Question about IBM ThinkPad A21m 2628 Notebook
Problem: Matshita SR-8175 DVD-ROM in IBM Thinkpad A21m 2628-GSG
My DVD-ROM is very selective of what CD's and DVD's it recognises. It does not seem to matter if it is a + or -, R or RW... I have tested the CD/DVD's that do not work in my laptop in other DVD drives, and they are fine... Somebody suggested it could be the format they're written in...
I am running Windows XP SP2, and according to all the forums, etc on the web, the driver isn't the problem. I have come across suggestions of BIOS and firmware updates, but I am not sure if that is the thing to do first.
Any input whatsoever would be greatly appreciated!! I am lost without those "unreadable" CD/DVD's!
  • 1,067 Answers
Re: Problem: Matshita SR-8175 DVD-ROM in IBM Thinkpad...
Update the firmware is the 1st thing to do ok to read more disk
Posted on Jan 19, 2008
0 characters
3 Points
Boot Method for IBM ThinkpadA21m
Set bott sequence to DVD/CD first. Insert you OS or rescue disc and re boot.
Nov 24, 2013 | IBM ThinkPad A21m 2628 Notebook
How do i connect my ibm thinkpad a21m to the internet
You need the next three letters or numbers after 2628 - ___ Go here click on laptop and tablets click on thinkpad A series then A21m Then 2628 then the next three then your operating system then voila there you have all your drives and any update for your thinkpad Bookmark so you will always be able to fix what ever may be wrong.. Please rate!!!
Nov 23, 2012 | IBM ThinkPad A21m 2628 Notebook
I have IBM 2628-DRU Think Pad A21m And this PC sets password for BIOS, and I can't use it, because I don't know the password
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 22, 2010 | IBM ThinkPad A21m 2628 Notebook
Deiver ibm thinkpad a21m 2628
Good day!Go to IBM site and write that model of your PC Notebook..You can find the drivers there..
Mar 26, 2010 | IBM ThinkPad A21m 2628 Notebook
How do I turn on the wireless on an IBM ThinkPad 2628 A20m Thanks in advance
To turn on the wireless on IBM Think Pad 2628 A20m you can try the below options
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the Fn+F5 key-combo.
IBM Thinkpad (General) - Most have software switch or button on Left hand side.
IBM Thinkpad (model not further identified) wireless switch on Front edge of case.
IBM T43/X32 - Fn+F5 -Click "Turn On"
IBM ZD series use the antenna-like button just below the “Lock” key.
Let me know fi this will help
Dec 04, 2009 | IBM ThinkPad A21m 2628 Notebook
My ThinkPad A21m will not play Dvd now,Power Dvd XP installed
There can me many solutions,
1. first one and the most possible problem is the malfunctioning of the solve this plz uninstall ur DVD ROM drivers from the driver manager and then restsrt it, when you will restart the system it will automatically say that new hardware has been fonded and drivers will be installed automatically just wait for that.Restart again, and u will find it runnig.
2. might be lens of it is cracked, dusty so check tht.
3. Might be u have denied it from reading through BIOS.
4 Also check that you have not taken the aceess rights of users from reading CD/DVDs
Jun 14, 2009 | IBM ThinkPad A21m 2628 Notebook
Ibm thinkpad A21m 2628 floppy dr not working
Take a can or air and blow a little bit into the drive to make sure dust is not in there. Then use good known floppy disks to see if it reads at that point. If it still doesn't read then the floppy drive is bad and will need to be replaced.
Feb 02, 2009 | IBM ThinkPad A21m 2628 Notebook
Visual cd drive but when disk is placed -no D: drive (supposed to be erased)
hi there,
got some good news and bad news -
the good news is that u can still get a replacement drive for your laptop P/N FRU P/N
ThinkPad 24x-10x CD-ROM Ultrabay 2000 Drive 05K9233 05K9158, 05K9159 Yes
the bad news the drive might not be installed or is faulty which case you will have to get someone u know with a contact number and knows about computer hardware to help u replace the drive...
Apr 13, 2008 | PC Laptops
Always shutdown my IBM ThinkPad A21m 2628 PC Notebook
It must be a processor overheating problem, check the vents are not restricted and if the fan is always on or never comes on because of a faulty temp setting then theres a overheating problem and the processor will shut down before any damage.
Oct 02, 2007 | IBM ThinkPad A21m 2628 Notebook
IBM ThinkPad A21m 2628 Notebook Logo
857 people viewed this question
Top IBM PC Laptops Experts
John mullen
 Mike M
Mike M
Level 1 Expert
Are you an IBM PC Laptop Expert? Answer questions, earn points and help others
