Question about Panasonic Lumix DMC-FX30 Digital Camera
Hi everyone The lens sticks in usually or sticks out sometimes- doesnt take pictures and tells me to turn it on and then off but it doesnt fix it- Camera is 14 months old- Harvey Norman where purchased didnt want to know- Can anyone help
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 10, 2009
SOURCE:
How to disassemble a Makinon mc zoom lens
first off, you need special tools to get at the inner elements of a zoom lens - i've been working on lenses for 20 years, and i still don't have every tool needed sometimes :-)
second, makinon lenses are not really worth anything, even if they are in perfect condition - my advice is to buy a better zoom used that is in perfect condition already, since you would have spent that money in tools to try and clean this one, and everyone screws up the first lens they ever try to take apart...
some good lens brand names are sigma, tamron, kiron or any with the same camera name as your camera (canon, nikon, etc)
stick with japan made optics - can't go wrong usually.
good luck...
Nov 30, 2014 | Cameras
WHEN I TURN OFF MY CAMERA MY LENS DOESNT GO BACK IN
There is usually a reset procedure for cameras. Here is some information that might help you out. Please post back it this helps : )
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 22, 2011 | Fuji FinePix Cameras
Dvd player 3280S - plays movei till about halfway, tehn the picture sticks. It seems taht teh disc continues to turn, but the picture doesnt change.
This symptom indicates that your lens motor drive chip is over heating and failing after half an hour, so the laser unit does not read further. You will need professional help as the IC ( chip ) involved is an smd type which needs very good soldering experience to remove and fix. The spare will cost about 5-8 $ plus labor.
Aug 16, 2011 | Sansui Televison & Video
I have the same problem this guy had: I have a Sony Cybershot 8.1 megapixels. Every once in a while the screen will turn black when I turn the camera on. The display will come up (shaky hand, flash, etc.)...
The camera either has a stuck aperture inside the lens or a bad CCD sensor.
The aperture is the opening that allows light to enter the lens. If it's stuck closed no light goes in, so no display on the LCD and solid black pictures. The way to fix it is to replace the lens. You can try tapping or banging the camera on it's side on your hand or even gently on a table. This might unstick the aperture for a short time, but it will just stick again later.
If the CCD is bad the sensor won't show anything other than solid black, or sometimes purple/pink smeared lines. Again the solution is to replace the lens assembly, or look for a used CCD online and just switch that out instead.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 12, 2011 | Sony Cyber-shot DSC-W100 Digital Camera
Hi, I have a Pentax K-x and it usually takes great pictures but for the last past 6 months my pictures look like they covered with dust and also i have have a few spots in the left hand corner looks...
Hi there you are right in your place. Its a dust. but you need to clean in different way. because the dust stick in side the lens and its not easily clean by that dust clean option. Some how your camera get moisture and dust stick on it. After drying the moisture that dust permanently stick there. So i suggest you visit a service center and submit your camera for manual cleaning. They use alcohol and cotton so the dust easily clean by them. Thanks.
Feb 27, 2011 | Pentax Kx Digital Camera with 1855mm lens
Hi, i was wondering if you know how to restore my sony cyber-shot DSC-t77 to its factory settings? My camera use to take really good pictures but now the pictures are all blurr you cant tell what they...
It's a lens problem - the lens sometimes gets debris in between and does not extend out enough to take clear pictures or the lens is crooked from impact or damage. As for the touch screen and not being able to read the menu on your screen, that's also damage. Don't think factory settings will fix this problem. Did you try troubleshooting on google for your camera - maybe they have some fix it suggestions.
Nov 29, 2010 | Sony Cyber-shot DSC-T77 Digital Camera
Camera lens wont open or close after being dropped. it won't turn on and take pictures
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Jul 06, 2009 | Kodak EASYSHARE M1063 Digital Camera
Sony dsc-w55 fell and the lens is stuck
Use bit more force to push or pull the lens as lens has been damaged. If applying bit more force lens goes to working, u saved $$$ otherwise, new lens option is always available at Sony repair shops.
May 30, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Lighting
There is a focus knob on cameras, what you need to do is turn the focus knob until the picture is clear. Sometimes the knob is the same as the part that sticks out and has the lens in the middle of it.
Mar 29, 2008 | Intel Deluxe PC Camera CS330 Webcam
Will not Take Pictures, Lens possibly damaged
Is the lens sticking out at all? does it look square to the body? the front has a square opening is it square with the rest of the camera? Some times a weak battery can cause this or debris in the gears of the mechanism. Sometimes tapping on the unit while powering it on can free the lens and it will function. Sometimes a fresh charged battery will also work. It sometimes can take a bit of power to get it over the jam. Have you dropped it or banged it recently? have you shot in a dusty enviornment latley? sand, dust wind? these conditions can cause problems.
Apr 03, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Panasonic Lumix DMC-FX30 Digital Camera Logo
96 people viewed this question
Top Panasonic Cameras Experts
rajiv6089
Level 1 Expert
AJMAL KHAN
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
