Question about RIM BlackBerry 7290
How can i install the blackberry smartphone into my laptop?
  • 43 Answers
If you no longer have the disc you can get the drivers for your model from the RIM website.
Posted on Apr 30, 2010
7280 507 error
Cause 1 If this error occurs while using the application loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
You need to complete the following steps:
  1. Verify that you have the BlackBerry Device Software installed on your computer. Before you use Application Loader to install software on your BlackBerry wireless device, verify that the necessary device software is installed on your personal computer.
    To verify what device software is installed on your computer
    1. In Desktop Manager, click Help>About Desktop Manager.
    2. Click the Device Software tab.
    The Device Software tab lists the device system software installed on your computer. If the tab is blank, then no device software exists.
  2. If your BlackBerry smartphone is connected to a laptop computer in a docking station, disconnect the laptop computer from the docking station and connect the BlackBerry smartphone directly to the laptop computer.
  3. If a third-party program, such as a virus scanner, is using the same communications port (COM port) as BlackBerry® Desktop Manager, close the third-party program to free the COM port for use.
  4. If you are using a USB adapter to connect your BlackBerry smartphone to a serial port on your computer, temporarily connect your BlackBerry smartphone to a computer with a USB port.
  5. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  6. Use the application loader tool to install the BlackBerry Device Software.
OR
Cause 2 It may occur when all data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
  1. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  2. Use the application loader tool to install the BlackBerry Device Software. Cause 3 It may occurs when the Power Management feature on the computer turns off the USB ports.
  1. On your computer, click Start > Settings > Control Panel.
  2. In the Control Panel, double-click the System icon. The System Properties window opens.
  3. Click the Hardware tab of the System Properties, and click Device Manager.
  4. In the Device Manager, double-click Universal Serial Bus Controllers.
  5. Right-click the first USB root hub, and click Properties.
  6. In the Properties window, click the Power Management tab.
  7. Clear the Allow the computer to turn off this device to save power check box.
  8. Repeat steps 5 to 7 for all other USB root hubs.
  9. Restart your computer.
Cause 4:
It may occurs when the BlackBerry smartphone is connected to a laptop computer using a docking station. You need to complete the following steps:
  1. Disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer using a USB cable.
  2. Re-install the BlackBerry Device Software using the application loader tool.
Nov 08, 2009 | RIM BlackBerry 7290
My blackberry 7290 gives error 507 with a circle at the top
You will receive the following Java error 507 message on your BlackBerry smartphone while using the application loader tool to install or upgrade the BlackBerry Device Software.
Cause 1:
This might occurs while using the application loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
To resolve this error you need to complete the following steps:
Cause 2
This might occurs while all data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
Cause 3:
This might occurs while the Power Management feature on the computer turns off the USB ports.
Cause 4:
This might occurs while the BlackBerry smartphone is connected to a laptop computer using a docking station.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Oct 21, 2009 | RIM BlackBerry 7290
Phone refuses to turn on. red light keeps blinking and can't connect to my pc
  1. Verify that BlackBerry Device Software is installed on the computer.
  2. If the BlackBerry smartphone is connected to a laptop computer using a docking station, disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer.
  3. If a third-party application uses the same communications port as the BlackBerry Desktop Software, close the third-party application.
  4. If you use a USB adapter to connect the BlackBerry smartphone to a serial port, temporarily connect the BlackBerry smartphone to a USB port.
  5. In the BlackBerry Desktop Manager, double-click Application Loader.
  6. Follow the Application Loader tool prompts to install the BlackBerry Device Software.
Oct 19, 2009 | RIM BlackBerry Pearl Smartphone
Blackberry red light then reboots!
This behavior indicates that no applications are installed on the BlackBerry smartphone.
CAUSE: The Application Loader tool in BlackBerry® Desktop Manager removed existing
applications from the BlackBerry smartphone, but failed to install new applications.
RESOLUTION:-
1) Verify that BlackBerry Device Software is installed on the computer.
2) If the BlackBerry smartphone is connected to a laptop computer using a docking station,disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer.
3) If a third-party application uses the same communications port as the BlackBerry Desktop Software, close the third-party application.
4) If you use a USB adapter to connect the BlackBerry smartphone to a serial port, temporarily connect the BlackBerry smartphone to a USB port.
5) In the BlackBerry Desktop Manager, double-click Application Loader.
