Question about Performance Teknique ICBM-771 Car Audio Amplifier
Cuento con un amplificador performance teknique
I have a performance teknique PT500.2 amplifier, i want to know if this amplifier and the performance teknique icbm 771 are the same, i think so because they have similar specifications. i connected 2 sub jbl p1200 wich are 5ohms impedance. but the amplifier only give me 100WRMS per channel, the amplifier could give me 240 W RMS bridged in mono but i want to know if in serie connection (10ohms) it could damage any part of my sistem.
so what if i connect the subwoofers in paralel bridged plus one 1.5ohms resistance?
4 Suggested Answers
  • 631 Answers
SOURCE: performance teknique icbm 892 1200 watt amp
DD, JL and pioneer in that order. I don't recommend any particular size but 12s are a good compromise.
Posted on Sep 22, 2008
blueextc3221
  • 15935 Answers
SOURCE: ICBM-DIGITAL MONO-Channel 2000W AMPLIFIER speaker much
Look into competition lines of different manufacturers.... Massive Audio DMX, Soundstream, Atomic APX, Incriminator Audio Death Penalty Series, Kicker Solo X etc. In car audio, you have to pay to play. Dont expect a 100.00 subwoofer to take 2000W continuously.
Massive Audio offers a no questions asked warranty. Even covers blown voicecoils!
Posted on Dec 22, 2008
SOURCE: Performance Teknique ICBM-771.
probly your ground isnt connected right or yor spaekers are probly not connected right recheck and check if the ohmms set on your speakers your amp probly ant handle it
Posted on Feb 19, 2009
Ayuda con el MTX THUNDER 895
Ojala que no pagastes mucho por el. SI tienes un tecknico cerquitas te lo puede reparad barato. Si lo tienes que mandar a MTX no conveine.
Feb 19, 2014 | MTX Thunder 5-Channel Amplifier 895 Car...
Technics Amplifier SU-VZ320 plays sound for a while and just cuts out sound. Tried switching off and on but no sounds comes through. Leave it off for a while then turn it back on get sound then cuts out...
puede ser un problema con la fuente de poder de la planta,con los parlantes,con los cables y terminales que conectan los parlantes con la planta ,puesto que la mayoria de amplificadores tienen control de temperatura y al sobrecalentarce se apaga por protecion y por eso ensiende por un rato y despues se apaga, por favor revice que los parlantes y los cables con teminales esten bien y no esten aciendo contacto
Oct 05, 2010 | Technics Audio Players & Recorders
Hola por favor necesito el diagrama de este amplificador no me sale audio y necesito poder repararlo
debes revisar todos los transistores que no esten da?ados.se miden con un multimetro y se supone que midan de 500-700 ohmios
Sep 02, 2010 | Kicker 06ZX750.1 Car Audio Amplifier
Hola mi stereo panasonic 8901u no se escucha k podra ser no hay audio las salidas de el stereo no trabajan
te recomendo k sakes el stereo y lo prueves fuera del carro cheques las salidas ,si todo esta bien checa con un probador si las bocinas no estan haciendo tierra si todo esta bien,tienes k saber si tu carros tiene amplificador de fabrica ,muchas veces no tiene corrien te por eso no tiene sonodo,una manera facil de saber si tiene o no amplificador de fabrica con una bateria pequena(triple aaa)con un lado de la pila tocas un lado de labocino al mismo tienpo con el otro lado tocas el otro estremo de la bocina por un segundo si no tiene amplificador de fabrica tiene k escuchar un tronido cuando tocas la bateria,repite los mismos pasos con todas las bocinas si no hay respuesta ,es k tienes aplificador de fabrica y tienes k remplazarlo si necesitas mas informacion llamame 5203126061 k tengas buen dia
Jun 15, 2010 | Panasonic CQ-CB8901U CD Player
Tengo un performance teknique 774 yse apaga cuando le sibo volimen
Si dos cosas bien importante deves acer primero es la entrade de tierra debe estar en buen metal,segundo que no este interferiendo ningun corto falso.
Jan 04, 2010 | Performance Teknique ICBM-776 Car Audio...
HOLA, ME GUSTARIA SABER COMO CONECTO EN BRIDGE MI KENWOOD KAC X1R??
Es un monoblock amplifier, esto significa que el amplificador es de un solo canal, y este tipo de amplificador no se puede conectar en bridge.
Aug 11, 2009 | Kenwood KAC-X1R Car Audio Amplifier
Amplificador panasonic modelo sa-he7, se pone en error f70
rafatecnico amigo mio el error esta en la placa de coneccion de dispositivos auxiliares por favor revisa soldaduras de los dos transistores de potencia que se encuentran juntos y de los dos transistores de acople de los de potencia, si se encuentran bien entonces alguno de ellos esta averiado en cortocircuito o abierto
Jul 29, 2009 | Technics Audio Players & Recorders
Performance teknique icbm-896 stick on diagnostics
If it's in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Sep 10, 2008 | Performance Teknique ICBM-896 Car Audio...
Performance Teknique ICBM-771 Car Audio Amplifier Logo
172 people viewed this question
Top Performance Teknique Car Audio & Video Experts
hoyzee1
Jose Velazquez
Jose Velazquez
George Nalley
Level 1 Expert
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
