Question about Graco Digital Deluxe Imonitor With Vibration
I have two moniters that are beeping and red light is on ive been cgarging still not working what can i do?
Ive just replaced my power supply and when i turn on the computer i get a continuous beeping sound.also my moniter wont display.ive got pwer to it but no picture and the mouse dont work.all fans ar running...
You may have to reseat the memory.
Check all motherboard connections and if that does not work for you, remove and resaet your video card and work one card at a time.
Dec 31, 2009 | Soltek SL-K8AN2E (SL-K8AN2E-GR)...
Wont post led 3 flashes
if its the red flashing light on the tower, its the hard drive activity light.
when the monitor goes on stand by, does the tower retain power? (green light on and flashing red light sometimes?) Does your keyboard's scroll lock/num lock/caps lock keys and keyboard lights work?
Sep 07, 2009 | AOpen AX4SPB-UN (91.8AT10.013) Motherboard
It does not start, gives one long beep (about 2-3 seconds) silence and beep again
Switching DDR cards solved the problem. I was getting long beeps every 2 seconds. No short beeps. Just one long beep every 2 seconds. Thanks Josh Whitehead.
Apr 23, 2009 | Computers & Internet
Acer Aspire T180 wouldn't turn on...
Hi again.
It's the memory thats the problem, continuous beeps indicate a memory failure, take the system memory out and clean the contacts and the slots with a dry, clean paintbrush. Re-seat the memory and re-start the machine. If you still get beeps post back.
Good luck!!
Feb 15, 2009 | Acer Aspireā„¢ T180 PC Desktop
I have a cisnet not exactly sure what model my sister gave me
chack the monitor cable with c.p.u and other probleam is your R.A.M is not work fine
Feb 14, 2009 | ZT Group Cisnet PC Desktop
Is there help for this dragon doesnt go on ive tryed video mem ?
This might be problem with your RAM. Remove the RAM and connect it to another memory slot or try changing RAM with new one.
Remove your PCI card and try now...
Sep 28, 2008 | Soyo i845 P4I Fire Dragon Pentium 4...
Booting up
one light is for hardrive activity , the other is to show the power is on.. the flashing one is most likely the power light as most computers will tell you when thier ill....the beeping is an error code and should be in some pattern EG: Power LED blinks red twice, once a second, followed by a two second pause. Or something like that. Take note of the pattern and repost it here, then we can give you a specific area to look at.
Sep 16, 2008 | HP Compaq d530c PC Desktop
Constant beeping,won't turn on
What is the beep pattern? beeeeeeeep, beep,beep beeeeeep etc. also what BIOS do you have?
Aug 05, 2006 | Gateway EV 700 17" CRT Monitor
Graco Digital Deluxe Imonitor With Vibration Logo
65 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
