Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Profile Side-by-Side Refrigerator Ice Maker Issue
I hope someone has come across this...
My water & ice dispenser seems to be on strike.  The water comes out just fine.  But, when I press either the crush ice or regular ice cube button then try to dispense ice, the lights blink and then absolute silence and no lights at all.  Not even the motor for the auger tries to turn.
The ice is producing just fine.  I got ice, lots of pretty ice but the only way I can get to it is to pull down the drawer and pick it out of the holder.  Does anyone have any ideas before I suffer the dreaded GE Help Line? Thanks! Tamra
  • jwilson3317 Jan 21, 2008
    Plug was corroded from sitting in water in the toe plate. GE should have connected the plug to the bottom of the frig.
  • Singapore B Jun 30, 2008
    The dispenser unit completely shuts the entire fridge down into some kind of reset mode for 5 min or so. Any attempt to get ice or water results in the control panel going blank, and a clicking sound with the fridge seemingly trying to reset or get the compressor started.
  • 447 Answers
The Computer on the Door communicates to the Main Control Board on the rear of unit via several small low voltage DC wires .Ive had this problem and is was a bad connection under the freezer door behind the toe plate (it goes through the middle of the hinge). You can try wiggling that connector, but if it still doesnt work you may have to bypass that connector with proper techniques. Unplug before cutting or splicing, If is still doesnt work than There is no other way to tell what the issue is besides replacing display board and Main board. I would try Main board first if connection is good. Hope this helps
Posted on Jan 19, 2008
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Nov 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile side by side with water/ice dispenser. The water is working but the water to make ice is not working, hence no ice. I had ice, used it all and then nothing.
I would try putting water in ice maker if it freezes ice maker is ok if so feplace water valve. careful only 4oz. of water in ice maker
Oct 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
My ice maker will not work, Ge profile Arctica.
Here you dad had the same issues...Good Luck!
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
May 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
372 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
