Question about Samsung TXN3075WHF 30" TV
Power turn-on after 5min.s cut off power
Sometime power cord take off and then put on TV power normality work
and then cut off again.
please , how i do?
  • aik1 Jan 15, 2009
    I have a similar problem. My started by power cut off after about 5 minutes. But now, it turns off right after you turn it on. I need help with this problem.
  • 30 Answers
Chek for leakage capacitors.hope thisn will help
Posted on Feb 09, 2008
TV wont trun on. Pull plug and wait 5min, still wont turn on. What can be done to fix this
Tv turn on?Front LCD panel LED power light indication flashing?Yes,than the power supply board is dead,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 09, 2010 | Philips 32PFL3403D/27 32 in. LCD TV
Tv turns off by itself after few seconds has been turned on
tv turning off automatically
for first unplug the main power cord of the tv for couple of minutes and then reconnect it.also before reconnecting the power cord of the tv again remove all the external device wires connected at its back such as dvd player/vcr etc etc.just connect only tv wire and check out.if still the same problem then its quite possible that the capacitors and ic on the circuit board are getting short in between so the circuit is not getting completed and cutting in between so the tv power led comes but no picture comes up..in this case the circuit board needs to be checked with a multimeter.the faulty and burned out component part should be detected and then should be replaced with the help of soldering iron.to make it proper.to avoid further damage i suggest you that do not on the tv again and again as it will short some more tiny components and the reparing cost will increase as per that.at present its the normal circuit short problem in the tv get it repaired before using the tv again.
Dec 28, 2009 | Panasonic Televison & Video
, power cuts off ,
the power cable is broke, but not completely thats why come in and out ...
Dec 13, 2009 | RCA HD52W56 52" Rear Projection HDTV
My tv shuts off at random times and when I turn it on again the color is messed up.
Nov 16, 2009 | Olevia LT42HVi 42 in. LCD Television
Turn it on and sometimes it turns itself off. Can usually get it to stay on. When the set is warm the volume reduces by itself with lots of clicking noises, when it gets to zero the set changes channel by...
for first unplug the main power cord of the tv for couple of minutes and then reconnect it.also before reconnecting the power cord of the tv again remove all the external device wires connected at its back such as dvd player/vcr etc etc.just connect only tv wire and check out.if still the same problem then its quite possible that the capacitors and ic on the circuit board are getting short in between so the circuit is not getting completed and cutting in between so the tv starts and turns off.in this case the circuit board needs to be checked with a multimeter.the faulty and burned out component part should be detected and then should be replaced with the help of soldering iron.to make it proper.to avoid further damage i suggest you that do not on the tv again and again as it will short some more tiny components and the reparing cost will increase as per that.at present its the normal circuit short problem in the tv get it repaired before using the tv again.
youcan get the required parts from ------ www.partstore.com --
www.radioshack.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 20, 2009 | Televison & Video
Audio is fine, but video will off after 5min ON time
Good Day, howac506;
The most common problem for your 1991 TV is the vertical out put IC (IC) part number 272p239040.
I hope this was helpful.
Good Luck again, big IRISH.
Aug 04, 2008 | Televison & Video
Samsung TXN3075WHF 30" TV Logo
123 people viewed this question
Jerry Greenberg
Jerry Greenberg
