Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Plugged in but won't turn on - Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
  • Euro-Pro Master
  • 43,501 Answers
Hi,,
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 29, 2010
SOURCE:
I can't unscrew the plug on the water reservoir??
Same thing happened to me. The plastic cap gets "stripped" inside and won't catch to turn. I removed the plastic cap with a big wrench and a lot of muscle. Then used an adjustable to remove the metal screw-in plug. I still use it this way and put the metal cap on and off with a wrench. Just have to be very careful as it gets extremely hot.
Jun 30, 2012 | Euro-Pro Shark SC-505 Handheld Steam...
It won't turn on
Have you checked the cords for a possible break preventing the machine from getting power. Use a AC volt meter to diagnose this. Many times the wires at the plug that goes in the wall break and it is the most common problem. Other issues are a defective motor and a defective on/off switch.
Jan 15, 2012 | Bissell Cleanview Helix Vacuum
My dirt devil model bd10025w won;t recharge when plugged in and won'yt woek when plugged in
Assuming that you've tried a different electrical outlet, it may have a defective charger or a totally dead rechargeable battery.
Try Dirt Devil's customer help line:
1-800-321-1134.
Good luck from Detroit, MI.
Jul 18, 2011 | Vacuums
Hi, My Henry hoover has stopped working about 10
Check the motor brushes as well as the on/off switch.
Sep 20, 2017 | Hoover Vacuums
I have a brand new KitchenAid mixer that is 5 years old and never used. I unpacked it this morning and it won't turn on, no noise, no movement, nothing. Help.
Please check manually the motor and see if it moves freely. Now make sure that the power plug and the connections to the switch are not tampered , check the continuity of the plug to the switch and to the motors.
If you notice any dirt or insects make sure that this has not clogged on the motor. If so clean using a degreasing spray- WD40- would be recommended.
If the motor is tight , lightly oil or degrease using the spray while manually rotating.
Once this is done connect the power while taking all precaution. Use the meter to check the flow of the circuit to the switch and to the motor. If there is a trip switch see that it is reset.
If there is power to the motor and still it does not work the brushes might be dirty and might need a cleaning/ reset.
Jul 07, 2011 | Vacuums
Where is the reset button on shark navigator. vacuumed throw rug, and bar wont move
I'm not sure it has one. Check the owner's manual though.
Try this. Turn off vacuum. Unplug it. Make sure there are no clogs in main hose, power head intake tube, or intake inside tank. Plug it in, turn it on, and let us know what happens.
Aug 23, 2010 | Euro-Pro EuroPro Shark Navigator Vacuum
Rotating brushes will not turn
If belts are ok then possibly needs new front brush motor replaced.
Nov 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
135 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
