Question about Cross Furnace Draft Inducer Blower 115 Volts Fasco # A064
My heater no call for heat - Cross Furnace Draft Inducer Blower 115 Volts Fasco # A064
  • 288 Answers
This motor is a light duty motor and before it comes on, all of the safety switches...i.e. rollout switches, high limit switch must be closed before voltage will go to the inducer fan will be energized. You can check the fan with an ohm meter and see if you have any resistance. if you do, its good. the door switch on your furnace must also be closed before the furnace will be energized at all
Posted on Dec 19, 2009
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
Will well water cause a problem on the heat pump water heater
I would say yes.
Because element may not be easy to replace, or easy to reset unit after replacement
I would also suggest not buying heat pump... must be in at least 10'x10' room with 7" space around entire heater
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html
Gene
Oct 15, 2014 | GEH50DEEDSC GeoSpring Hybrid Water...
Heater not working blows but no heat
Oh no! What do you do when your car heater not working? How do you figure out why there's no heat in car? What if you have no heater in car? Before you start trying to figure out how to fix car heater yourself, you should know a little about how your car's heating system operates. That will help you to figure out your car heater problem and why your heater isn't working properly or even at all! So, let's talk about how your heating system functions and then about some of the more obvious reasons that it you may be getting no heat from car heater. In order to heat up the inside of your car, the heating system uses some of the excess heat produced from your engine. Actually the engine produces so much heat that if you didn't have a way to release it (the heating/cooling system in your car) it could harm and even destroy the engine! That is why the heating/cooling system is set up to remove some of the heat and keep your car running smoothly.
Oct 05, 2012 | 1997 Lincoln Continental
Not sure if a blower is in this model because feel no air comeing from unit
The blower is/was a $69.00 optional add on feature for that heater. To be quite honest, a blower does little on an Infrared Heater. Infrared, unlike Blue Flame Convection Heaters, doesn't waste energy heating the air. It heats objects (floor, walls, furniture, etc). From that the room air heats up. Simply put, it heats a room like the sun heats the earth. It's really more efficient than a gas convection heater. Rated 99.9% efficient at 15,000 Btu's, it will heat a good sized room easily.
I've selling these heaters for several years and I always try to talk the customer out f wasting their money on a blower. It's simply not needed on an infrared heater.
I hope this helped you and thanks for choosing FixYa.
Aug 20, 2011 | Empire ECS HearthRite HR25EL Heater
Every time we put on the central heating our water runs cold
What kind of water heater do you have?
In any case, it sound like a plumber should check out system.
Do you have indirect heater that gets heat from central heating boiler?
Most indirect/boiler combo heaters have control that is set to heat the water first.
If water is not getting heated, then the control needs repair.
Do you have gas water heater with gas central heating?
The central heater may be drawing so much gas from meter, that other gas appliances are unable to function. larger gas meter or gas line may be needed.
Or if furnace and water heater vent on same chimney, the backflow from central heat could be affecting burner on water heater especially if water heater has electronic sensor that stop combustion if air quality is bad. Venting problems can lead to CO poisoning, and are a serious matter.
Nov 18, 2010 | Water Heaters
My check engine light has come on in my 2006 Pontiac G6 after 2 and a half years. What could possibly be wrong since I keep my car serviced and the guys had just told me that my car was in tip top shape?
P0016 - Crankshaft Position Camshaft Position Correlation Bank 1 Sensor A
P0030 - Heated Oxygen Sensor (H02S) Heater Control Circuit Bank 1 Sensor 1
P0031 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 1
P0032 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 1
P0036 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2
P0037 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 2
P0038 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 2
P0050 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1
P0051 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 1
P0052 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 1
P0053 - HO2S Heater Resistance Bank 1 Sensor 1 (PCM)
P0054 - HO2S Heater Resistance Bank 1 Sensor 2 (PCM)
P0056 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2
P0057 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 2
P0058 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 2
P0068 - Throttle Body Airflow Performance (PCM)
P0100 - MAF Sensor Circuit Insufficient Activity
Jun 25, 2009 | 2006 Pontiac G6
When temperature is placed on HI, very little heater comes from heater
if the fan is blowing air normally, but the heat is less! than you need to replace the heating coil of the heater. i'm sure your problem will solved................have a nice day:-)
May 13, 2009 | Pelonis WM-HO202C Oil Filled Radiator...
Pool and Spa Heaters pros and cons
An electric heat pump needs heat available to pump. If it is 30 degrees outside, heating a spa to 102 or so, may be impossible unless the heater has some type of alternative heat source. A properly sized, gas fired heater can take care of a larger range of heating needs. A combination heat pump and natural gas heater, probably with a controller, really makes the issue more difficult, expensive, and would require a lot of study for efficient, cost effective operation. Bottom line: In really mild climates a heat pump might do the job. In cooler climates the gas heater rules. And where a wide range of temperatures and high heat demand is wanted by the customer, a gas heater is the only way to go. A backup heat pump may take years to payout.
Aug 27, 2008 | Saunacore Special Edition Residential...
Cross Furnace Draft Inducer Blower  115 Volts Fasco # A064 Logo
271 people viewed this question
Top Cross Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Cross Measuring Tool and Sensor Expert? Answer questions, earn points and help others
