-74XN Natural...
NO REAL PROBLEMS FOR 3 YEARS, BUT SHOULD I SERVICE UNIT OR AT LEAST CLEAN THE BURNERS?
Following link shows preventative maintenance on page 28
Other Rheem tankless manuals show same information
I have also heard that tankless are susceptible to lime build up and should be de-limed each year.
Page 32 shows lime build-up as a troubleshoot cause.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on water heater or any do-it-yourself project.
Feb 23, 2011 | Rheem Paloma PTG-74XN / RTG-74XN Natural...
RTG-74XN2 won't put out hot water until about 9am.
Tankless questions are complicated because these units have many parts, and both internal and external issues can cause problems. Also problems can arise from combination of issues including maintenance, incoming water temperature, pressure, air quality, venting, water quality, water pressure, in addition to internal washers, gaskets, and parts functioning perfectly with each other over time.
Hot water only after a certain time of day indicates problem might be pressure related.
Which could be local water supply, or clog in line, or sediment on pressure sensor, failed pressure sensor, dirty in-line sediment filter, improper vent, or combination of things listed.
Rheem suggests calling service technician.
Service technicians train for years on one brand of tankless, and then see something new each day.
To understand why service technician is recommended, view number of UNanswered questions on following link showing one Rheem tankless model number.
I suggest avoiding tankless water heaters since all costs are energy.
Clogged pressure sensor after 2 years exposure to hard water. De-liming tankless will not prevent failure from hard water.
For a price, expert works with you via e-mail while you work on water heater or any do-it-yourself project.
Feb 21, 2011 | Rheem Paloma PTG-74XN / RTG-74XN Natural...
I NEED THE OWNERS MANUAL FOR RHEEM RTG-74XN-2 TANKLESS WATER HEATER
Feb 10, 2011 | Rheem Paloma PTG-74XN / RTG-74XN Natural...
Can't find manual & have a C7 error code on a Rheem tankless water heater model # rtg-74pvm-1.
need to contact rheem what you can do until then is remove the control wire it will run until parts ship out
Jul 26, 2010 | Rheem Tankless Hot Water Heater...
Rheem Paloma PTG-74XN /  RTG-74XN Natural Gas Outdoor Logo
243 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
Steve Allison
Steve Allison
Sean Lavelle
Sean Lavelle
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