6) Follow the Application Loader tool prompts to install the BlackBerry Device Software.
Oct 15, 2009 | RIM BlackBerry Pearl 8100
I woke up this morning to find find the screen of my new BlackBerry Curve reading "JVM Error 545 incompatible or corrupt filesystem." It was charging all night. Unless my roommate messed with it, I have...
The BlackBerry Device Software is corrupted.
u need to reinstall the software.
Install the latest version of the BlackBerry Device Software on the BlackBerry smartphone.
The BlackBerry Desktop Manager will not detect the BlackBerry smartphone in this state. To force the BlackBerry Desktop Manager to detect the BlackBerry smartphone, run the Application loader tool. For instructions on how to force the BlackBerry Desktop Manager to detect the BLackBerry smartphone.
Perform following steps
BlackBerry Desktop Manager 4.5.0 and later
  1. Remove the battery from the back of the BlackBerry smartphone.
  2. Connect the BlackBerry smartphone to the computer using a USB cable.
  3. In BlackBerry Desktop Manager, double-click Application Loader.
  4. Click Start under the Update Software heading
  5. The Device Password dialog will display. If the BlackBerry smartphone has a password enabled, enter the password. If the BlackBerry smartphone does not have a password, leave this field empty.
  6. Click OK.
  7. If prompted with a list of Available Updates, choose the latest software version by selecting the corresponding check box and then click Next.
  8. Click the Settings button under the Device backup and restore options.
  9. Make sure that the Back up device data automatically during the installation process check box is not selected.
  10. Make sure that the Delete all application data and Erase all currently installed applications check boxes are both selected.
  11. Click OK on the Settings dialog.
  12. Insert the battery into the back of the BlackBerry smartphone.
  13. In the Application Loader wizard, click Next to proceed with the loading process.
  14. When the process is complete, the Application Loader wizard will display the following message: The loading operation was successful.
  15. Insert the memory card, if applicable.
  16. Close the Application Loader wizard.
If you are getting problem in installation of configuration kindly contact me
Please Rate !
Sep 04, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry 8100
error 507 means that the operating system on the handheld is missing.
1) Download the latest version of the handheld os from your carrier's web site
2) Execute the downloaded file
3) Locate and delete VENDOR.XML from your PC's C: drive
4) Connect the BB and start Desktop Manager
It should reload now.
Jun 25, 2009 | RIM BlackBerry Pearl 8100
Phone has error code 507 with a square and a triangle, and a line running trough it
Cause:
This error message can have the following causes:
While using the Application Loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
All data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
The Power Management feature on the computer turns off the USB ports.
The BlackBerry smartphone is connected to a laptop computer using a docking station.
Resolution
The following are possible resolutions for this issue.
Cause 1
Resolution 1
Complete the following steps:
Verify that you have the BlackBerry Device Software installed on your computer. For instructions, see KB03295.
Use the Application Loader tool to install the BlackBerry Device Software.
Cause 2
Resolution 2
Open BlackBerry® Desktop Manager and double-click the Application Loader icon.
Cause 3
Note: This resolution is for Windows® XP users only.
Resolution 3
Cause 4
Resolution 4
Re-install the BlackBerry Device Software using the Application Loader tool.
May 17, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
I have a blackberry pearl 8100 and it turned off and now all it will do is flash a red light in the upper right hand corner. I have taken out the battery memory card messed with the sims card. What...
CAUSE: The Application Loader tool in BlackBerry® Desktop Manager removed existing applications from the BlackBerry smartphone, but failed to install new applications.
RESOLUTION
Apr 12, 2009 | RIM BlackBerry Pearl Smartphone
507 error resolution
The error message indicates that no applications are loaded on the BlackBerry smartphone.
Cause 1
While using the application loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
Cause 2
Even after performing these steps if you could find the same error, please let us know so that we can provide the further resolution.
Mar 07, 2009 | RIM BlackBerry 7290 Smartphone
Reload software 507
Cause:
Resolution
Cause 1
Resolution 1
Cause 2
Resolution 2
Cause 3
Resolution 3
Cause 4
Resolution 4
Feb 18, 2009 | RIM BlackBerry Bold 9000 Smartphone
RIM BlackBerry 7290 Logo
59 people viewed this question
Top RIM Computers & Internet Experts
Otman Lahlou
Otman Lahlou
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
