Question about KDS K717s 17" LCD Monitor
The monitor goes blank after just a few seconds or sometimes works for hours.
I have a KDS Model 700P, Product # K717S which is about 1 year old. It works fine sometimes for hours and other times the screen will look a little dark and then go blank after just a few seconds. Shutting off and then on again makes it work for about 1 second before going blank again.
  • 1 more comment
  • Anonymous Jan 31, 2008
    Same problem here with my KDS monitor, I suspect heat build-up,
  • kentr6727 Feb 15, 2008
    We have the 19 inch K917 and it too goes dark after a few minutes. It is probably the display tube inverter circuit. Another web page "Selectric Typwriter museum" at selectric.org had the same problem and he installed a small fan in the back of the monitor to blow air into the power supply. Like many monitors the AC to DC supply is built into the monitor. They may not have proper airflow for longterm operation.
    Do these monitors have a small easily replaceable inverter PCB like laptop screens have?
  • alexyarden Apr 10, 2008
    I have a KDS Model 700P, Product # K717S which is about 2 year old. it work for about 1 second before going blank again.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • KDS Master
  • 848 Answers
The monitor goes blank after just a few seconds or sometimes works for hours? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
860 AB0 170DTLAPH PI 170DTLA 200 000 170DTLA AH 860 AB0 170DTLAPH Power...
Posted on Jan 03, 2015
My monitor worked one day - gone the next. Nothing on the screen except a bright green glow. No tech support for this problem. They want $70. just to look at it.
Posted on Mar 06, 2008
I tried the fan idea to cool it and it didn't work.
Posted on Mar 02, 2008
KDS K717 MODEL 700P MONITOR works dimly for a second or two and then goes blank.
Your monitor has faulty light bulb(s). Replacement is hard.
Apr 07, 2012 | Computers & Internet
Necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
Dec 12, 2010 | KDS K717s 17" LCD Monitor
Kds 700p monitor
Power supply filter caps will be he first thing to check, look for leaking/bulging tops.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
May 11, 2010 | KDS K717s 17" LCD Monitor
Kds 700p monitor
The most common problem with LCD monitors is the capacitors that are on the power pack. the pack usually looses or pops as we say 2-6 of them after 3-5 years. its almost a certainty after 5 years. a component repair tech can replace these but unless you can find some one like me who will do it for cheap to save the landfill you most likely will buy a new one.
Mar 19, 2010 | KDS K717s 17" LCD Monitor
My monitor is fine, I cannot find the power jack. Do you know where I can find one?
Hi
Please see the following link
many available for fairly cheap prices
http://shop.ebay.com/sis.html?_kw=KDS+LCD+Monitor+17inch+17%22+k717+k+/+717+700p+/+700+p&_nkw=KDS+LCD+Monitor+17inch+17+k717+k+717+700p+700+p
I hope this has been useful
Mar 09, 2010 | KDS K717s 17" LCD Monitor
Monitor Life
Instructions follow, RESULT "Replace and never buy a KDS USA Monitor again (less than 3 years usage)."
Dec 29, 2008 | KDS K717s 17" LCD Monitor
Can my KDS (#K717S-700P) monitor be wall mounted?
This monitor can be wall mounted but I do not know what bracket you would use.
If you look on the back of the monitor you should see 4 indents in the sticker near the corners. If you don't then rub around near the corners of the sticker. With a sharp knife or pin you should be able to lift out these tiny stickers. You need to measure the distance between these on the horizontal, vertical and diagonal then you should be able to ask somebody at your local TV dealer for help locating the correct bracket.
I'm sorry i can't be more helpful.
Nov 24, 2008 | KDS K717s 17" LCD Monitor
This is a common problem across many monitors, unfortunately. The problem stems from one of two things, typically.
Itis either the Power Inverter board (Inverter Mirage Electronics AD-1700Rev:F 200-000-170DTL1 VERSION:A) or a weak or dying backlight.
Ifyour monitor comes on for a few seconds then you can test the backlight byusing the controls to get into the backlight brightnes settings on theOSD and turning it WAY down.
If that doesn't work or if it won't come on at all then it islikely bad capacitors on the Power board mentioned above. If you feeladventurous and know how to solder then you might be able to fix thisyourself. You need to be careful however because you are dealing withhigh voltage in there and capacitors CAN hold a charge long after youhave unplugged the unit. You can read more about this power board aswell as how to replace the bad caps HERE.
Ifthat's not for you then I would recommend taking it to a local TV shopfor them to fix. The parts shouldn't be more than $20, but labor can beexpensive.
Jul 30, 2008 | KDS K717s 17" LCD Monitor
KDS K717s = Radius-73 Model 700P
Most are snapped at the corners and center of each side.  A plastic ipod pry tool will usually get the process started, and you just work your way around the frame.  Starting at one corner is best.
srich
May 27, 2008 | Gateway FPD2275W LCD Monitor
Two possible causes are bad capacitors or a bad light inside the LCD panel.
Open the unit and check to see if any of the capacitors in the power supplyor other boards look domed or vented on the top.
Replace any capacitors accordingly. Monitor should work fine after that.
If not try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistora go bad. Also, you may have a bad light inside the panel. This is tough to test without a spare light to use for troubleshooting the panel lights.
You can take the panel apart and inspect the lamps but it is very tedious. It's tough enough to get them apart and back together again never mind keeping the layers clean. You have to try not to get any dust between the layers or you will see it in the picture.
There's usually two light fixtures each of which holds two lamps. One fixture at the top and one at the bottom. Remove them one at a time and inspect the lamps to see if any are broken or very dark on the ends. If one looks out of place, it could be bad.
You'll have to find replacement lights on the net. It's not easy to replace them, but if you've gone this far, good luck. You should be able to get generic instructions off of the site that sells the lamps.
Feb 13, 2008 | ViewSonic VX924 19" LCD Monitor
KDS K717s 17" LCD Monitor Logo
426 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
